Mohammed B.
Im Vergleich zu Mundorf...
Mohammed B.
Mohammed B.
die
Roberto V.
Jack 3.5 mm high quality
High quality product, well built. The connections, when compared to cheaper jacks, ensure the sound quality. I like it.
Gérard K.
DD DJ44C Adapter Female Balanced Jack 4.4mm to Male Single-Ended Jack 3.5mm Gold Plated This adapter consists of a female balanced Jack 4.4mm connector and a male single-ended Jack 3.5mm connector.  It benefits from a very nice quality design with a robust CNC...
Cet adaptateur est conforme à sa description et de très bonne qualité.
Livraison rapide et sans problème.
Massimiliano G.
Rewarding purchase
I needed a new sub amplifier module since my previous one suddenly stopped working. After checking the options and the reviews on the internet I decided to take the Dayton SPA250. It arrived few days after placing the order and I am really satisfied of both the quality of the amp and the efficiency of Audiophonics staff. Right now I am running it in, but I can already appreciate its powerful and clean delivery.
Frank H.
Difficult to crimp
If you do a "square-crimping" f.e. with the tool Weidmüller PZ-3 it doesn´t stay´s on the cable, had to use another crimping systems to fix it on the cable!
Frank H.
Good one!
Very good in Quality and handling. In the meantime i´ve build three powercables with the CS-321B and would also use it for further Powercables :)
Frank H.
Good one!
Very good in Quality and handling. In the meantime i´ve build three powercables with the RI-24GB and would also use it for further Powercables :)
Frank H.
Good one!
Very good in Quality and handling. In the meantime i´ve build three powercables with the RS-24GB and would also use it for further Powercables :)
Gian Marco d.
Fantastico prodotto
Kit favoloso. Il prodotto implementato con Moode audio è semplicemente strepitoso. Velocità, reattività da ogni device di utilizzo, nonché la comodità di avere tutto a portata di mano (Nas, HD, Spotify/qobuz ecc) in un prodotto piccolissimo e molto bello. Il kit è egregiamente costruito. Il suono della scheda dac sabre è ottimo. Consigliatissimo. N1 audiophonics.
JF B.
Pratique et esthétique.
Facile à installer, soudures effectuées sans problème.
JF B.
Presque parfait
Ce petit ampli Bluetooth fonctionne étonnamment bien vu sa taille, le Bluetooth fonctionne jusqu'à 10 mètres environ.
Je n'ai pas mis 5 *, car sur celui que j'ai reçu il y une inversion de phase entre les 2 sorties.
Patrick M.
Amortir parois d'enceintes
Utilisé pour réduire les résonnances des panneaux latéraux pour enceintes jamo alto 90.Pas évident à poser mais ç'est réalisable.Ensuite au niveau de l'écoute on a l'impression d'une plus grande netteté du message sonore ainsi qu'une diminution de la distortion.Trés satisfait.
Patrick M.
cable haut parleur pro
Cable utilisé en doublant les conducteurs.Enfin un cable qui n'engendre pas l'ennui et qui pousse à redécouvrir nos oeuvres préférées.J'ai l'impression que les musiciens ont vraiment envie de jouer et de nous faire plaisir!
Cable neutre,équilibré et bande passante trés large.Il y a quelques années je faisais du son live et je retrouve les memes sensations et ce plaisir d écouter de la musique.C'est vif,dynamique mais sans etre agressif, les instruments sont respectés dans leur timbres, leurs couleurs,leurs résonnances propres et leurs dynamiques:on se croirait en direct!
Je suis étonné de redécouvrir un nouvel éclairage de plusieurs disques en bien.Un cable pour ceux qui aime le live.C'est la premiére fois que sur certains cds j'entends nettement la couleur des réverbs utilisées,idem pour l'acoustique des salles.Excellente largeur et profondeur du champ sonore.Par contre un cable qui demande beaucoup d'heure de rodage mais pour ma part il fonctionnait déjà trés bien dés le départ.
Patrick M.
Super lilliput dac!
