Rémi D.
N'hésitez pas
Antony C.
Best rapport Qualité/Prix !
Laurent C.
Une référence
Kai-M. L.
TinySine TSA1701
I ordered 2 TinySine DSP boards TSA1701 on May 27, 2024.
Only after the order I noticed that no units were in stock.
The parcel was finally delivered on June 18, 2024, i.e. after 22 days.
The price seems ok.
Unit price was 22,71 € at the day of order,
Including shipping to Germany this resulted in 25,75 € per board.
List price at TinySine is 21,20 USD (=19,93 € on June 21, 2024).
For 2 boards shipping cost are estimated as 8 $, resulting in a unit price of 25,20 $.
For an order of 2 the German distributor charges 37 € per unit.
Matthieu G.
HUMMINGURU HG01 Ultrasonic Vinyl Cleaning Machine The HumminGuru vinyl cleaning machine is an ultrasonic cleaning machine. This machine provides a professional level of cleaning for your vinyl. It's intuitive, compact,...
Excellente solution pour le nettoyage des vinyles
Rien à dire. Machine compacte, silencieuse (pour une machine à ultrason), pratique. Les disques ressortent comme neuf et cela se ressent énormément au niveau de l’écoute. Prix un peu élevé, mais on reste en dessous de la plupart des autres systèmes existants.
Adam S.
Disapointing sound
Not worth the Money ,just a bad cable ,the sound was disapointing compared to the standard ptfe cable i have bought earlier from audiophonics
RENE R.
VIABLUE UFO Vibration Absorbers Ø35mm Black (Set x4) Viablue UFO absorbers can be used to dampen harmful vibrations by placing themselves under your speakers or HiFi devices. Due to their optimal pressure on the lower surfaces of...
Absorbeurs Viablue UFO
excellents sous une vieille platine Thorens td 160S.
J'en avais déjà acheté un jeu pour mettre sous TD 124 MK2.
RENE R.
1877PHONO EH
Bon produit cependant je n'ai mis que 3 étoiles car le diamètre est le meme que celui du disque ce qui fait que lorsque l'on change de 33 tours le couvre-plateau vient avec.
Donc il faut peut-etre mettre un scoth double-face?
Andrija K.
works great
everything works as described, using it to run BST-1 shaker and it works great
Georg O.
AUDIO-GD HE-1 MK3 Class-A Balanced Preamplifier ACSS XLR RCA Silver Audio-GD once again presents the quintessence of audio technology with its HE series products (here the HE-1 MK3), an evolution of the MASTER series. They have benefited from...
Mein bester Vorverstärker
Ein ganz herausragend gutes Gerät. Meine klassische Musik auf CDs hatte noch nie einen besseren Klang, obwohl ich bereits 12 andere sehr renommierte Geräte hatte ! Der Klang zeichnet sich durch eine besondere Präzision, Dynamik, Detailfreudigkeit und angenehmer Wärme aus! Ein ganz seltener Hochgenuss!
FURUTECH DAS-4.1 Balanced Interconnect Cable OCC DUCC Copper Ø10mm This Furutech DAS-4.1 balanced interconnect cable offers an absolutely outstanding design quality that will allow you to design your own high-end audio cables. It features two...
Attention Ovni i!!!
Ce câble, est venu en remplacement, du Furutech FA-aS22, chez moi il s'agit d'un câble Hybride RCA FURUTECH CF-102 NCF, et OYAIDE FOCUS 1 Connecteurs XLR Mâle. Ce câble, est a l'image de cette game HDG FURUTECH, au bout d'une semaine : beaucoup de transparence, de véracité des timbres, de finesse, de profondeur, de maitrise, est de lisibilité, d'une définition très poussée ,mais naturelle. Le seul bémol, est qu'il va être très long à roder (le câble secteur FURUTECH DPS 4.1 avait mis environ 500 Heures, pour arriver à Maturité) et son prix relativement élevé, mais je pense que cela en vaut la peine.( Il ya de très bonnes vidéos en ligne, pour le montage des câbles FURUTECH DPS 4.1, sous toutes leurs formes, faites par Furutech).
