DAYTON AUDIO MB820-8 Speaker Driver Midbass
New
The Dayton Audio MB820-8 is a 20.32cm (8") bass midrange speaker, with an impedance of 8 Ω, designed for two- or three-way professional loudspeakers. Its power handling of 200 W RMS (400 W maximum), its sensitivity of 94 dB (2.83 V/1 m) and its usable response from 100 to 7,500 Hz allow it to produce high levels while covering a wide frequency range.
Reference : 22543
69,90 €tax incl.
58,25 € tax excl.
Grantie 5 ans
Dayton Audio MB820-8 Speaker Driver Midbass 200W 8 Ohm 94dB 100Hz-7.5kHz Ø20.32cm
DAYTON AUDIO MB820-8: Front view
The Dayton Audio MB820-8 is a bass midrange speaker of 20.32cm (8"), with an impedance of 8Ω, designed for two- or three-way professional loudspeakers. Its power handling of 200W RMS (400W maximum), its sensitivity of 94dB (2.83V / 1m) and its usable response from 100 to 7500Hz allow it to produce high levels while covering a wide frequency range.
Its lightweight paper cone, its cloth surround and its 40 oz ferrite motor with a 5.08cm (2") voice coil promote low-distortion dynamic reproduction. With a maximum linear excursion of 4mm, it fits equally well into PA loudspeakers as into hi-fi, automotive or musical instrument systems, particularly for bass and keyboard.
DAYTON AUDIO MB820-8: Dimensions and measurements
Technical specifications
Product typeBass midrange speaker
Impedance8Ω
Sensitivity94dB 2.83V/1m
Frequency response100Hz-7.5kHz
Voice coil diameter5.08cm (2")
Nominal diameter20.32cm (8")
PowerRMS: 200W
MAX: 400W
Thiele-Small parameters
Resonance frequency (Fs)69Hz
DC resistance (Re)5.26Ω
Voice coil inductance (LE)1.04mH
Mechanical quality coefficient (Qms)3.83
Electromagnetic quality coefficient (Qes)0.52
Total quality coefficient (Qts)0.46
Compliance equivalent volume (Vas)0.56ft³
Mechanical compliance of suspension (Cms)0.26mm/N
Force factor (BL)9.57T·m
Total moving mass + air load on the diaphragm (Mms)20.9g
Max linear excursion (Xmax)4mm
Diaphragm surface area (Sd)208.9cm²
Materials
DiaphragmPaper
SurroundCloth
FrameSteel
MagnetFerrite
Voice coil wireCCA
Mounting informations
Total external diameter8.22"
Cutout diameter7.13"
Depth3.6"
Number of mounting holes8
Recommended Enclosure Volume
Sealed Volume8.49L (0.3ft³)
Sealed F3119Hz
Vented Volume20.38L (0.72ft³)
Vented F361Hz
Sealed F3119Hz
Vented F361Hz
Weight3.6kg
PackageSold individually
Speaker Power (W RMS)200.0
Speaker TypeMidbass
Impedance (Ω)8
Loudspeaker diameter (mm)203.2
Diaphragm typePaper
Efficiency / Sensitivity (dB)94.0
Max Linear Excursion (Xmax) (mm)4.0
Lowest frequency (Hz)100
Highest frequency (Hz)7500
DAYTON AUDIO MB820-8 Speaker Driver Midbass 200W 8 Ohm 94dB 100Hz-7.5kHz Ø20.32cm
The Dayton Audio MB820-8 is a 20.32cm (8") bass midrange speaker, with an impedance of 8 Ω, designed for two- or three-way...