Suite aux avis postés ici et aileurs je me suis laissé tenté par ce petit dac.En remplacement d'un behringer ultramatch pro de 2006.Ce que j'ai perdu en 24/96 je l'ai gagné et oh combien en homogénéité,en naturel,en timbres,en largeur de la bande passante, en précision et placement des interprétes .Large scéne stéreophonique ,effets de réverb(couleurs) et délais superbes,dynamique vrai sans agressivité.Son organique,analogique et qui a du poids sur mon systéme.Bref un petit dac au gros son!
Evgeny S.
Прекрасный источник питания.
Подключив этот источник я услышал свой DAC по новому. Я восхищен. Быстро подобрал адаптер для поключения его. Рекомендую.
Patrick M.
Beau cable usb
Acheté par erreur.No comment.
Patrick M.
Alim pour dac
Acheté conjointement avec le dac smsl 10 th mk2 pour tirer le maximum de ce petit bijou de dac.Pas eu le loisir d'ecouter avec ou sans une alim de ce nom mais ç'est certain une bonne alim change tout dans un systéme un tant soit peu transparent!
Une réalisation qui respire le sérieux et qui est abordable pour les audiophiles peu fortunés dont je fais partie.
Patrick M.
Trés bon cable secteur
Pour alimenter au départ un vieux dac behringer ultramatch pro.Sur mon systéme: trop de médium en avant,mais passé sur mon ampli carver musicalité et naturel au rendez vous,trés bon équilibre, douceur mais qui ne veut pas dire mou.Pas d'agréssivité ou de déséquilibre sur une zone de fréquences.Tout cela associé aux fiches cuivre pur viborg qui apportent aussi leur lot de naturel(timbres des instruments).
Patrick M.
Etonnament musical!
En remplacement d'un préamp A/V Yamaha.On passe de la hifi au monde du plaisir musical.Excellente qualité des timbres(classe A oblige),dynamique vrai non exagérée idem pour la rapidité et la réponse transitoire.Scéne sonore large , pas de trou central et bonne profondeur des plans sonores.Se marie trés bien avec un bloc carver pm-1200.Pour ma part il n'est pas trop sensible au cable secteur(occ audiophonics)mais révèle les qualités ou les défauts des cables de modulation:les différences sont énormes.Le son est plein il a du poids presque comme dans la réalité:cela sonne vrai, ç'est naturel.Aprés avoir fréquenté quelques salons hi-fi j'ai toujours été impressioné par les prix jamais par la musicalité, exception faite de quelques constructeurs qui savent reproduire la musique et pas que des sons!Le prix est inversement proportionnel à sa musicalité!Trés bonne réalisation du coffret, ç'est relativement lourd pour la taille et les fiches rca sont d'excellentes qualité.Par contre j'ai trouvé l'emballage pour ce produit un peu cheap et un vis à l'arriére du préampli pas complétement vissée.Sinon hyper satisfait!
Anthony S.
Excellent Rapport Qualité Prix
Produit de conception solide, châssis robuste ce produit inspire confiance au touché. La fonction détection de phase est simplissime il suffit de brancher chacun de ces équipements un à un, la fonction prise Master permet aussi de mettre en veille un seul équipement et le reste Dac et Drive suivent. Enfin sur l’écoute cela reste subjectif, mais il y a un mieux prononcé sur l’ensemble du spectre notamment sur l’aiguë moins criard ainsi qu’une scène sonore mieux étagée. C’est un excellent investissement dans le cadre d’une optimisation de sa chaîne de valeur audio
Emmanuel C.
Exceptionnel pour le prix, même sous alimenté.
J'ai pris cet ampli, plutôt par curiosité, juste pour voir ce que c'était. Je voyais tous ces avis élogieux et je me disais « Pas possible, ils n'ont jamais entendu un bon ampli ! ».
J'ai connu la classe D lors de mes cours d'électronique orientation Radio TV début 1990 et à l'époque, à part les mégaphones et amplis de sono, ça n'avait pas beaucoup de succès. C'était un peu agressif ! Du coup, j'étais resté sur cette idée.
Comme point de comparaison, j'ai un vieux gros Japonais de ± 20Kg, mais aussi un NAD 3020 i dont je trouve que l'on en dit beaucoup trop sur son sujet.
