TOPPING E50 II DAC White
The Topping E50 II, an evolution of the E50, is a DAC that offers excellent performance thanks to meticulously selected components. It also features a number of improvements in terms of functionality compared to its little brother. The E50 II benefits from an AK4497S chip coupled with an XMOS XU316 interface, enabling it to support high-resolution sampling rates up to 32-bit 768kHz PCM and DSD512 while maintaining a THD+N of just 0.0001% and offering a dynamic range of up to 131dB.
Reference : 21358
198,66 €tax incl.
165,55 € tax excl.
Shipping date: 13-11-2026.
Topping E50 II DAC AK4497S XMOS XU316 Bluetooth LDAC 32bit 768kHz DSD512 White
TOPPING E50II picture
The Topping E50 II, an evolution of the E50, is a DAC that offers excellent performance thanks to meticulously selected components. It also features a number of improvements in terms of functionality compared to its little brother. The E50 II benefits from an AK4497S chip coupled with an XMOS XU316 interface, enabling it to support high-resolution sampling rates up to 32-bit 768kHz PCM and DSD512 while maintaining a THD+N of just 0.0001% and offering a dynamic range of up to 131dB. Bluetooth allows the E50 II to support high-resolution codecs up to LDAC for flawless wireless reception and superior audio quality. In addition to Bluetooth, other improvements include support for ADAT, the Topping Home app, and a 10-band PEQ function for precise sound adjustment. In terms of connectivity, it has all the essentials with several digital inputs and two analog stereo outputs, one RCA and the second a balanced 6.35mm TRS jack.
The strengths of the TOPPING E50II
Topping E50 II: an excellent chipset
AK4497S DAC
AK4497S DAC
The AKM AK4497S stereo DAC chip based on VELVETSOUND technology enables the E50 II to deliver exceptional performance. Notably, a THD+N of 0.0001% @ 1kHz and an SNR of up to 131dB.
XMOS XU316 USB interface
The XMOS USB interface allows the E50 II to support high-definition sampling rates up to PCM 32-bit 768kHz and DSD512.
FGPA for ADAT processing
FPGA for ADAT processing
An FPGA chip automatically recognizes SPDIF or ADAT signals and processes both formats for greater versatility.
Topping E50 II: high-definition Bluetooth
The Topping E50 II features a Qualcomm QCC5125 Bluetooth chip, allowing it to receive SBC, AAC, aptX, aptX Adaptive, aptX HD, and LDAC codecs. This means you can enjoy wireless listening at up to 24-bit 96kHz for the most enjoyable listening experience.
Bluetooth functionality of the TOPPING E50II
Preamplification function of the TOPPING E50II
Topping E50 II: preamplification function
A preamplification mode allows the Topping E50 II to be connected directly to a power amplifier or active speakers while offering precise volume control via the included infrared remote control.
Topping E50 II: powerful output level
The E50 II's independent output stage offers different output levels to suit any type of amplifier, whether it be a headphone amplifier, a power amplifier, or even active speakers. Its different output levels help prevent problems such as overloads or insufficient power.
Output level of the E50 II
Unbalanced outputBalanced output
High power output5.6Vrms11.3Vrms (23.2dBu)
Low output power2.6Vrms5.3Vrms (16.7dBu)
Les niveaux de sortie du TOPPING E50II
Topping E50 II: Topping app and 10-band equalizer
The Topping E50 II DAC is compatible with the Topping Home app for remote control via smartphone, but it also supports 10-band equalization to tailor the sound to the genre of music being played or the user's preferences.
SPEQ function support by TOPPING E50II
Topping E50 II overview
Overview of the Topping E50II
1Balanced output on 6.35mm jack (TRS)
2Unbalanced stereo RCA output
3Coaxial input
4Toslink optical output
5Bluetooth antenna
6USB-C input
7Power supply via USB-C
Product typeDAC
DAC chipAK4497S
USB interfaceXMOS XU316
Bluetooth chipQualcomm QCC5125
Inputs1x USB-C
1x Toslink optica
1x Coaxial
Bluetooth
Outputs1x Balanced 6.35mm TRS jack output
1x RCA output
Supported sample ratesPCM up to 32bit 768kHz
DSD up to DSD512
Supported Bluetooth codecsSBC, AAC, aptX, aptX Adaptive, aptX HD, LDAC
RCA output specification
THD+N (A-WT)0.0001% @ 1kHz
THD No-WT 90kBw0.0005% @ 20-20kHz
SINAD (A-WT)120dB @ 1kHz
SNR (A-WT)124dB @ 1kHz U-L
130dB @ 1kHz U-H
Frequency response20Hz-20kHz (±0.1dB)
20Hz-40kHz (±0.3dB)
Output level (@PCM)2.6Vrms/10.7dBu @ 0dBFS, U-L, m-p/d
5.6Vrms/17.2dBu @ 0dBFS, U-H, m-p/d
Output level (@DSD)2.6Vrms/10.7dBu @ 0dBFS, U-L, m-p
3.8Vrms/13.7dBu @ 0dBFS, U-L/H, m-d
Noise A-WT1.7uVrms
Channel separation-130dB @ 1kHz
Channel balance0.3dB
Output impedance50 Ohms
Output couplingAC
DC output configuration1mVrms
Balanced 6.35mm jack output specification
THD No-WT 90kBw0.0002% @ 20-20kHz
SNR (A-WT)125dB @ 1kHz U-L
131dB @ 1kHz U-H
20Hz-40kHz (±0.3dB)
Output level (@PCM)5.3Vrms/10.7dBu @0dBFS, U-L, m-p/d
11.3Vrms/17.2dBu @0dBFS, U-H, m-p/d
Output level (@DSD)5.3Vrms/10.7dBu @0dBFS, U-L, m-p
7.5Vrms/13.7dBu @0dBFS, U-L/H, m-d
Noise A-WT3.0uVrms
Output impedance100 Ohms
Output couplingAC
Power supply5V via USB-C
Dimensions15.5 x 12.9 x 4.1cm
Weight465g
ColorWhite
Package1x Topping E50 II DAC
1x USB-A to USB-C cable
1x USB-C cable
1x Bluetooth antenna
The Topping E50II measurements
OutputJack 6.35mm
DAC / ADC ChipAK4497SVQ
Max sampling rateDSD512
Max sampling rate768kHz
ColorWhite
ClassN/A
Remote ControlYes
TOPPING E50 II DAC AK4497S XMOS XU316 Bluetooth LDAC 32bit 768kHz DSD512 White
The Topping E50 II, an evolution of the E50, is a DAC that offers excellent performance thanks to meticulously selected components. It also...
