TANG BAND W4-2414 Speaker Driver Full Range
The Tang Band W4-2414 full-range speaker delivers a wide sound reproduction thanks to its 11.5 cm diameter diaphragm. It has a power handling capacity of 25W, an aluminium and polypropylene cone, and a Santoprene surround, ensuring excellent performance.
Reference : 21799
79,90 €tax incl.
66,58 € tax excl.
Shipping date: 01-12-2026.
TANG BAND W4-2414 Speaker Driver Full Range 25W 8Ω 87dB 65Hz-40kHz Ø11.5cm
TANG BAND W4-2414 : Front view
TANG BAND W4-2414 : Dimensions and frequency response
Product typeFull-range speaker
Nominal diameterØ115mm
Power ratingRMS : 25W
Max : 50W
Impedance8Ω
Frequency response65Hz - 40kHz
Sensitivity87dB
Voice coil diameter25.4 mm
Thiele & Small parameters
Resonance frequency (fS)65Hz
DC resistance (RE)6.3Ω
Electrical quality coefficient (QES)0.47
Mechanical quality coefficient (QMS)2.77
Total quality coefficient (QTS)0.40
Equivalent volume (VAS)3.87L
Maximum impedance (Zmax)45Ω
Voice coil inductance (LE)0.032mH
Force factor (B·l)5.49T·m
Moving mass (MMD)5.06g
Effective piston area (SD)0.0052 m²
Suspension compliance1007 µm/N
Maximum linear peak (Xmax)2.5mm
Materials
Diaphragm materialAluminum + PP
Surround materialSantoprene
Magnet materialFerrite
PackageSold by unit
Speaker Power (W RMS)25.0
Speaker TypeFull range
Impedance (Ω)8
Loudspeaker diameter (mm)115.0
Diaphragm typePolyethylene
Diaphragm typeAluminium
Efficiency / Sensitivity (dB)86.0
Max Linear Excursion (Xmax) (mm)2.5
Lowest frequency (Hz)65
Highest frequency (Hz)40000
The Tang Band W4-2414 full-range speaker delivers a wide sound reproduction thanks to its 11.5 cm diameter diaphragm. It has a power handling...
