Intégrité de la source réduction du jitter Utiliser sur deux parfums différents: SMSL(akm) et Audio-gd(wm8741) pour le casque. L'étage en terme de gain est tout...
Câbles remarquables. Branchés sur mon Drive CD Atoll 400 SE, les détails et la précision des timbres sont remarquables. Câbles étonnants, à brancher...
This section presents all our midrange, midbass and full range speakers. Many brands are represented allowing everyone to find a model that will suit their project. The filters on the page allow you to make a more precise selection according to your needs.
The Tang Band W5-1611SAF is a 12.7cm diameter full range driver, ideal for integration into compact loudspeakers. It features a robust polypropylene diaphragm supported by a rubber surround and is powered by a suspension motor.
Tang Bang's W8-1772 full-range driver offers extensive sound reproduction thanks to its 22.38cm-diameter diaphragm. It has a power handling capacity of 30W, a paper diaphragm and a fabric suspension for optimum performance.
Tectonic's BMR range consists of full range loudspeakers designed to cover a very large part of the audible audio spectrum. Thus, the TEBM35C10-4 has an extended frequency response from 100Hz to 20kHz and a wide directivity.
Tectonic's BMR range consists of wideband loudspeakers designed to cover a very large part of the audible audio spectrum. Thus, the TEBM65C20F-8 has an extended frequency response from 80Hz to 20kHz and a wide directivity.
Tectonic's BMR range consists of full-range speakers designed to cover a very wide part of the audible spectrum. For example, the TEBM65C20F-4 features an extended frequency response from 60Hz to 20kHz, as well as wide directivity.
The Visaton BF 32 is a small full range loudspeaker with a diameter of 3.2cm. It offers a wide and balanced frequency response and good low frequency reproduction. It is particularly suitable for use in equipment where space is limited and depth is thin.
The Visaton FRWS 5 is a full range speaker with a diameter of 5cm and a square front panel. It offers a balanced frequency response above 250Hz with accurate highs and an omnidirectional sound distribution. It can be used as a midrange driver in floorstanding loudspeakers, but will also find its place in many other audio projects.
The Visaton K 50 is a small full range loudspeaker with a diameter of 5cm, a plastic cone and a metal basket. It offers a wide frequency response and is particularly suitable for use in machines and other equipment where space is at a premium.
The Visaton K 50 WP is a small full range loudspeaker with a diameter of 5cm, with a plastic frame and diaphragm. It offers a wide frequency response and a beautiful sound reproduction. It is particularly suitable for use outdoors or in humid areas.
The Visaton K 64 WP is a small full range loudspeaker with a diameter of 6.4cm, with a plastic frame and diaphragm. It offers a wide frequency response and a beautiful sound reproduction. It is particularly suitable for use outdoors or in humid areas.
The Visaton SL 87 FE is a wide-range loudspeaker with a diameter of Ø8.5cm. It has a plastic membrane, a rubber suspension and benefits from high efficiency thanks to its large ferrite magnet. Its frequency response is very balanced and its reproduction accurate. Compact and very affordable, it will be perfect for designing small DIY speakers.
The Wondom SUPB6510 is a neodymium-powered plastic speaker specially designed for voice applications and DIY projects. In addition, its ultra-compact design makes it suitable for compact music systems.
