TECTONIC BMR TEBM35C10-4 Speaker Driver Full Range 10W 4 Ohm 80dB 100Hz - 20kHz Ø 5.2cm
Tectonic's BMR range consists of full range loudspeakers designed to cover a very large part of the audible audio spectrum. Thus, the TEBM35C10-4 has an extended frequency response from 100Hz to 20kHz and a wide directivity.
3.5 / 5
Reference : 13586
14,90 €tax incl.
12,42 € tax excl.
Shipping date: 01-07-2025.
TECTONIC BMR TEBM35C10-4 Haut-Parleur Large Bande 10W 4 Ohm 100Hz - 20kHz Ø 5.2cm
Tectonic's BMR range consists of full range loudspeakers designed to cover a very large part of the audible audio spectrum. Thus, the TEBM35C10-4 has an extended frequency response from 100Hz to 20kHz and a wide directivity. In addition, Tectonic combines flexible wave technology and piston operation to ensure high audio performance despite a very small speaker format.
Dimensions
Product typeFull range speaker
PowerRMS : 10W
Max : 20W
Impedance4 Ohm
Frequency response100Hz - 20kHz
Sensitivity80dB 1W/1m
Depth25.1mm
Diameter54mm
Weight51.3g
Thiele-Small Parameters
ParameterDescriptionMin.Typ.Max.Unit
ReDC Resistance-10%4.2+10%Ohm
LeInductance (@ 10kHz)-0.05-mH
BLForce factor-2.03-Tm
FsResonant frequency-20%145+20%Hz
SPLSound pressure level @ 1W, 1m-80-Db
dDrvCoil diameter-20.4-mm
MmsMoving mass-10%1.11+10%g
CmsCompliance-10%1.04+10%mmN-1
RmsSurround mechanical resistance-0.27-Nsm-1
XmaxMax linear excursion-2.5-mm
SdSurface area of cone-11.04-cm²
VasEquivalent compliance volume-0.18-L
QmsMechanical quality factor-3.84-
QesElectrical quality factor-1.06-
QtsTotal quality factor-0.83-
Material
Surround materialRubber
Frame materialPolymer
Magnet materialNeodymium
Mounting informations
External overall diameter5.18cm (2.04")
Cutout diameter4.29cm (1.69")
Depth2.49cm (0.98")
Bolt circle diameter4.83cm (1.9")
Number of mounting holes4
Optimum cabinet size
Sealed volume0.016 ft³
Sealed F3154Hz
Vented volume0.026 ft³
Vented F385Hz
Speaker Power (W RMS)10.0
Speaker TypeFull range
Impedance (Ω)4
Loudspeaker diameter (mm)52.0
Diaphragm typeN/A
Efficiency / Sensitivity (dB)80.0
Max Linear Excursion (Xmax) (mm)2.5
Lowest frequency (Hz)100
Highest frequency (Hz)20000
2 reviews
Rendu sonore moyen.
L'essai de ces HP est décevant. J'espérai un rendu audio bien meilleur au vu de la bande passante annoncée.
This review has been posted for TECTONIC BMR TEBM35C10-4 Speaker Driver Full Range 10W 4 Ohm 80dB 100Hz - 20kHz Ø 5.2cm
idéal pour mon kit son de modèle réduit , avion enverg 1600mm. légers, dimensions réduites, puissance juste ce qu'il faut et une bande passante conforme à mes attentes. dommage que le +et - n'est pas repéré, mais avec une pile on retrouve.
Tectonic's BMR range consists of full range loudspeakers designed to cover a very large part of the audible audio spectrum. Thus, the...