J-Paul R.
Excellent petit DAC auto-alimenté
Fonctionne parfaitement. Sert à relier un MacBook Air M1 à un ampli casque Micromega Myzic.
Werner H.
the best chinch sockets
***** these jacks show you how high quality cables Audience Au24 SX can sound *****
Harry H.
the best for the buck
The only affordable pure silver contacts XLR connectors.
Use them with the Neotech Nemoi rectangular UP-OCC silver IC and that is a very good combination
Harry H.
second buy for friend
This cable was so impressive in my friends set up (Macintosh pre/power amps, kef reference speakers and pink faun streamer/DAC, Yeti power conditioner and power cords, Timber XLR interlinks) when I took it to him to try the he said make one for me too. That,s why I ordered the cable again and the Viborg pure silver XLR plugs.
SUPER
Philippe L.
MOONDROP SPACE TRAVEL Dynamic True Wireless In-Ear Monitor IEM 20Hz - 20kHz Black Moondrop Space Travel wireless earphones feature a dynamic 13 mm titanium composite dome transducer in each earcup. These wireless earphones benefit from a Bluetooth 5.3 module...
Qualité/Prix imbattable
Des écouteurs avec du son! Un poil lent dans les commandes
Une étoile perdue en raison d’une app Moondrop Link “momentanément” absente du AppleStore et une fonction EQ à telecharger ailleurs… ceci dit, peu voire pas d’équivalent IEM TWS sur le marché
Michel P.
Trés bon amortisseur de vibration
Utilisé sur un pré-ampli donne d'excellents résultats : basses plus sèches, son plus dynamique image stéréo plus stable, détails révélés. Pose facile avec un peu de précision et d'attention. Cependant nécessite de faire un essai préalable pour juger du résultat selon les appareils et l'emplacement de pose, selon ces critères j'ai obtenu des effets différent : lecteur réseau aucun impact, pré-ampli : sur le dessus (capot) très bien, sur le dessus une plaque interne + une plaque externe très très bien sur le dessus et dessous encore mieux, sur les cotés : négatif (son dur et agressif). Pour les essais j'ai retiré qu'une partie (par bandes) du film protecteur de la partie collante afin de faciliter le retrait; attention néanmoins si cette procédure donne une bonne indication des effets, lors de la pose totale il peut y avoir de légères différences.
SUPERBE ECOUTE !
Informé d'une nécessité de rodage avant un résultat optimum, j'ai été toutefois surpris d'obtenir immédiatement un excellent rendu, déjà supérieur à mon précédent Dac pourtant aussi R2R de qualité.
- La fabrication du Gustard R26 et la structure même des circuits internes et des composants retenus (ex: horloges), sont visiblement de la plus haute qualité.
J'ai attendu une dizaine de jours avec le Dac sous tension secteur permanente (et modulation en silence les nuits) afin de pouvoir donner un avis un minimum cohérent et crédible !
- Le son de la section Dac du Gustard R26 est tout simplement remarquable; à la fois précis, dynamique, très articulé et avec en prime un fruité de l'aigu comparable à celui d'excellents systèmes de lecture vinyle ce qui est extrêmement râre.
L'image sonore assez "panoramique" offre une belle profondeur 3D avec une agréable impression de présence réaliste des interprètes musiciens ou chanteurs.
L'écoute est d'emblée très supérieure musicalement au rendu de mes 9 ou 10 précédents Dacs.
- Son lecteur réseau intégré plus classique, bien que très correct n'a certes pas le caractère exceptionnel de la section Dac mais on doit considérer que proposer un Dac d'une telle qualité + un lecteur réseau très correct + une télécommande, + Bluetooth etc. pour un prix de 1599 € s'affiche comme un excellent rapport qualité/prix.
En conclusion: c'est probablement l'un des 3 ou 4 meilleurs Dacs actuellement disponibles sur le marché, dans une tranche allant jusqu'à env 3500 € !
