DAYTON AUDIO SS18-22 Speaker Driver Woofer / Subwoofer
With the SS18-22, Dayton Audio presents a 45.72 cm dual voice coil subwoofer driver. Designed for high-power applications, it combines an anodised aluminium cone with a triple magnet optimised by FEA simulation and a dual spider suspension to deliver 1300W RMS power output into 4Ω over a frequency range of 20 to 400Hz.
By buying this product you get 65 loyalty points
Reference : 21203
659,00 €tax incl.
549,17 € tax excl.
Grantie 5 ans
Dayton Audio SS18-22 Speaker Driver Woofer / Subwoofer 1300W 4Ω 90.8dB Ø45.72cm
Dayton Audio SS18-22 : Front view
With the SS18-22, Dayton Audio presents a 45.72 cm dual voice coil subwoofer driver. Designed for high-power applications, it combines an anodised aluminium cone with a triple magnet optimised by FEA simulation and a dual spider suspension to deliver 1300W RMS power output into 4Ω over a frequency range of 20Hz to 400Hz.
Dayton Audio SS18-22: Aluminium membrane
The SS18-22 uses a thick anodised aluminium membrane, combining lightness and rigidity. This diaphragm resists deformation well, even during significant movements, and maintains strictly pistonic movement throughout the entire excursion. An indexed transition between the cone and the suspension provides additional rigidity at the edges to resist deformation and minimise unwanted resonances. The long-travel butyl rubber suspension completes this assembly, optimised to allow high excursion while maintaining an excellent emissive surface.
Dayton Audio SS18-22 : View of the membrane
Dayton Audio SS18-22 : Magnet
Dayton Audio SS18-22: 3-inch coil and advanced thermal management
The SS18-22 is powered by a 3-inch voice coil, using four layers of copper, coiled on an aluminium support. This configuration maximises the number of turns in the air gap to increase magnetic force while maintaining a reduced gap, ensuring precision. The aluminium support acts as a heat sink and contributes to stability during prolonged use. Combined with significant ventilation through the sub-cone, suspension, magnetic pole and air gap, this design limits thermal stress and allows for a rated power of 1,300 W RMS.
Dayton Audio SS18-22: Low distortion magnetic circuit
At the heart of the SS18-22 is a large triple magnet, engineered using FEA and generating a symmetrical magnetic field. This allows the diaphragm to move identically forwards and backwards, minimising distortion even at the limits of excursion. Precision-machined plates with sculpted edges maximise magnetic flux transfer, while an aluminium short-circuit ring and a large magnetic cap linearise inductance throughout the entire stroke. The result is reduced distortion and constant, precise control of sound reproduction.
Dayton Audio SS18-22 : Magnetic circuit
Dayton Audio SS18-22 : Suspensions
Dayton Audio SS18-22: Unfailing stability
To maintain linear cone movement and eliminate any risk of tilting, the SS18-22 uses a double spider suspension, spaced for greater stability. The connecting wires are stitched into the upper spider to improve mechanical reliability and prevent unwanted contact with the cone or suspension during heavy excursions. This design, combined with the precise control mentioned above, ensures smooth piston-like movement even when pushed to its limits.
Dayton Audio SS18-22 : Spécifications
Product typeSpeaker Driver Woofer / Subwoofer
Nominal diameterØ45.72cm (18")
Power handlingRMS: 1300W
Max: 2600W
Impedance4Ω
Sensitivity90.8dB 2.83V/1m
Frequency response20-400Hz
Voice coil diameterØ7.62cm (3")
Membrane materialAluminium
Suspension materialRubber
Basket materialCast aluminium
Magnet materialFerrite
Thiele-Small Parameters
Resonant frequency (Fs)21Hz
DC Resistance (Re)5.3Ω
Voice coil inductance (Le)2.1mH
Mechanical quality coefficient (Qms)3.4
Electromagnetic quality coefficient (Qes)0.42
Total quality coefficient (Qts)0.37
Compliance equivalent volume (Vas)7.9ft³
Mechanical compliance of suspension (Cms)0.112mm/N
Force factor (BL)29.2T·m
Diaphragm mass inc. airload (Mms)497g
Linear excursion (Xmax)26mm
Surface area of cones (Sd)1188cm²
Information regarding assembly
Total external diameterØ46.99cm (18.5")
Cutting diameter of the baffleØ41.91cm (16.5")
Depth26.035cm (10.25")
Weight20.5kg
PackageSold by unit
Speaker Power (W RMS)1300.0
Speaker TypeWoofer
Speaker TypeSubwoofer
Impedance (Ω)4
Loudspeaker diameter (mm)450.0
Diaphragm typeAluminium
Efficiency / Sensitivity (dB)91.0
Max Linear Excursion (Xmax) (mm)26.0
Lowest frequency (Hz)20
Highest frequency (Hz)400
DAYTON AUDIO SS18-22 Speaker Driver Woofer / Subwoofer 1300W 4 Ohm 90.8dB Ø45.72cm
With the SS18-22, Dayton Audio presents a 45.72 cm dual voice coil subwoofer driver. Designed for high-power applications, it combines an anodised...