Je ne m'attendais pas à trouver ça dans un boîtier si petit et surtout si bon marché. C'est une sonorité très propre, relativement détaillée. Une très belle précision, pas d'agressivité du tout, une belle image stéréophonique. La localisation des instruments est assez précise. Tout le spectre semble bien présent et sonne plus « monitoring » que Hifi. Bref, quelque chose de tout à fait inattendu.
En toute sincérité, le NAD 3020 ne tient pas la comparaison, quand on les compare, on entend vraiment le manque de netteté du NAD et sa faiblesse dans le bas du spectre. Oui, celui-ci (le TDA S50) est plus net, plus précis, tout en restant aussi doux.
La comparaison avec le gros Japonais est plus nuancée. Là, je ne sais pas dire qui fait mieux. Difficile comparaison. Le « classe D » se montre plus net, plus précis, mais moins ample et manque d'épaisseur et de relief. Mais il n'est aussi alimenté qu'en 20V au lieu de 36V. Je ne sais pas si 36V apporteraient un plus de ce côté-là.
Intrinsèquement ce petit ampli, compte tenu de son prix et de sa taille, est absolument exceptionnel (mais ils le sont probablement tous dans cette catégorie). Bref, ça m'a vraiment réconcilié avec la les amplis à découpage. De toute évidence, l'avenir de la Hifi est là.
Points forts :
Equilibre spectrale.
Détail et douceur.
Tiens bien en puissance malgré les 20V
Bonne dynamique.
Netteté des instruments.
Points faibles :
Manque un rien de relief et d'épaisseur, voire de rondeur.
Bref on est pas loin d'un ampli sans faute et pourtant c'est le bas de gamme.
Bon, tout ça sont sur des modestes Monitor Audio, j'imagine que sur du haut de gamme, ça ne passerait pas aussi bien. Mais pour le prix c'est hallucinant !
Oui, petit défaut : le gauche et le droit sont inversés. En revanche, pas le moindre bruit parasite.
FILIPPO A.
Ottimo cavo!!
Cavo eccezionale per neutralità e trasparenza. Compete con concorrenti dal prezzo molto superiore. Benissimo Audiophonics!!
Thierry L.
Fonctionne parfaitement.
je l'utilise pour un ampli de puissance relié à mon ampli home cinéma.
Expédition très rapide et soignée. Merci
Bruno C.
Excellent rapport qualité / prix / fonctionnalités.
On peut trouver mieux en qualités sonores mais à ce prix là, rien à dire, c'est Ok.
Jean-Christophe R.
Surprenante
Apporte matière, propreté, et son "analogique" à la musique, à l'instar des câbles et fiches Furutech. Indispensable.
Michael L.
Best budget speaker cable
Finally goit it 2x4 meter, B&W 607 s1 (bi wired) nad c352 and nad D1050 with wbc gotham analog and qed perfomance optical cable. Easy top strip,easy to fit into any quality banan,bfa,spades, sound compared to qed xt25, somehow clearer highs and deeper tighter bass ,if it improves after 150-200 it must be the best budget cable ever
Edmond S.
ne pas se priver
simplement efficace, un meilleur contact plus facile a 'visser", en argent, qui conduit mieux le courant que le cuivre des câbles. Aucune performance bridée, .. usage systématique.
Edmond S.
pratique (orientable) et de qualité (cuivre)
prise associée a du SOMMERCABLE NYM-ST-J Câble Secteur Cuivre OFC 3x2.5mm² pour améliorer une multiprise.. Tête de la prise orientable, c'est pratique avec du câble un peu raide .. Musicalité du résultat au dessus de mes espérances..
Edmond S.
cuivre massif et argent
facile à mettre en oeuvre..plus de transparence a l’écoute par rapport a des bananes en laiton doré
Edmond S.
plus de tenue et de détails
j'ai utilisé ce câble (3 x 2,5 ofc/blindage/drain de masse)pour remplacer celui (3 x 1.5 cuivre "industriel") d'une multiprise câblée en 2,5 mm en interne.. résultat net et inespéré..ce qui était correct est devenu excellent..Plus de détails à l'écoute, de tenue des registres,
de basses ..je recommande.
Jean-Charles R.
SMSL M400 Balanced DAC AK4499 XMOS XU216 MQA 32bit 768kHz DSD512 The SMSL M400 is a DAC with balanced and single-ended outputs taking advantage of very high fidelity components: DAC AKM AK4499 chip, USB interface XMOS U216. It...
