patrice f.
Soundcare standard
Dimitrios K.
Neotech usb cable
Pierre H.
Condo Mundorf 22000µF/63V
Kevin I.
Kevin
I m very pleased with the cable and it a lot better sounds better than my Nordest flatline 2 cables I was running. I have it tri wired on my Mordaunt Short 880 performance speakers driven by a Plinius SA100 MK2.
MOST IMPORTANT is that you raise the cable off the floor. I used card board toilet roll inners on end to support it and it made anoticable difference and the sound really opened up.
I live in New Zealand and paid extra to have TNT couriers deliver it and they promised delivery every day for a week. I would not recommend using them for delivery. Overall very happy with the cable. Thanks
Zoltan B.
Perfect value for money. Great sound with beyerdynamic dt770 pro.
DIPRIZIO G.
Excellent timbre, seductive musicality and perfect MQA functionality.
Excellent DAC with a resounding quality/price ratio. You can also argue about the tonal and musical performance, but whoever shuts it down by declaring that it is not up to the declared things has....... few ideas and even confused and MQA coding has understood very little!
Ludovic Q.
Très bon produit rapport qualité/prix nickel. Utilisé pour des panneaux acoustiques le tissu est légèrement extensible ce qui permet de le tendre sans trop forcer. Résultat impeccable sur mon installation. De plus envoi rapide, je recommande !
Tony M.
Point négatif: Gaine trop dure et bruyante au frottement.
A l'avenir on y ajouter une gaine coton ou autre qui permettra de réduire cela...
Un peu dommage que ce point ne soit pas réglé d'usine.
Philippe F.
TINYSINE TSA9840B Class D Stereo Amplifier Module MAX98400A Bluetooth aptX TWS 2x20W 8 Ohm The TinySine TSA9840B is a small Class D amplifier module, based on a MAX98400A amplifier chip, delivering 2x20W power. This module can then be used to power two 8Ω passive...
Très bon produit.
Parfaitement adapté à la réalisation d'enceintes Bluetooth. Les 2x20w sont bien réels.
Evseicikas R.
DAC
Great quality, everything I needed for my needs, works flawlessly, I use the player Audirvana.
jean noel V.
Enceinte bluetooth
Très bon produit cela fait deux fois que je m'en sert pour fabrication d'une enceinte bluetooth dans un poste ancien... Bonne puissance clarté du son et simple à monter soi même. Très bon kit
Tony M.
YARBO SP-8SWT Silver Plated Copper Headphone Cable PTFE Ø3.5mm The top-of-the-range Yarbo SP-8SWT cable consists of 8 conductors of 0.9mm (with sheath) in diameter braided and independently insulated with PTFE sheath. The conductors are...
Bien mais...
Alors je n'ai pas beaucoup de câbles différents pour faire un vrai comparatif, en revanche, celui-ci a été utilisé pour confectionner un câble symetrique pour mon casque Audeze LCD-X, dc séparé la tresse de 8x pour faire deux de 4x pour aller aux différents écouteurs...
Pour écoute sur Fiio M11 ou Topping A90 dc avec jack 4.4mm.
Il y a biensûr clairement une différence en sortie symétrique de ses deux appareils, n'ayant pas la même configuration pour le câble donné avec le casque (ca viendra), je ne peut trop m'avancer.
Mais on sent tout de même une amélioration des détails dans le son, plus de clareté...
Mais point négatif, le bruit que fait le câble au frottement, dommage que la gaine soit si rigide..., cela demande de crée un Y un peu plus prononcé pour éviter ses bruits qui se transmette facilement au casque, surtout pour les open back.
Facile à utiliser
Soudeur du dimanche comme moi, allez y les yeux fermés.
Belle finition pour le prix
Rien à dire, fait le boulot comme on dit, c'est peut-être pas la qualité de WBT mais c'est 4 fois moins cher
Exellent RQP
Apres quelques heures de mise en place , ce câble a apporté un certain équilibre a la restitution avec surtout une meilleure micro dynamique et donc une présence plus immersive du rendu sonore.
Placé entre le switch et le streamer.
GB
Christian L.
