PURIFI PTT8.0X04-NAB-02 Speaker Driver Full Range
The Purifi PTT8.0X04-NAB-02 is a 20.32 cm (8") speaker with a nominal impedance of 4Ω, designed to reproduce mid-range frequencies while maintaining usable extension in the bass and treble ranges. With its 350W power handling capacity and extremely low distortion level, even at full power, the PTT8.0X04-NAB-02 is the ideal choice of full-range loudspeaker for any Hi-Fi installation.
By buying this product you get 68 loyalty points
Reference : 21562
689,00 €tax incl.
574,17 € tax excl.
Purifi PTT8.0X04-NAB-02 Speaker Driver Full Range 350W 4 Ohm 89.3dB 20Hz-20kHz Ø20.32cm
PURIFI PTT8.0X04-NAB-02 : Front view
PURIFI PTT8.0X04-NAB-02 : Frequency response PURIFI PTT8.0X04-NAB-02 : Dimensions
Product typeFull-range speaker
Power rating350W
Diameter20.32cm (8")
Frequency response20Hz-20kHz
Electrical and acoustic parameters
Nominal impedance4Ω
Minimum impedance above resonance3.8Ω
Minimum impedance frequency241Hz
Maximum impedance52Ω
DC resistance3.5Ω
Voice coil inductance0.18mH
Sound pressure level (SPL)89.3dB @ 2.83Vrms/1m, 300Hz-800Hz
86.1dB @ 1W(Zmin)/1m, 300Hz-800H
Thiele & Small parameters
Resonance frequency (fs)26Hz
Mechanical quality coefficient (Qms)5.3
Electrical quality coefficient (Qes)0.38
Total quality coefficient (Qts)0.36
Equivalent volume (Vas)70.4L
Effective piston area (Sd)235.1cm²
Effective piston diameter (D)17.3cm
Mechanical resistance (Rms)1.32kg/s
Moving mass (Mms)43.2g
Suspension compliance (Cms)0.90mm/N
Weight3.5kg
PackageSold by unit
Speaker Power (W RMS)350.0
Speaker TypeFull range
Impedance (Ω)4
Loudspeaker diameter (mm)203.0
Diaphragm typeAluminium
Efficiency / Sensitivity (dB)89.0
Max Linear Excursion (Xmax) (mm)15.0
Lowest frequency (Hz)20
Highest frequency (Hz)20000
PURIFI PTT8.0X04-NAB-02 Speaker Driver Full Range 350W 4 Ohm 89.3dB 20Hz-20kHz Ø20.32cm
The Purifi PTT8.0X04-NAB-02 is a 20.32 cm (8") speaker with a nominal impedance of 4Ω, designed to reproduce mid-range frequencies...
