TANG BAND W4-2417 Speaker Driver Full Range
The Tang Band W4-2417 full-range speaker delivers a wide sound reproduction thanks to its 11.5 cm diameter diaphragm. It has a power handling capacity of 25W, an aluminium and polypropylene cone, and a Santoprene surround, ensuring excellent performance.
Reference : 21789
76,90 €tax incl.
64,08 € tax excl.
Shipping date: 11-11-2026.
Tang Band W4-2417 Speaker Driver Full Range 25W 8Ω 86dB 65Hz-40kHz Ø11.5cm
TANG BAND W4-2417 : Front view
TANG BAND W4-2417 : Dimensions and frequency response
Product typeFull-range speaker
Nominal diameterØ115mm
Power ratingRMS : 25W
Max : 50W
Impedance8Ω
Frequency response65Hz - 40kHz
Sensitivity86dB
Voice coil diameter25.4 mm
Thiele & Small parameters
Resonance frequency (fS)65Hz
DC resistance (RE)6.3Ω
Electrical quality coefficient (QES)0.52
Mechanical quality coefficient (QMS)2.87
Total quality coefficient (QTS)0.44
Equivalent volume (VAS)4.56L
Maximum impedance (Zmax)40Ω
Voice coil inductance (LE)0.032mH
Force factor (B·l)5.36T·m
Moving mass (MMD)5.56g
Effective piston area (SD)0.0057 m²
Effective piston diameter988 µm/N
Maximum linear peak (Xmax)2.5mm
Materials
Diaphragm materialAluminium + PP
Surround materialSantoprene
Magnet materialFerrite
PackageSold by unit
Speaker Power (W RMS)25.0
Speaker TypeFull range
Impedance (Ω)8
Loudspeaker diameter (mm)115.0
Diaphragm typeAluminium
Diaphragm typePolyethylene
Efficiency / Sensitivity (dB)86.0
Max Linear Excursion (Xmax) (mm)2.5
Lowest frequency (Hz)65
Highest frequency (Hz)40000
TANG BAND W4-2417 Speaker Driver Full Range 25W 8Ω 86dB 65Hz-40kHz Ø11.5cm
The Tang Band W4-2417 full-range speaker delivers a wide sound reproduction thanks to its 11.5 cm diameter diaphragm. It has a power handling...