Très bon produit beau désigne excellente qualité sonore
TOPPING D70 BT Balanced DAC 2x AK4497 XMOS XU208 I2S Bluetooth 5.0 LDAC 32bit 768kHz DSD512 Silver The DAC Topping D70 BT features many refinements specific to a high-end audio product. Powerful chips, ultra-low jitter clocks, latest generation interfaces and great...
DAC remarquable
Le descriptif de ce DAC n'est pas usurpé. Finesse et détails révèlent la profondeur de la scène sonore sans aucune agressivité. Les enregistrements sont exactement rendus. Mon matériel d'écoute a fait un bond qualitatif difficile à surpasser.
Petit détail, il envoie un ploc dans mon ampli quand mon streamer se connecte (par SPDIF). Pour éviter ce petit désagrément, je met le DAC sous tension après les autres éléments.
Aleš J.
Big positive surprise
I was really surprised how good does my Dali Ikon 2 and custom amplifier perform with this DAC. For this price, it does not have any competition.
Hubert B.
Andis O.
For high-end systems!
Outstanding low frequency sound and detail.
Very balanced and neutral sound!
The best benefit for fans of any music genre!
Johan E.
Excellent little amplifier!
I got this little amplifier 2 days ago. Pair it with a Topping E30 dac.
I just love this combination! Very affordable and it sounds just...beautiful!
Use it with my Hifiman Sundara which it drives with absolutely full control. Theres a LOT of power in this amplifier.
Also use it as a preamp for my active Heco speakers with great results.
All together it sounds wonderful.
Highly recommended!
Jerome G.
Moins moche en vrai que sur la photo.
Fonctionne parfaitement pour Freebox Révolution avec télécommande Logitech Harmony One.
Emmanuel C.
Simplement excellent
J'ai acquis ce produit il y a peu, plutôt par curiosité et je ne m'attendais pas à une telle finition.
PCB épais et propre qui semble de très bonne facture. L'idée de l’alimentation filtrée qui alimente aussi le Raspberry est géniale car ça apporte une sorte de mode ATX.
J'ai aussi acquis le bouton poussoir et l'alimentation qui sont les compléments qui apportent un confort non négligeable et relativement intuitifs à mettre en œuvre (voir la doc dans le Wiki).
Question du DAC lui même, comparé à mon vieux et énorme Burr Brown, bien le Sabre l'enterre aisément. je suis surpris de voir ce PCB peu peuplé faire mieux que mon vieux gros Burr Brown des années 90. Des graves bien présents et des aigus très propres. Une belle stéréophonie, bref un régal. Pas d'acidité, ni d'agressivité.
Bref, me voici convaincu et très probablement enclin à d'autres achats sur ce site.
Emmanuel C.
Alimentation qui semble bien faire son boulot
Rie de particulier à signaler : Elle semble bien construite et dissipe peu. Correspond parfaitement au DAC Sabre pour Raspberry Pi vendu ici-même.
ESCUDIER P.
avis
Très bon produit. Il a métamorphosé mes enceintes.Meilleur qualité d'ensemble sur tous les registres de mon enceinte colonne qui était auparavant bi-cablée.
Efficace et audible! Qualité du produit et Idéal pour mettre en valeur ses enceintes!bien ouvragé!
Bon délai de livraison. j'en commandé d'autre pour mes autres colonnes.
Jean-Pierre L.
FX-AUDIO D802E FDA Amplifier STA326 Streamer WiFi DLNA Bluetooth 5.0 Multiroom 2x80W / 4 Ohm Silver The E version of FDA D802 amplifiers from FX Audio now includes WiFI (DLNA) connections to complement Bluetooth connectivity.
son +++ ; connexion wifi ---
les plus :
livraison rapide, fabrication de qualité, fonctionnement intuitif, son très bon sur de petites enceintes (un peu moins de volume de graves sur des bibliothèques), bluetooth OK, PC/USB OK, bref conforme à mes attentes.
les moins :
impossible de le connecter au réseau en wifi pour activer la fonction DLNA, motif de mon achat. les réseau adhoc est très faible, aucune des procédures de raccordement ne fonctionne, la doc est succincte.
bilan : excellent support très réactif sur le site, après diagnostic retour aux frais d'audiophonics, j'attends la suite...