Rien de moins ! !
Gilles R.
Fausse bonne impression
Celui-ci a une tendance certaine à accentuer le poids des notes d'un piano par exemple,au détriment des voix qui passent logiquement en second plan.Pas du tout emballé.
Djènè S.
Du très beau matériel
Équipé d'un dac teac ud 503 branché en rca esprit alpha à roksan k3 sur monitor audio silver 500 6G. Source tidal depuis pc. Je remplace le teac + pc par ce a26.
Gain léger en utilisant le gustard avec source pc en usb. Puis je passe en l'an avec le streamer interne avec source tidal sur bubble upnp. Et là le gain est incontestable. J'avais déjà un très bon son, bien optimisé, peaufiné pendant des années. Mais là je gagne sur tout. Scène un peu plus large, et clairement plus profonde. Silence un niveau au dessus et surtout micro informations et attaques un gros cran au dessus. Le son a bas volume conserve sa qualité et son dynamisme, avant je sentais qu'il fallait pousser un peu pour profiter du potentiel de mes HP de 20cm.
De nouveaux micro détails se révèlent de manière évidente. Le plus flagrant s'entend sur les percussions/batteries. Un solo de batterie complexe est maîtrisé sans aucune bavure et avec une finesse qui permet d'apprécier l'intention de chaque frappe même quand le batteur est surexcité. J'ai l'impression que ce a26 est capable de gérer tout ce qu'on lui envoie. Au point où j'ai l'impression qu'à présent c'est peut-être le reste du matériel qui mériterait de monter en gamme.
Esthétiquement rien d'incroyable mais c'est minimaliste et très bien construit, donc RAS. En terme de signature sonore, c'est dans la continuité de ce que j'avais avant (double akm) mais tous les curseurs sont clairement poussés en termes de performances. Un son neutre, défini, naturel sans excès, pas de chaleur superflue qui nuirait à la définition, pas de froideur particulière mais une maîtrise virtuose qui prend aux tripes si le reste de l'installation est cohérente.
Ps : je suis habitué à des écoutes sur de nombreux systèmes HDG (atoll, Mac, hegel...).
J'ai changé le câble secteur avec un furutech tcs31 avec viborg rhodium, gain évident sur les basses qui sont plus musclées et longueur de note sur les micro informations.
J'espère qu'il vous plaira.
Matthias E.
Happy it makes a great difference
I have a Chord mojo and a hifiberry dig+ pro. Before I was using a power bank, and there was a clear difference between coaxial and toslink, toslink sounded 3d but a little less decisive, and coaxial was more impactfull but 2d, now both inputs sound equally 3d, clearly there was some electrical noise coming through coaxial that affected the dac which by the way is not galvanically isolated and this psu solved the problem, I'm very happy with this result, in the future I plan on powering a Chord qutest and allo digione signature with this
Jean-Luc M.
Superbe DAC
Je possède également un DAC RME ACI2 (AKM 4493), le Cyan2 apporte une différence importante sur le rendu avec une écoute plus "analogique", un placement plus précis des instruments et des voix, et le registre des basses plus soutenu.
Il est associé à un préamp Lake People MC100 et des enceintes ATC 20 Pro Active.
Je l'utilise avec Roon et HQPlayer 5 en mode DSD direct upsampling DSD256 et il révèle alors tout son potentiel.
Il semble qu'il faille entre 4 à 500 h de rodage pour qu'il soit complétement au top.
Attention si vous avez plusieurs sources (USB, AES, coax, I2S), vous n'avez pas de sélecteur à votre disposition, il choisi la première activée, mais à tendance à privilégier l'USB (j'ai activé l'AES, mais il bascule quand même sur l'USB si j'active en second l'USB).
Service impeccable avec Audiophonics.
Achat très recommandé.
Si vous êtes intéressés, passez commande dès qu'il est de retour en stock, car cela part très vite....
Jacques T.
