Max cable diameter (mm)
Connectic
Contacts Material (Connector)
Contacts Plating (Connector)
Contacts number
2 - 5
Mounting type
Pavel V.
Good and tight plugs
Good and tight plugs, but despite my impression from the pictures, there is actually no grooving to put on a coloured rubber...
Pavel V.
Excellent amplifier with a power-on issue
Excellent amplifier. The only serious issue: it can frequently trip sensitive circuit breakers on start-up. The NC252MP...
Pavel V.
Excellent amplifier
- the power supply produces a very slight high-piched noise (~4kHz)...
Jack Plugs
We offer a very wide range of Jack connectors. Jack plugs are essential in the audio world, and are available in different formats, materials, plating, or in different ways: crimping, soldering, or clamping. Among our numerous jack connectors, discover the recognized brands such as Furutech, Elecaudio, Neotech, or 1877PHONO.
  • Jack 3.5mm
    Jack 3.5mm
    Discover our range of 3.5mm jack connectors, for the design of your HiFi analog audio cables.
  • Jack 6.35mm
    Jack 6.35mm
    Discover our range of 6.35mm jack connectors for the design of your analog audio cables.
  • Jack 2.5 mm
    Jack 2.5 mm
    Discover our range of 2.5mm jack connectors, for the design of your balanced analog audio cables.
  • Jack 4.4mm
    Jack 4.4mm
    Discover our range of 4.4mm jack connectors for the design of your balanced analog audio cables.
