DAYTON AUDIO DMA58-8 Speaker Driver Full Range Dual Magnet 15W 8 Ohm 82.5dB 160Hz-20kHz Ø50.8mm
Delivering high efficiency and low distortion, the Dayton Audio DMA58-8 is an ideal full-range driver for a modern compact speaker design. Its motor uses two neodymium magnets to create a strong and symmetrical magnetic field for perfect diaphragm control.
Reference : 17208
18,90 €tax incl.
15,75 € tax excl.
Grantie 5 ans
Dayton Audio DMA58-8 Haut-Parleur Large Bande Double Aimant 15W 8 Ohm 82.5dB 160Hz-20kHz Ø50.8mm
Delivering high efficiency and low distortion, the Dayton Audio DMA58-8 is an ideal full-range driver for a modern compact speaker design. Its motor uses two neodymium magnets to create a strong and symmetrical magnetic field for perfect diaphragm control. The careful design of the DMA58-8 also reduces inductance and distortion, improving high-frequency response. The double-layer voice coil is wound on a widely ventilated aluminum support, allowing for excellent heat dissipation, power handling and low compression. The aluminum diaphragm is held in place by a rubber suspension and a large basket, providing excellent mechanical damping.
Driver typeFull range
Nominal diameterØ50.8mm (2")
Power handlingRMS : 15W
Max : 30W
Impedance8Ω
Frequency response160Hz - 20kHz
Sensitivity82.5dB 2.83V/1m
Voicec coil diameterØ25.4mm (1")
Weight159g
Thiele-Small parameters
Resonant frequency (fS)166.2Hz
DC resistance (RE)6.9Ω
Electrical quality factor (QES)0.69
Mechanical quality factor (QMS)2.45
Total quality factor (QTS)0.54
Compliance equivalent volume (VAS)0.136L (0.0048ft³)
Voice coil inductance (LE)0.4mH
Force factor (B·l)4.6T·m
Mechanical compliance of suspension (CMS)0.46mm/N
Surface area of cone (SD)14.5cm²
Maximum linear excursion (Xmax)±2mm
Materials
Cone materialAluminum
Surround materialRubber
Voice coil wire materialCopper
Voice coil former materialAluminum
Frame materialPolymer
Magnet materialNeodymium
Mounting informations
Overall outside dimensions56*56mm
Cutout diameterØ49.8mm
Total depth31.75mm
Bolt circle diameterØ64.3mm
Number of mountin holes4
Optimum cabinet size
Sealed volume0.57L (0.02ft³)
Sealed F3235Hz
Vented volume0.57L (0.02ft³
Vented F387Hz
Speaker Power (W RMS)15.0
Speaker TypeFull range
Impedance (Ω)8
Loudspeaker diameter (mm)51.0
Diaphragm typeAluminium
Efficiency / Sensitivity (dB)82.0
Max Linear Excursion (Xmax) (mm)2.0
Lowest frequency (Hz)160
Highest frequency (Hz)20000
Delivering high efficiency and low distortion, the Dayton Audio DMA58-8 is an ideal full-range driver for a modern compact speaker design. Its...