Pour un streamer Octavio
Je possède un streamer Octavio que j'utilise en simple transport réseau vers un DAC Heed Abacus (+ Ampli Heed Elixir et enceintes PEL Toscane). Le remplacement de l'alimentation d'origine par celle-ci est simplissime en utilisant la connexion USB A et le câble USB A - USB C fourni par Octavio. L'écoute via Qobuz montre une belle spatialisation précise et sans fatigue auditive ainsi qu'une meilleure musicalité, cette amélioration reste subtile mais suffisante pour accorder de l'intérêt à ce changement d'alimentation.
Il est à noter l'envoi soigné et extrêmement rapide du colis contenant cette alim mais il est vrai que j'habite à proximité du siège français de Audiophonics.
STEFANO M.
Good!
Good replacement for Behringer MS40 Tweeter, it is necessary to profile them one mm smaller in diameter (66mm these vs 65mm original MS40 Tweeter) they seem to sound very very good.
Jean O.
Jean O.
J’ai acheté cet ampli Purifi en remplacement d’un ampli Project Amp Box DS2. Ce dernier est équipé de modules Hypex UCD 180. Bien que fonctionnant tous deux en classe D et ayant la même origine, des différences audibles existent. Le Purifi a plus d’assise dans les basses et est moins montant dans les aigus que le project. Il est également plus transparent (microdétails) et plus naturel. Bref très bonne impression. Merci audiophonics.
Attention, le boitier est étroit mais profond. J’ai du utiliser un cable d’alimentation et des renvois RCA coudés pour qu’il rentre dans le meuble.
Patrick M.
GENALEX GOLD LION Tube 12AT7 / ECC81 / B739 Gold Pins (Unit) The high-end Genalex Gold Lion Gold Pins double triode tube unveils a wide sound stage, characterized by expressive midrange, deep and precise bass and generously developed treble.
Belle amélioration
Il remplace avantageusement une EH qui équipait mon ampli casque Canor tp10: aigu plus suave, médium plus souple et champ sonore mieux ressenti avec mon Grado PS500E.
Stephane N.
Spikes M4 Aluminum Rubber Ø31x21mm Silver (Unit) This decoupling tip is made of Aluminium. It is surrounded by a removable rubber ring. The combination of these two materials allows the absorption of different frequencies. The...
Très bon produit. Utilises sous un DAC ATOLL, il font le boulot !
jouri k.
this is it :)
Packaging and shipping were superb. I was really curious how these expensive clocks would hold up. They don't let down. Much better than the accusillicon. Treble/mid/bass took a giant leap.
Imaging way better :)
It is so good, so happy to have high-end sound in my living room.
jouri k.
IAN CANADA UCCONDITIONER PRO Ultra Capacitor Conditioner Board 5V The Ian Canada UcConditioner Pro 5V is a ultra capacitor signal conditioner module for use with a 5V power supply. It will significantly improve the quality of your power supply...
unexpected!
This power supply is a great upgrade. Also if you have the previous version. Which i have. Thus I was very sceptical about any noticeable upgrade. But this is a big one!
SERGE B.
Excellente qualité
Excellente fiche IEC qui vaut bien son prix. Permet de confectionner des câbles d'excellente qualité audio. Combinée à une prise Schuko ELECAUDIO PS-24RA et à un câble 3 X 1,5 blindé Elecaudio j'ai obtenu une différence de qualité nettement audible par rapport au câble d'origine. Surprenant mais la dépense valait la peine !
SERGE B.
Bonne prise IEC avec contacts en cuivre
SERGE B.
Excellente prise schuko coudée
Excellente conception et construction.
Parfaite pour fabriquer des câbles d'alimentation de qualité. Nettement supérieure aux prises BALS qui coûtent près de 5 fois moins. Mais la différence à l'écoute est stupéfiante...
Miutescu G.
AIYIMA T8 Tube Preamplifier 6N3 Headphone Amplifier MAX9722 DAC ES9018K2M Bluetooth 5.0 24bit 96kHz With the T8, Aiyima offers a versatile device that is a tube preamplifier, headphone amplifier and DAC at a very affordable price. Its preamplifier stage uses a 6N3 tube, which...
