IBASSO DC03 Headphone Amplifier DAC Adapter USB-C Hi-Res 2x CS43131 32bit 384kHz DSD256
The iBasso DC03, successor of the DC02, is largely based on the principle of the DC01, while making a modification to its conversion/amplification stage as well as to its output. As compact and powerful as ever, the DC03 is ideal to accompany a smartphone equipped with a USB-C output but without a 3.5mm jack. It will allow you to enjoy your music in very high quality, wherever you are!
4.6 / 5
Reference : 14776
54,90 €tax incl.
45,75 € tax excl.
iBasso DC03
iBasso DC03 Adaptateur Amplificateur Casque DAC 2x CS43131 32bit 384kHz DSD256
Dual DAC CS43131
Based on a pair of Cirrus Logic CS43131 digital-to-analog converters, the iBasso is capable of reading high-resolution files up to 32bit 384kHz PCM and DSD256. These chips also incorporate an amplification stage, providing low noise floor and low impedance for natural sound reproduction.
Amplification stage
The DC03 offers an output voltage of 2Vrms at 300Ω and 1.61Vrms at 32Ω. It delivers a power of 80mW at 32Ω, which is more than enough to accompany EMI with ease.
From smartphone to computer: USB UAC2.0 sound card function
The DC03 is equipped with a USB-C connector and uses the USB UAC2.0 reception standard. It is compatible with the vast majority of Android smartphones and tablets on the market. It is also capable of connecting to a computer running Mac OS or Windows using the high quality USB-C to USB-A adapter provided. This allows it to work exactly like a sound card, and in an extremely simple way since the system is Plug & Play.
Volume control per application
Windows 10 and Android 5.0 (or higher) support the UAC2.0 protocol by default. However, for compatibility reasons, Android smartphone manufacturers still use the SRC protocol on the audio output. When the DC03 is connected, the volume is set to maximum by default and the device's software algorithm is used to reduce the volume. While this method does reduce the volume, it does not reduce the noise threshold. So iBasso has developed a volume control application using the UAC2.0 protocol to allow hardware 64 step volume control while reducing the noise threshold and providing much better audio performance.
DAC
Conversion / amplification chips2x Cirrus Logic CS43131
InputUSB-C
OutputFemale Jack 3.5mm
Noise floor level< 0.9µV
Output voltage2Vrms @ 300Ω
1.61Vrms @ 32Ω
Power80mW @ 32Ω
SNR127dB
OutputJack 3.5mm
ColorSilver
11 reviews
Exellent
Rien à redire sur ce petit DAC, vraiment performant.
utilisé sur un Huawei P30 avec un casque Focal Celestee ou Pioneer HDJ 1000 et appli Qobuz, c'est une vraie installation audio haut de gamme embarquée.
Grosse dynamique, réserve de puissance impressionnante, je ne peux pas monter le volume à fond.
Aucun souffle, aucune saturation, le son est d'une clarté réjouissante. Je redécouvre la joie du casque filaire
Vous pouvez y aller les yeux fermés
This review has been posted for IBASSO DC03 Headphone Amplifier DAC Adapter USB-C Hi-Res 2x CS43131 32bit 384kHz DSD256
Excellent!
Très satisfait de cet article. Il est plus petit qu'on ne le pense mais semble très bien fait. Mon téléphone Android l'a reconnu immédiatement et je peux maintenant écouter mes fichiers audio HiRes sans aucun problème.
Je le recommande vivement !
Très bon dac compact et à prix contenu
Utilisé pour contourner la sortie jack défaillante de mon LG G7 qui est doté d'un excellent dac (ES 9018 quad dac avec des mesures excellentes sur audio science review), je ne suis pas déçu! Distortion inaudible, clarté, rondeur, le son tient tout à fait la comparaison avec le dac natif du LG, avec un peu plus de pêche et de fermeté.
Il pousse très bien sur des écouteurs ou des casques faciles (AKG240, ...) ou en sortie ligne, par contre à ne pas utiliser avec un casque plus lourd à driver (pas terrible avec mon Beyerdynamic DT770, qui nécessite pour bien marcher un ampli casque).
Le chaînon manquant
Lecture parfaite des FLAC ultraHD 24b/192KHz d' Amazon Music HD depuis mon PC portable HP Pavilion X360 sur ma chaîne Harman Kardon A401 + 3A Adagio infini
https://m.facebook.com/story.php?story_fbid=3780039658731403&id=100001762192840
Surprenant dans le bon sens du terme. Génial !
Un son puissant, je l'utilise principalement avec un intra Final Audio Heaven IV (16 ohm/116 db) et un casque Fostex TH 610 (25 ohm/98 db) Dans les deux cas le son est excellent. Avec le TH 610 pour une écoute normale le réglage du volume est à peu près à 30% ce qui laisse une réserve de puissance très importante (encore plus importante avec le Final Audio). Dans les deux cas aucun bruit de fond et aucune distortion. Avec des fichier HIRES Qobuz le résultat est bluffant à tel point que je me demande si il y a un intérerêt à utiliser des produits beaucoup plus sofistiqués, encombrant et beaucoup plus chers...
Je suis conquis.
The iBasso DC03, successor of the DC02, is largely based on the principle of the DC01, while making a modification to its conversion/amplification...
