Impedance (Ω)
Speaker Type
Diaphragm type
Loudspeaker diameter (mm)
76 - 530
Efficiency / Sensitivity (dB)
76 - 98
Xmax (mm)
2 - 28
Lowest frequency (Hz)
10 - 70
Highest frequency (Hz)
0 - 9000
Class
Power (W)
500 - 500
Speaker Power (W RMS)
15 W - 2005 W
Input
Roland S.
Dac tv
Walter V.
Great product!
Joli mais non..
Subwoofers
This section presents all our subwoofers dedicated to subwoofer reproduction (very low frequencies). Many brands are represented allowing everyone to find a model that will suit their project. The filters on the page allow you to make a more precise selection according to your needs.