Christian
Surpris par la qualité de la restitution sonore dans l’espace
Philippe V.
Philippe V.
DAYTON AUDIO RS225P-8A Reference Series Speaker Driver Woofer / Midbass 70W 8 Ohm 88dB 30Hz - 7000Hz Ø20.3cm The Dayton Audio RS225P-8A is a 20.3cm diameter bass speaker, belonging to the Reference Seriesrange. This range has the particularity of offering membranes combining natural...
Du solide
Fonctionne bien, il est encore en rodage, il n'exprime pas encore les basses attendues
Philippe V.
Fonctionne très bien
guilaume h.
ARDUINO MICRO Microcontroller Board ATmega32U4 Micro USB I/O 20 Pins The Arduino Micro is a programming module based on an ATmega32U4 microcontroller chip, developed in collaboration with Adafruit. This module has 20 digital input/output pins (7...
nickel
rien a dire de plus :)
Cordon d'alimentation parfait.
Ce cordon est excellent pour le prix. Bien fabriqué, les prises n'ont aucun jeu et il complète parfaitement l'alimentation LPSU25. Que demander de plus ?
Très belle fabrication.
Cette alimentation linéaire vient compléter à merveille la carte Matrix élément H. L'alimentation ne chauffe pas, elle est totalement silencieuse. Elle apporte un surplus de de transparence et de fluidité à la liaison USB de la carte Matrix et ceci pour prix plus que raisonnable.
arnaud B.
Bon câble audio
ARNAUD
Bruno G.
Dans ma configuration, ce petit objet améliore sensiblement le résultat. En ce qui me concerne, le meilleur résultat a été obtenu en plaçant un ac ipurifier en début de l'excellente barette achetée également sur ce site sur laquelle sont branchés les autres appareils hormis l'ampli. Celui-ci est branché sur une double prise avec un autre ac ipurifier. La qualité de l'image et du son de la TV est également améliorée.
Bruno G.
Multiprise de très bonne qualité. L'apport est flagrant par rapport à une multiprise de grande surface et justifie son tarif raisonnable.
Pierre-Marin L.
Vraiment excellent
Je rejoins la liste des satisfaits par ces mogami !!!
Petite particularité suite à un achat d'un Audioquest carbon en usb mon système était devenu trop précis et un peu fatiguant au niveau analytique, j'avais des qed signature révélation, avec le mogami on gagne beaucoup dans les basses et medium mais j'ai tenté avec les 2 et c'est sublime les qualités des 2 s'additionnent !!! Plus la moindre fatigue auditive et un son beaucoup plus riche en harmoniques tout en restant précis : je suis ravi (ce sont les commentaires de ce fils qui m'ont donné l'idée de bicabler merci à eux !!!) Système : Quellis 1 Optima // Qed Signature révélation && Mogami 3103 // BC 362 D // Sommercable Epilogue // Audio GD Master 7 Singularity // Ifi Ipurifier usb // Audioquest Carbon usb // MacBook Pro Audirvana // Ifi Ipurifier AC // Nordost red dawn
Ioannis P.
Makes a difference!
Connected to power cable feeding preamp. Still burning in, but I can perceive the noise floor drop already.
Goetz S.
TOP SERVICE
The description started with reference to output GX 12. This was wrong. It is actually a GX 16 output. The error has now been corrected. Due to the wrong description, I ordered high-quality GX 12 to DC 5.5 / 2.5 cables from another company, which logically did not fit.
The service that followed was really outstanding.
I was able to send the power supply back (with my cables), the outputs were adapted to my cables, tested and sent back to me.
Shipping there and back was completely free. First class service and thank you for that.
The power supply itself is great and does what it should.
Bruno F.
APD85 Amplifier Module Mono LM3886 100W / 8 Ohms This small amplifier module of 100w mono bipolar produces a dynamic and detailed sound. It is ideal for designing active speakers or powerful and affordable amplifier blocks....
