WONDOM AA-SP15117 SUPB6510 Neodymium Plastic Speaker 10W 6 Ohms 84.5dB 180Hz
The Wondom SUPB6510 is a neodymium-powered plastic speaker specially designed for voice applications and DIY projects. In addition, its ultra-compact design makes it suitable for compact music systems.
Reference : 21240
14,91 €tax incl.
12,42 € tax excl.
Shipping date: 17-11-2026.
Wondom AA-SP15117 (SUPB6510) Neodymium Plastic Speakers 10W 6 ohms 84.5dB 180Hz (Pair)
WONDOM AA-SP15117 picture
The Wondom SUPB6510 is a neodymium-powered plastic speaker specially designed for voice applications and DIY projects. In addition, its ultra-compact design makes it suitable for compact music systems. The speaker fits perfectly into its enclosure to produce significantly high sensitivity for a small-volume speaker. This speaker is equipped with soft foam and rubber mounts to dampen vibrations when panel mounted.
WONDOM AA-SP15117 measurements
Product typeSpeaker
Speaker typeFull range
Handling power10W
Max. Power15W
Impedance (Nz)6.25 ohm @ 1kHz
Min. impedance (Zmin)5.82 ohm
Max. impedance (Zmax)14.84 ohm
DC resistance (Re)5.6 ohm
Resonance frequency (Rs)130Hz
Coil inductance (Le)24.7uH @ 1kHz
Effective frequency response180Hz
Sensitivity84.5dB
Net weight185g
Total dimensions208 x 94mm
Package1x Pair of Wondom AA-SP15117 (SUPB6510) (1x right speaker + 1x left speaker)
Speaker Power (W RMS)10.0
Speaker TypeFull range
Impedance (Ω)6
Loudspeaker diameter (mm)63.0
Diaphragm typePlastic
Efficiency / Sensitivity (dB)84.5
Max Linear Excursion (Xmax) (mm)N/A
Lowest frequency (Hz)20
Highest frequency (Hz)20000
WONDOM AA-SP15117 SUPB6510 Neodymium Plastic Speakers 10W 6 ohms 84.5dB 180Hz (Pair)
The Wondom SUPB6510 is a neodymium-powered plastic speaker specially designed for voice applications and DIY projects. In addition, its...
