MUSE HIFI M3 ULTRA Portable DAC Headphone Tube Amplifier
The Muse HiFi M3 Ultra is a portable DAC with a hybrid architecture designed to handle both digital conversion and analogue amplification in a compact form factor. It supports up to PCM 32bit 384kHz and DSD256, relying on an ES9028Q2M chip paired with a fully balanced circuit to ensure accurate reproduction while minimising interference and distortion.
Reference : 22066
109,00 €tax incl.
90,83 € tax excl.
Shipping date: 26-11-2026.
Muse HiFi M3 Ultra Portable DAC Headphone Tube Amplifier ES9028Q2M 32bit 384kHz DSD256
Muse HiFi M3 Ultra : Front view
Suited for both portable and desktop use, it combines high-resolution conversion with JAN6418 tube amplification, enabling effective drive of a wide range of headphones while maintaining stable operation.
Muse HiFi M3 Ultra : ES9028Q2M DAC Chip
The DAC is built around an ES9028Q2M chip, whose conversion architecture ensures precise digital signal processing while maintaining low distortion and noise floor. This technical foundation is extended by a fully balanced output circuit, effectively isolating parasitic interference and preserving channel integrity throughout the signal chain. Building on this, it supports high-resolution streams up to PCM 32bit 384kHz as well as DSD256.
Muse HiFi M3 Ultra : in use
Muse HiFi M3 Ultra : JAN6418 tube
Muse HiFi M3 Ultra : JAN6418 Tube Amplification
The integration of the JAN6418 tubes is complemented by a dedicated mechanical suspension system, relying on specific damping components and a decoupled architecture to limit vibrations transmitted to the circuit. This stabilisation reduces microphonic effects while maintaining consistent electrical conduction, resulting in more stable reproduction during portable use.
Product typeDAC / Headphone amplifier
Inputs1x USB-C
Outputs1x 3.5mm jack headphone output (single-ended)
1x 4.4mm jack headphone output (balanced)
Amplification componentsJAN6418 tubes
ES9603Q
DAC chipES9028Q2M
DSD up to DSD256
Output power480mW @ 32Ω
Total harmonic distortion (THD)0.0003%
USB interfaceSA9137L
ColourGrey
Package contents1x Muse HiFi M3 Ultra
1x USB-C to USB-C cable
1x USB-C to Lightning cable
OutputJack 4.4mm
OutputJack 3.5mm
DAC / ADC ChipES9038Q2M
Max sampling rateDSD256
Max sampling rate384kHz
ColorGray
ClassTube amp
MUSE HIFI M3 ULTRA Portable DAC Headphone Tube Amplifier ES9028Q2M 32bit 384kHz DSD256
The Muse HiFi M3 Ultra is a portable DAC with a hybrid architecture designed to handle both digital conversion and analogue amplification in a...