Bon produit, mais 0 étoile pour Audiophonics
Le module fonctionne bien, mais montage = galère. Aucune instruction fournie. Le radiateur suggéré par Audiophonics n'est pas percé. Je l'ai fait, mais ce n'est pas pratique de percer droit entre les ailettes. Les petites feuilles en plastique semblent conçues pour isoler électriquement le module du radiateur tout en permettant le passage de la chaleur, mais en l'absence d'instructions, je ne sais pas. En tout cas, j'ai grillé un module suite à un fil de masse baladeur qui est venu toucher intempestivement le radiateur. Par ailleurs, le schéma électronique fourni sur le site est faux, c'est celui du module 150W avec 3 LM3886. Celui-ci n'en comporte que deux. Enfin, j'ai acheté un transfo 2x24V recommandé par Audiophonics, mais il n'est indiqué nulle part que celui-ci délivre bien +36V /-36V continu après redressement. Heureusement, c'est bien le cas.
Stephane T.
Très beau
très bon rapport qualité prix, il est magnifique
Ralph D.
Conforme et efficace
Fonctionne parfaitement avec mon harmony 350 et me permet de contrôler ma freebox v6. Aucun temps de latence. Cela fait plus d'un mois d'utilisation pourvu que ça dure !
Ah et réponse rapide aux mails de la part d'Audiophonics, c'est appréciable...
Christophe V.
Ça marche!
S’en trop savoir ce que fait techniquement cette accessoire sur la barrette secteur,une chose est sur c’est que ça s’entend chez moi en mieux sur quasi tout les plans, clarté sur le médium/aiguë font un bond en avant, meilleur définition, les plans entre les instruments sont plus nette et le grave plus mesuré donc plus juste mais avec autant de profondeur. Il suffit de le retirer pour s’en rendre compte et le remettre très rapidement !! C’est assez incroyable !
Pierre Olivier C.
Une pure merveille
Je viens de commander ce Dac sur les conseils d’une connaissance qui l’a testé et trouvait que c’était l’un des meilleurs qu’il aie entendus, y compris face à des modèles beaucoup plus chers...
Pour ma part il remplace un Dac valant le double qui me donnait beaucoup de satisfaction mais là je dois avouer que cet audio gd est carrément supérieur ! Il ne tourne chez moi que depuis 2 jours mais à chaque album qui défile c’est un enchantement, un émerveillement .
Je croyais avoir déjà re-découvert une bonne partie de mes albums mais je les re- découvre une nouvelle fois et à un cran tellement supérieur... tout est là, juste comme il le faut: détail, immersion sonore, clarté, spatialisation, présence du grave, richesse des micro informations, silence de fonctionnement et j’en passe... et pour deux fois moins cher que mon ancien Dac qui n’avait pas deux ans...
Je remercie audio gd de créer de si beaux et bons appareils à des prix accessibles, et je remercie audiophonics de nous les rendre accessibles, par ailleurs ils sont très serviables et réactifs il convient de le préciser.
C’est mon troisième appareil de cette marque, après deux amplis de puissance. À chaque fois cette impression de sérieux rien qu’au déballage du carton, quant à l écoute n’en parlons pas...
Je suis comblé et profite enfin de toutes les capacités de mes enceintes (b&w 802), j’entends enfin le son que je cherchais de puis si longtemps.
Si je pouvais mettre plus de 5 étoiles je le ferais !
Frederic S.
Rodage impératif
Pas moins de 200 heures de rodage avant que ce préampli ne se dévoile pour délivrer un son plein et chaud mais ne manquant pas de punch et de ciselé. Construction solide et belle finition. Un grand merci à David Aubert pour ces conseils avisés.
Patrick d.
Warm smooth detailed and wel placed sound
Ordered this one ... V2 DAC ES9023 TCXO, but got the TDA1387 instead and oh am I happy. Thanks to this DAC and my Audiotronics LR-2500 X (1972) and HECO speakers, the sound in my workshop is way better than in my living room ... the warm smooth detailed and wel placed sound supprised me.
François C.
Conforme à la description.
Malgré l'envoi d'un autre modèle, Audiophonics m'a renvoyé les bons modèles sans souci. C'est bien conforme à la description.
François C.
Efficace et très discret
C'est tout petit, ça fait le job et ça s'intègre parfaitement sous mes enceintes Triangle en remplacement des pièces de 2 centimes d'euros... J'ai donc au passage pu libérer mon capital de 8 centimes immobilisé depuis des années sous mes enceintes !
