HiVi SP10 Speaker Subwoofer Long Tour 10 "
By buying this product you get 28 loyalty points
Reference : 4775
281,00 €tax incl.
234,17 € tax excl.
https://www.audiophonics.fr/images2/Swans_Logo.gif
Model SP10 uses proprietary technology HiVi Symmetric Motor Drive(SMD), which consists in immersing the moving coil in the center of a powerful symmetrical magnetic field .
This symmetrization of the motor allows reducing the inductance of the movable part , and thuscontrol movement more effectively of the membrane.
The support of this crew participates actively in the " evacuation of thermal releases , and ensures the loudspeaker longevity.
The winding employs aluminum wireallowing a superior power holding, with perfectly controlled and linear displacements on one XMAX 15.5mm.
The membrane is made from multilayer pressed paper , guaranteeing a rigidity and an impermeability outside norm.
https://www.audiophonics.fr/images2/4770_SWANS-HIVI-SP10_1.jpg
https://www.audiophonics.fr/images2/4770_SWANS-HIVI-SP10_2.jpg
SSpecifications:
  • Nominal Impedance:4Ω
  • Resonant Frequency: 34Hz
  • Rated Power:500W
  • Sensitivity (2.83v / 1m): 84dB
  • Resistance DC:/ Strong>3.4Ω
  • Diameter Coil: 76mm
  • Length Coil:46mm
  • Mounting Type:SV
  • Composition Coil:Wire Aluminum
  • Number of Layers:2
  • Chassis: Aluminum
  • Composition Magnetic Circuit: Ferrite
  • Magnetic Shielding:/ Strong>Yes
  • BL:16.6
  • Hey :15mm
  • XmaX:15.5mm
  • Cms:91.4
  • Qms:4.83
  • Qes:0.75
  • Qts:0.57
  • Mms:235g
  • Sd:0.0363m2
  • Vas:17.1
  • Recommended Type of Load: Close
  • Recommended Load Volume: 20L
  • Recommended Cut-Off Frequency -3dB: 43Hz
  • Weight:13kg
https://www.audiophonics.fr/images2/HiVi_Logo.jpg
https://www.audiophonics.fr/images2/4770_SWANS-HIVI-SP10_5.jpg
HiViSP10:Dimensions
https://www.audiophonics.fr/images2/4770_SWANS-HIVI-SP10_3.jpg
HiViSP10:Frequency Response
https://www.audiophonics.fr/images2/4770_SWANS-HIVI-SP10_4.jpg
HiViSP10:Impedance Curve
Speaker TypeSubwoofer
Impedance (Ω)4
