WONDOM AA-SP15113 SUPB7615 Subwoofer Speaker Driver
The Wondom SUPB7615 is a compact 7.62cm (3") subwoofer designed for integration into audio systems with limited space. It has a power handling capacity of 15W, utilising a paper cone combined with a rubber surround to minimise cone breakup and maintain consistent reproduction at the lower end of the frequency range.
Reference : 22033
16,90 €tax incl.
14,08 € tax excl.
Shipping date: 18-11-2026.
Wondom AA-SP15113 SUPB7615 Subwoofer Speaker Driver 15W 8 Ohm 80dB Ø7.62cm
WONDOM AA-SP15113 SUPS7515 : Front view
Designed for in-car systems or custom-built speakers, it features a pre-assembled polypropylene chassis that makes installation easier whilst ensuring the mechanical stability required to withstand the stresses of installation. This approach is complemented by the use of silicone components, which help to control unwanted resonance.
WONDOM AA-SP15113 SUPS7515 : Frequency response and impedance
Technical Specifications
Driver typeSubwoofer
Nominal diameter7.62cm (3")
Power handlingRMS : 15W
Max : 30W
Sensitivity80dB
Diaphragm materialPaper
Surround materialRubber
Thiele-Small Parameters
Resonance frequency (fs)160Hz ±20Hz
Nominal impedance (Zn)8Ω @1kHz
Minimum impedance (Zmin)7.4Ω ±0.2Ω
Maximum impedance (Zmax)23.4Ω ±0.3Ω
DC resistance (Re)7.5Ω
Voice coil inductance (Le)1.31mH @2kHz
0.59µH @20Hz
Maximum mechanical excursion (Xmech)±2mm
Weight423.5g
PackageSold by unit
Speaker Power (W RMS)15.0
Speaker TypeSubwoofer
Impedance (Ω)8
Loudspeaker diameter (mm)76.2
Diaphragm typePaper
Efficiency / Sensitivity (dB)80.0
Max Linear Excursion (Xmax) (mm)N/A
Lowest frequency (Hz)N/A
Highest frequency (Hz)N/A
WONDOM AA-SP15113 SUPB7615 Speaker Driver Subwoofer 15W 8 Ohm 80dB Ø7.62cm
The Wondom SUPB7615 is a compact 7.62cm (3") subwoofer designed for integration into audio systems with limited space. It has a power handling...