Sylvain R.
Impressionnant pour le prix et la taille !
Un son puissant, chaleureux et très détaillé, aucun souffle, un régal pour les oreilles ! Il a transfiguré littéralement le son de mon smartphone en toute discrétion et il ne chauffe quasiment pas, un véritable exploit vu son faible poids et ses dimensions plus que réduites ! Grâce à lui, je peux enfin profiter de la qualités de mes intras et de la HiRes de Qobuz sur mon smartphone
Patrick M.
Carrément parfait !
J'en ai commandé 9 ... mais pour une utilisation particulière : Recouvrir des panneaux acoustiques pour le traitement d'un home studio ... Elastiques à souhait, aucun plis sur les panneaux et sur un fond blanc, les panneaux sont magnifiques.
Gregory K.
Cable de sphère haut niveua
J'ai acheté le câble pour me fabriquer un cordon d'écouteurs.
Le câble a deux fils pour le plus et le moins.
Donc, si vous voulez faire un canal où vous voulez faire deux mètres de long, il vous faut 4 mètres au total et les couper ensuite en deux.
Pour la soudure, j'ai utilisé la soudure à l'argent Viablue et j'ai pris les fiches mono du Denon D7200 pour connecter les haut-parleurs et j'ai soudé une fiche XLR à 4 broches à l'amplificateur du casque.
Vous pouvez également y souder une XLR 3 broches ou 6,3 mm. Il vous suffit alors de connecter la ligne moins au connecteur 6,3 au niveau du Xlr 3 broches jeu sais pas.
Si le câble est bon ? oui, non seulement au niveau de la fabrication mais aussi au niveau du son après environ 100h d'utilisation, vous pouvez sentir la scène se lever comme si le soleil se levait. les basses sont un peu plus rondes et plus profondes et gagnent dans les moyennes et hautes fréquences.
Pour le prix et le fait que vous ayez travaillé proprement, c'est un très bon câble.
J'ai reconstruit tous mes écouteurs avec ce câble parce que j'ai gagné dans tous les domaines, j'étais étonné et sceptique au début, alors j'ai continué à en construire un nouveau, c'est effectivement le cas, chaque écouteur a visiblement gagné quelque chose, un super câble et chaque centime de valeur.
J'achète toujours un nouveau casque quand j'en ai besoin.
SA R.
FIIO M9 Digital Audio Player DAP 2x AK4490EN WiFi Bluetooth aptX-HD LDAC HWA Balanced 32bit 192kHz DSD128 Black The FiiO M9 is a complete, high-performance and ergonomic digital music player at an affordable price. Featuring high quality circuitry for rich and accurate sound reproduction...
FiiO support review
I am writing this review before even receiving the item. Every question I asked to support@fiio.com to receive technical clarifications prior to my purchase, has been fully and very timely answered. Very professional, and reason to buy FiiO products .
Congratulations to FiiO support team.
LUCIAN S.
Le câble est bien construit, semble solide et il est livré dans un sachet en tissu noir très élégant. Il remplit bien son rôle entre un lecteur cd Marantz et un amplificateur avec DAC intégré. Le rendu est neutre, je ne constate pas de changement évident par rapport à un autre câble coaxial 75Ohms no name, mais c'est peut-être dû à la qualité moyenne du DAC de l'ampli Cambridge. En tout cas les fiches Canare sont impressionnantes par rapport aux RCA qu'on met d'habitude sur ce type de connecteur. Je sais, coaxial numérique en RCA c'est pas le top , mais je n'ai pas de vrais 'AES/EBU, ni sur le lecteur, ni sur le DAC. C'est réservé au monde professionnel et au très haut de gamme, apparemment.
Nico V.
Natural opamp
An improvement... The Muses02 is much more natural and dynamic than the stock LME49720. This original is a nice opamp for its price but if you pay ten times more for the Muses02, you want get 10 times more music. NO... the change to the Muses is ok if you like more the natural sound of music. Even if you watch a movie the voices are there like they should, and sub is more controlled. A serious upgrade. Regards
Michel G.