Perfect , but ...
It's really awesome preamp / dac . I use it in my P sistem - Dac Aiyima T8 and straight to my power amp Emotiva BasX A300 . Everything is beautiful, sound is excellent , but be aware that the output RCA is weak , like 1.9 V. So if you want more volume you really have to crank it up to allmost max volume from Dac . Except this thing, the preamp is really really good sounding and works like a charm
Patricio C.
Excelente!
Antes de probar este cable, estaba usando uno de Gustard (cable azul) y conectores Neutrik... fué poner el obsidian y el cambio fue brutal e instantáneo... ya no recuerdo si previamente lo dejé sonar por 20 horas a modo calentamiento..... pero fué como quitar un velo en la música, mucha mas transparencia, detalle y un sonido mas abierto sin ser brillante ni perder musicalidad o cuerpo en la zona grave... sin duda un excelente cable.
Alain M.
Protection modules for stereo speakers 12V 16A (Pair) This double mono protection module consisting of two cards will allow you to properly protect your speakers.
Problème de fonctionnement avec carte ampli SSD 3E Audio
J'étais assez content de découvrir ce module de protection qui permettait entre autre de simplifier la conception du boitier qui allait accueillir une carte ampli SSD 3E Audio et une alimentation SMPS Connex de 300W/36V.
une fois les connections réalisées je me suis aperçu qu'à la mise sous tension une petite diode rouge intitulée "Fault" s'allumait sur la carte 3E. Après investigation je me suis rendu compte qu’il ne faut pas alimenter ces 2 modules avec la même alimentation car de ce fait, les masses sont alors reliées. Ce problème n’existe probablement pas avec un amplificateur stéréo dont les masses des 2 canaux sont reliées notamment ceux faisant appel à des alimentations symétriques.
MUNDORF F71 Varnished Wire Ferrite Core Self 0.71mm 2.2mH The F-Series combines small size and low price, making it an excellent value for money for filtering woofers, or any other application requiring high inductance and/or low...
Très bien.
Belle qualité de self, livraison éclair.
Super.
J'utilise ces condensateurs en parallèle pour mes filtrages HP.
Bravo Audiophonics pour la livraison toujours express.
MUNDORF E-CAP ECAP100 (BR100) RAW Capacitor 100VDC 32VAC 22μF Mundorf E-Cap audio and signal coupling capacitors are bipolar electrolytic capacitors. They are used in applications where film capacitors are not suitable for space or cost...
Super.
J'utilise ces condensateurs en parallèle pour mes filtres HP.
Excellent.
Excellente self de filtrage, y compris pour montage en série.
Que ferait-on sans Audiophonics et sa livraison express ?
Excellent.
Excellent.
JANTZEN AUDIO 000-0837 4N Copper Air Core Wire Coil 20AWG 0.92mH The Jantzen Audio Air Core Wire Coil is made of a very pure copper wire, offering distortion-free inductance. It will therefore be suitable for all audio applications. The coil...
Excellent.
Jean-Pierre D.
Très bonne amélioration comparé à l’HPA-S400 ET
Utilisé avec un pré-ampli Gustard H26, doux et neutre avec deux lecteurs DAC, un Neo Alpha avec un ESS 9038 pro et un Lumin D2 avec un DAC Wolfson WM 8741, couplé à des enceintes colonnes Triangle Signature Delta. Je trouve, au fil des premières écoutes sur ces deux lecteurs, la restitution juste et naturelle, c’est à la fois neutre et musical. Les timbres des voix sont réalistes et pas accentués. En comparaison avec l’HPA-S400 ET, il y a une peu plus de puissance perceptible, les basses sont supérieures, pour le reste il y a davantage d’ouverture, de micro-détails (à ce niveau évident), cela reste la même signature sonore propre aux Purifi d’Audiophonic, neutre, musicale avec absence de toute agressivité dans le haut médium et l’aigu avec un profil plutôt doux.