Philippe V.
Positivement surpris
Ma config : AD18 + enceintes B&W Signature + subwoofer Yamaha SW300
Je cherchais un DAC bon marché pour valider l'intégration PC (applis : equalizer + Spotify + iTunes) / BT / platine analogique et je suis tombé au fil du web sur l'AD18 qui répondait quasi à tous mes besoins (l'aspect ampli était donc secondaire dans un premier temps). Je me suis lancé sans trop croire les revues positives ... erreur! Ce petit appareil est absolument incroyable, sonorité quasi égale à ce que l'on peut attendre d'un ampli intégré de marque. Je n'ai pas encore eu l'occasion de le pousser dans ses retranchements mais le volume que j'en ai déjà tiré est à la limite du supportable pour les voisins :-)
Un coup de chapeau à l'équipe Audiophonics : site web clair et précis, prix attractifs, possibilité de paiement complètes, excellent suivi de commande et livraison très rapide. Bravo.
PS : pas de problème d'alimentation à signaler
Pascal P.
satisfaisant
pratiques pour les lieus restreints . Faciles à connecter ,fabrication soignée
Pascal P.
mediocre
Malgré un aspect flatteur et technologique , ces connecteurs ne m'ont pas convaincu à cause de la difficulté de raccordement de la partie mâle qui est enchâssée dans un bloc de téflon .La soudure a ainsi tendance à couler sur la partie qui entre dans l'embase femelle ! Quant à la tresse de blindage ,il n'y a rien pour la souder , il faut seulement esperer quelle touchera au boîtier métallique au moment de l'assemblage !
Pascal P.
grande souplesse et faible capacité parasite
Pierre Z.
Pas mieux
Un câble résolument haut de gamme pour son équilibre.
J A C.
Using with Khadas DAC
I have yet to implement this using a FPC cable to connect to my Khadas DAC but when I have I will leave another review!
Jean-Marie C.
LINDY ANTHRA LINE Male USB-C to Male USB-C 2.0 Cable Gold Plated 3m Lindy's Anthra Line cables are high quality products, ideal for professional installations. This is a USB-C male to USB-C male cable with standard 2.0 and transfer rates up to...
Câble LINDY USB C vers USB C
Rien à dire. Câble de très bonne facture. L'emballage est soigné et la livraison respectée.
Guillaume L.
Problème en bas de spectre
J'ai fait le choix de ce DAC après avoir lu des études techniques mettant en avant les capacités de l'appareil. De plus, les avis utilisateurs semblaient globalement positifs.
Après 120h d'écoute, j'ai pris la décision de renvoyer le DAC. En effet, bien que les aigus et le medium soient très bien rendus. Une bonne séparation des instruments, beaucoup de détails musicaux, ce DAC a des qualités indéniables. Néanmoins dans le bas du spectre, basse et bas medium, le rendu était mal détouré, je ne retrouvais pas un rendu de qualité décente vis-à-vis des cinq autres DAC que je possède déjà. Je ne sais pas si cela vient d'un défaut spécifique de l'exemplaire que j'ai reçu ou de ce DAC en général. Je me suis tourné vers un modèle proche, le Soncoz LA-QXD1 dont je suis très satisfait.
pascal B.
préampli phono
très bon petit préampli phono bien conçu, bien réalisé, bien fini ; fournit une restitution sonore de qualité avec un système d'amplification compact et simplifié (uniquement entrée ligne) et permet ainsi une écoute de ses vinyles dans une configuration minimaliste ; rapport qualité/prix très positif
C'est mon 1er achat sur la boutique Audiophonics, par l'intermédiaire d'un célèbre site de vente aux enchères.
Le but était de remplacer les casques intra fournis avec mes smartphones successifs, avec un petit budget.
Résultat, je redécouvre ma musique et réutiliser es anciens écouteurs s'apparente maintenant à une torture.
Précisions : je lis des fichiers lossless sur un vieux Fiio X1.
Hormis l'écoute, j'ai également apprécié le fil qui ne s’emmêle pas, le choix des embouts et la qualité ressentie de ce produit.
Tout ça pour un prix plus que raisonnable.
Je suis enchanté, merci !