Super upgrade
Pour quelques euros, on a un dispositif qui facilite grandement la vie pour écouter sa musique en streaming.
En aptx, même si ce n'est pas de la HiFi, le SMSL se défend bien.
Son fonctionnement sur batterie est un plus.
Chaudement recommandé.
surprenant !
chez moi et comparé à de nombreux câbles de même tarif l image n est plus bien centrée entre les enceintes .
pourquoi ? je ne serais l expliquer. de plus le medium est vraiment exacerbé .
bref vous l aurez comprit ce câble n est pas pour moi .
pour un prix moindre il y à bien mieux au catalogue audiophonics .
SOMMERCABLE MERIDIAN SP215 Speaker Cable OFC Copper 2x1.5mm² Ø6.8mm This robust cable is specially designed for connecting speakers and technically meets all the requirements. Its copper cores with low oxygen content ensure excellent acoustic...
rien d autre !
j ai passé des jours , des mois , des années à travailler l acoustique d une pièce de mon sous-sol , mon système par rapport à l origine y a gagné x 100. de faîte aû fil du temps le câble à eu de moins en moins d impacte sur le rendu sonor , au point que ce petit câble et dans mes conditions d écoute est tout simplement fantastique !
ce qui donne sa personnalité à votre système est votre acoustique et rien d autre alors arretez de gaspiller votre argent en Grigris inutiles.
Michel G.
Bon en cable d'alimentation.
Acheter pour faire un cable d'alimentation à mon ampli, il est aussi bon que mon siltec et bien meilleur ques d'autre cables blindé qui poussaient les aigus de mes proac.
Il est rigide mais il garde la forme qu'on lui donne, donc maniable.
joseph s.
mon achat
commander et vous êtes livrés ...
j'ai installé les ampoules et c'est super
à bientot pour un autre achat
thierry G.
Bon petit ampli 2 voies+caisson
Résultats d'écoute très satisfaisant pour un système auxiliaire (bureau), la voie grave active est facile à régler, même si un réglage de la fréquence de coupure aurait été un plus. La liaison Bluetooth ne pose pas de problème particulier. Non testé en filaire, mais déjà en sans fil c'est plus que correct. Vu le tarif, il n'y a pas photo, le rapport qualité/prix est excellent. Bonne spatialisation, pas d'agressivité, très bonne restitution des détails. Utilisé avec un caisson passif très bas de gamme, et pourtant l'ensemble est très agréable à l'écoute. Livraison très rapide , parfait.
Peter F.
Quality of the product 5 stars quality of the packaging no stars
Overall satisfied. The product is nicely build and the sound quality is super. However the product was put in a big carton box (not a product box) with a lot of random filling (carton, foam, plastic) it could easily have been damaged. No user manual or anything. The rubber absorbing rings for the feet (I almost throw them away with the filling) and power cord were thrown unwrapped and unprotected in the box. Just a little more attention to the wrapping and packaging would increase the excitement and trust over the product enormously. But again once connected and listening to the Music all worries and concerns are soon forgotten and the happy feeling remains.
Vito F.
les borniers ne tournent pas quand on serre, la soudure est facile
Fabien S.
SMSL M300 MKII DAC AKM AK4497 XMOS 32bit 768kHz DSD512 Bluetooth 5.0 Apt-X Black The SMSL M300 MKII is a powerful and compact DAC in an atypical format, now with a Bluetooth 5.0 connection. Integrating high quality components, it is the perfect ally to offer...
Très bonne facture
Bonjour, ce Dac vaut bien un audio gd trois fois plus cher. Bonne dynamique et nécessite un rodage de 48 h. Meilleur rapport qualité prix et puce AKM. Pas de fonctions redondantes, mon système est bien optimisé avec ce Dac qui a bien progressé depuis sa première version. Très satisfait !
Deon G.
AUDIOPHONICS LPSU100 Stabilized Power supply 24V 4A 100W for FDA Amplifier The Audiophonics team is proud to be able to offer you a regulated linear power supply to properly supply your FDA amplifier.
Excellent power supply
Using it with Rupert Neve headphone amp.. much much quieter and music is more enjoyable. Great job!
