By buying this product you get 26 loyalty points
Low Noise Omnidirectional Measuring Microphone USB XMOS ASIO 32bit 192kHz
The UMIK-2 is the second generation MiniDSP omnidirectional low-noise measuring microphone. It takes advantage of everything that made the first version, the UMIK-1, so successful, such as its Plug & Play USB interface or its calibration file, unique for each microphone for optimal accuracy.
Of course, the UMIK-2 benefits from significant improvements in performance and functionality. A 1/2" larger capsule is used to achieve lower noise and distortion, preserved by the 32bit ADC integrated in an aluminum chassis. In addition, the sampling rate is selectable from 44.1kHz to 192kHz for extended compatibility with the widest range of measurement and recording software.
The microphone is fully compatible with REW (Room EQ Wizard) and Dirac Live (version 3 and later) software. No driver is required for systems running Mac OS, Linux, Android or iOS, and an ASIO driver is provided for Windows systems for easy integration.
All UMIK-2s are calibrated using a single calibration file. In addition, a unique 90 degree calibration file is automatically generated. To download the calibration files go to this page and enter the serial number on your microphone in the field provided.
MiniDSP provides two calibration files, to be used according to your audio system :
| Specifications | |
| Product type | Measuring microphone |
| Capsule | 1/2" Low noise pre-polarized condenser 60 UNS |
| Capsule sensitivity | -34dBfs @ 0dB Gain (97dB SPL, 1kHz) |
| Capsule noise level | -1055.3dBfs (A) @ 0dB Gain |
| Sampling rate | Up to 32bit 192kHz |
| SPL Max (0dBfs) | 125dB SPL |
| Equivalent input noise level (EIN) | 20dB SPL @ 0dB Gain |
| OS Compatibility | Mac OSX / Linux / Android without driver Compatible ASIO driver for Windows via UAC2 MiniDSP driver iOS with USB Camera Kit |
| ADC | 32bit Analog gain up to 60dB |
| SNR ADC | 120dB |
| General | |
| Body material | Aluminum |
| Dimensions | 21 x 185mm |
| Weight | 150g |
| Package | 1x MiniDSP UMIK-2 1x Shielded USB-C cable 1x Mini tripod + microphone clamp 1x Wind screen |
Average votes 5.0 / 5 4 reviews | Why write products reviews ? You can share your feelings about products and help other people by sharing your experience |
Ulrich N.
Lory N.
Serkan A.
Giovanni-Mattia P.
