With its QX13, FiiO offers us a relatively affordable portable DAC headphone amplifier based on quality components. Indeed, the QX13 is armed with an 8-channel ES9027PRO DAC chip, a USB XMOS-316 interface and no less than 6 AOPs. This chipset enables it to support high-definition sampling rates up to PCM 32bit 768kHz and DSD512, while offering up to 2x 900mW of output power under a 32-ohm load in desktop mode. In terms of inputs/outputs, the essentials are there, with a USB-C input and two headphone outputs: a 3.5mm jack/SPDIF headphone output and a balanced 4.4mm jack headphone output. The QX13 also boasts a robust carbon fiber body to limit external interference and regulate heat, and an attractive, scratch-resistant color display.
The FiiO QX13 is blessed with a high-performance ES9027PRO 8-channel DAC chip based on Hyperstream IV architecture, and an XMOS-316 USB interface. ES9312 regulators support the DAC chip with a specific focus on jitter reduction. This chipset gives the QX13 the ability to support high-resolution sampling rates up to PCM 32bit 768kHz and DSD512, allowing you to enjoy the best of your streaming platforms or favorite local files. Furthermore, the USB interface also offers support for 10-band equalization via the FiiO Control App.
FiiO has chosen to integrate 4 INA1620 AOPs and 2 OPA1612 AOPs to ensure non-interference between the different channels and to bring wide dynamics to the final sound rendering, whatever the impedance load.
The digital and analog parts are separated and isolated to limit interference and better manage heat dissipation. Each component is carefully selected to work in concert with its peers in the signal processing chain. The balanced architecture offers fine, clean signal processing for the most pleasing rendering at the QX13 output stage.
In desktop mode, the QX13 benefits from a considerable gain in power, enabling it to drive a wide range of headphones and IEMs. In fact, it can deliver up to 2x 900mW of power at 32 ohms. This makes it possible to drive headphones with impedances ranging from 16 to 350 ohms.
The QX13 features a 1.99-inch tempered glass color screen for easy viewing and configuration. Several UI interfaces are also available for complete customization.
| 1 | Switch mode desktop |
| 2 | USB-C audio input / Power supply |
| 3 | Volume control - |
| 4 | Play/Pause |
| 5 | Volume control + |
| 6 | USB-C power port |
| 7 | Tempered glass color display |
| 8 | balanced 4.4mm jack headphone output |
| 9 | 3.5mm jack headphone output/SPDIF |
| Specifications | |
| Product type | DAC amplificateur casque portable |
| DAC chip | ES9027PRO |
| USB interface | XMOS XU-316 |
| OPA | 2x OPA1612 |
| Hadphone amplifier OPA | 4x INA1620 |
| Input | 1x USB-C |
| Outputs | 1x 3.5mm jack headphone output/SPDIF 1x Balanced 4.4mm headphone output |
| Suppoted sample rates | USB DAC: PCM 32bit 768kHz, DSD512, MQA Coaxial output: 24bit 96kHz |
| EQ adjustment | 10-band dynamic EQ control (±12dB) 8 built-in preset EQ styles User-defined EQ support |
| Screen rotation | |
| Recommended headphone impedance | 8~350Ω |
| Gain | Low/High (Desktop mode) |
| FiiO Control App compatibility | |
| USB UAC1.0 compatibility (Switch, PS5, etc.) | |
| Headphone output performance and settings (3.5 mm output, USB decoding, desktop mode, high gain) | |
| Output power | L+R≥440mW+440mW (16Ω, THD+N<1%) L+R≥310mW+310mW (32Ω, THD+N<1%) L+R≥40mW+40mW (300Ω, THD+N<1%) |
| SNR | ≥124dB (A-weighted) |
| Frequency response | 20Hz~90kHz: attenuation<2.8dB 20Hz~20KHz: attenuation<0.07dB |
| Output impedance | <1Ω |
| Crosstalk | ≥ 77dB |
| Peak output voltage | 9.8Vp-p |
| THD+N | <0.0004% (1kHz/-2dB@32Ω) |
| Noise floor | <2uV (A-weighted) |
| Headphone output performance and settings (4.4 mm output, USB decoding, desktop mode, high gain) | |
| Output power | L+R≥480mW+480mW (16Ω, THD+N<1%) L+R≥900mW+900mW (32Ω, THD+N<1%) L+R≥125mW+125mW (300Ω, THD+N<1%) |
| Frequency response | 20Hz~70kHz: attenuation<2.8dB 20Hz~20KHz: attenuation<0.07dB |
| Output impedance | <1.5Ω |
| Crosstalk | ≥113dB |
| Peak output voltage | 17.5Vp-p |
| THD+N | <0.0006% (1kHz/-8dB@32Ω) |
| Noise floor | <3.4uV (A-weighted) |
| Headphone output performance and settings (3.5 mm output, USB decoding, non-desktop mode, high gain) | |
| Output power | L+R≥370mW+370mW (16Ω, THD+N<1%) L+R≥250mW+250mW (32Ω, THD+N<1%) L+R≥30mW+30mW (300Ω, THD+N<1%) |
| SNR | ≥123dB (A-weighted) |
| Crosstalk | ≥75dB |
| Peak output voltage | 8.7Vp-p |
| Headphone output performance and settings (4.4 mm output, USB decoding, non-desktop mode, high gain) | |
| Output power | L+R≥470mW+470mW (16Ω, THD+N<1%) L+R≥605mW+605mW (32Ω, THD+N<1%) L+R≥70mW+70mW (300Ω, THD+N<1%) |
| SNR | ≥122dB (A-weighted) |
| Peak output voltage | 13Vp-p |
| THD+N | <0.0006% (1kHz/-6dB@32Ω) |
| Noise floor | <3.5uV (A-weighted) |
| General | |
| Power supply | 5V 1A |
| Dimensions | 64.2x30.7x13 mm |
| Weight | 39.2g |
| Color | Carbon fiber black |
| Package | 1x DAC Portable headphone amplifier 1x USB-C to USB-C cable 1x Leather case with magnetic attachment |
| Input | USB |
| Output | Jack 4.4mm |
| Output | Coaxial SPDIF |
| Output | Jack 3.5mm |
| DAC / ADC Chip | ES9027PRO |
| Max sampling rate | MQA |
| Color | Black |
| Class | Class D / T |
| Networking | No |
| Remote Control | No |
