Keystone TM314-FGWH Header F
This female Keystone socket is intended for use with plastic wall plates. ( Example:Keystone Plastic Wall Plate 1 Location)
This type of product is used to pass cables through the walls to create a cleaner installation.
Specifications:
| Max cable diameter (mm) | N/A |
| Mounting type | To connect |
| Connectic | Female |
| Max panel thickness (mm) | N/A |
| Impedance (Ω) | NC |
| Contacts Material (Connector) | Copper Alloy |
| Contacts Plating (Connector) | Gold |