J’avais hésité avec le modèle récent 750, le prix de celui-ci m’a décidé ainsi que le retour du conseil technique d’Audiophonic, ce modèle largement suffisant pour mon usage, notamment au regard de mon préampli actuel (pas mal, mais pas exceptionnel) et de mon espace d’écoute. Pour conclure, le 500 me semble plus intéressant que le 400 malgré un prix un peu plus élevé.
Rudy C.
Rapport qualité/prix imbattable !
Très correct pour le tarif pratiqué
Marc J.
Speaker Terminals 24k Gold Plated Ø19mm x 50mm (Pair) These speaker terminal blocks offer excellent design quality at an affordable price. Their contacts are made of 24k gold-plated copper alloy, ensuring...
Qualité correct...mais pas en cuivre !
Contrairement à ce qui est annoncé ces borniers sont en laiton, absolument pas en cuivre.
Qualité correct pour le prix néanmoins.
Claude P.
SMSL M300 SE DAC Headphone Amplifier 2x CS43131 XMOS Dual Clock NDK Bluetooth 5.0 32bit 768kHz DSD256 MQA The SMSL M300 is a powerful and compact DAC in an atypical format. Integrating high quality components, it is the perfect ally to offer your HiFi audio system a...
Facteur de forme pratique et mignon, fonctionne très bien et délivre un beau son riche et dynamique.
J'apprécie aussi le fait qu'il démarre tout seul dès que la tension d'alimentation (+5v) lui est appliquée et qu'il ne génère aucun cloc à cette occasion, ni à l'extinction d'ailleurs (très bien pour mes enceintes actives Adam Pro).
Par contre, l'extinction (programmable) et l'intensité (variable) de l'écran incorporé sont incohérentes, des fois ça marche, des fois non, et c'est d'autant plus énervant que j'ai deux exemplaires accolés qui ne réagissent absolument pas de la même manière,
Claude P.
SMSL B2 DAC Bluetooth 5.1 Receiver CS43131 QCC5125 aptX HD LDAC The SMSL B2 is a small, practical, affordable and efficient DAC and Bluetooth receiver. It's based on a CS43131 digital-to-analog conversion chip and a Qualcomm QCC5125...
Testé ce jour
Fonctionne bien après un appairage rapide et sans histoire mais mériterait d'avoir un réglage d'intensité sur l'écran et surtout est arrivé avec le port optique HS (Led rouge éteinte).
Ayant le choix entre optique et coax, j'ai heureusement pu prendre cette solution.
Petit défaut de contrôle en fin de chaine ??
Contactez mes collaborateurs du SAV via les formulaires du site, il est anormal que toutes les sorties ne soient pas fonctionnelles en sortie de boite.
Ils feront rapidement le nécessaire.
Igor M.
Cables
I'm really impressed with the price to performance ratio of this cable. If you are looking for open and airy sounding cable with really good bass definition this is the must try cable.
Dmitrijs R.
Simple, good sounding amp
The MOS-120 is a very nice amp, I like it a lot. Sounds quite warm, without substantial coloration - all as per my taste. The build quality is also great. I would recommend it to anyone, who searches for a very simple, compact, single input amplifier.
Louis M.
manque de definition et d'equilibre
de la puissance, du volume, mais quid de la definition et de la musique ?
pas de la hifi...
Louis M.
NEUTRIK NC3MX-BAG 3 Way Male XLR Connector Silver Plated Ø8mm (Unit) This 3-pin XLR male Neutrik NC3MX-BAG connector allows quick and easy assembly, consisting of only 4 pieces and no screws. It benefits from a compact design, a sturdy Zinc shell...
bonne prise
parfait contact, pas de defaut
Louis M.
neutre mmais...
l'appareil est solide et presente bien, il n'apporte pas de coloration
mais...le bouton est lisse et il ne se manoeuvre pas facilement tant il manque de grip...
Louis M.
tres bonne prise jack, fontionnement totalement neutre
