Marcus L.
Michael M.
Worth every penny!
mathieu l.
Cyril R.
Relié à la tv par hdmi arc et à l´ordi par toslink, cet appareil envoi un signal analogique tout à fait correct sur l´ampli.
Pour le jus, j´ai mis un vieux chargeur de téléphone, et hop.
Le bluetooth fonctionne aussi. Je n´ai pas testé le son par usb avec le driver dispo sur le site du constructeur.
Davor F.
IFI AUDIO DC BLOCKER+ Main Power Supply Filter 90-250VAC Like its predecessor, the iFi Audio DC Blocker, the DC Blocker+ is a mains power filter that eliminates residual DC voltages to limit noise levels. It however improves filtering...
doing job well
Great little device.I have a toroidal transformer with 625Va in my integrated amplifier and it occasionally buzzed, this little dc blocker did its job and stopped that occasional buzzing and thus justified its purpose. Thumbs up
Davor F.
Just Great
From the first minutes of powering with this cable i was a little sceptical if it's gonna be something good of him but you must put youre suspicions aside and let it play for about 30 or more hours.After 50 hours of powering it becomes revealing as hell in a good way,stage opens up,details in abundance and bass is more defined.Cable is worth every cent, you wont regret it if you go for it.
chris p.
vfm amp/dac with trs output.
Paired with the edition xs and my monitor speakers everything works perfect. Very fast delivery 24hr first time experiencing that really nice. I only hope that the device has longevity. Recommended.
Olegs Z.
SS3602
Превосходные операционники, отличное качество звучания,сцена, прозрачность,детальность, всё на высшем уровне!!!
John T.
Top!
Excellent quality product with top sound. Using it to drive my centre speaker in my suround sound set-up. Only wish would be to be able to switch off the power light which is possible in the stereo version of this amp. As ususal, quick & efficent dispatch from Audiophonics.
vive le R2R....
Matière, détail, scène sonore,. Le traitement des sifflantes sur les voix, la cohérence entre la réverbération et les instruments acoustiques, (guitare classique par exemple) en prise live, est à mes oreilles très convaincantes. Une écoute réaliste, un vrai plaisir.
Rodage imperatif
Excellent câble de modulation. Monté en xlr avec des neotech 06612, il se montre très charnu et délivré de beaux détails sur tout le spectre. Mérite des connecteurs de bonne qualité, ce qui m'a obligé a revoir cela, non pas que les neotech 06613 soient mauvais, mais peut être pas a la hauteur de ce câble.
Pendant son " rodage" ,il peut se montrer décevant mais en mûrissant, il est vraiment très bon.
Bon rqp
Pas d' avis sur les qualités sonores, semblent relativement neutre, mais sont qualités tout a fait correct. Pour des câbles de fort diamètre, c'est intéressant.
Ethernet RJ45 Cable Cat 8.1 40Gbps Shielded Gold Plated 2m This RJ45 Ethernet cable takes advantage of the recent Cat 8.1 standard, offering a bandwidth of up to 40Gbps. The cable itself has a high quality design with a double shielding...
Qualitatif
Très bon câble solide et "franc" à la manipulation.
Ses qualités de transmission, sont très bonne. Je recommande ce câble au rqp très intéressant.
Bonne surprise
Ces connecteurs sont de très belle facture et s'adaptent parfaitement un câble de 9mm, il s'en dégage une impression de qualité. Le point chaud est maintenu par une vis BTR que l'on peut serrer fermement sans l'endommager. Une astuce pour souder la masse sur le corps du connecteur, j'ai mis un coup de pince coupante au milieu de la bague de soudage, j'en ai enlevé une moitié avec un pince. Il reste un demi anneau au bout duquel il est très facile de faire un point de soudure. On peut légèrement enfoncer la partie restante pour que la soudure ne viennent pas gêner le vissage du corps. J'ai utilisé de la soudure Dynavox, vendue sur le site, elle est parfaite pour ce travail. A l'écoute, s'il y a une différence avec mes anciens connecteurs beaucoup plus chers.....c'est très à la marge. Merci à l'équipe toujours à l'écoute, des pros!
Eric C.
Ne convient pas à mon DAC
Je pense que c'est un bon câble pour le prix, bien construit.
Mais, j'ai un DAC (Holo Audio Spring 3 KTE) à plus de 3000 €, et j'ai fini par comprendre que ce câble USB en argent n'était pas assez bon, en tout cas est incompatible avec ce DAC R2R.
Je vais le revendre.
Je m'explique.
Il y a beaucoup de détails, les basses descendent bas et sont bien serrées mais en même temps, le son est trop sec,
les médiums sont décharnés. Et certaines écoutes finissent par être agressives.
Je viens de recevoir un câble USB très haut de gamme (Mad
Scientist USB Ultra).
C'est le jour et la nuit.
Le son est riche, plein, aucune agressivité. Il est en cuivre OCC, et effectivement, le son est chaud, les timbres sont vrais, ça fourmille de détails, de matière, c'est hyper musical. Aucune fatigue auditive, on peut écouter pendant des heures.
La synergie en Hi-Fi, ça compte.
Désolé pour les sceptiques, mais oui, les câbles numériques ont un son. Ce n'est pas que des 0 et des 1.
Alexandru Ovidiu A.
First class connectors
Used on a Furutech 762 AC cable. Very neutral, very dinamic sound. Very good connection points and very clever and efficient cable holding system. Used on Amplifier.
Alastair P.
Superb
I bought a pair of these to replace my existing monoblocks. The RCA/XLR switches allowed me to remove a passive pre-amp (and lots of cables). I am delighted by the difference. My speakers love the power on tap and my ears love the sound, with deep, punchy bass, even at low volumes and very clear mids and treble. They took a day or so to burn-in.
Sadly, it took more than two months to receive them after they were shipped thanks to post-BREXIT customs delays on both sides of the la Manche, but I cannot blame that on the product or Audiophonics.
Jean Baptiste F.
HIDIZS LT03 Male Lightning to Female USB-C Adapter Gold Plated The Hidizs LT03 is a Lightning male to USB-C female adapter, notably compatible with iOS and Android devices, and ensuring a very good transmission quality. Its contacts are...
bien
fonctionne bien avec iphone 8
Jean Baptiste F.
TANCHJIM ZERO Dynamic In-Ear Monitor IEM with Microphone Ø10mm 118dB 32 Ohm 7Hz-50kHz These Tanchjim Zero in-ear headphones benefit from a very good quality of design and sound reproduction at an exceptionally affordable price. Each IEM embeds a 10mm...
très bons écouteurs que j'utilise sur iphone. pour du classique et du jazz que je n'écoute pas très fort. Le son est hifi incontestablement avec de très bonnes basses.
belles sonorités avec une bonne précision et dynamique. Les écouteurs son légers car en plastique, mais la tenus est plus facile, le fil pourrait être mieux mais pour le prix ... Super Rapport qualité prix. Pour le son, c'est presque aussi bien que le FIIO FD11.
Antoine S.
Que du Bonheur :-)
L'Hecate est connecté à un lecteur réseau Allo USBRIDGE Signature et à un DAC AUDIOPHONICS AK4495SEQ.
Après quelques déboires pour le configurer dans l'interface Web Allo DietPi, j'ai finalement réussi à modifier la "Soundcard" avec la valeur "Allo-Digione" (qui correspond à l'interface numérique chez Allo).
L'Hecate apporte indéniablement une amélioration, la scène sonore a plus de détail, un meilleur relief, tout est mieux positionné, un apport sur tout le spectre des bass à l'aigue
J'ai longtemps hésité mais je suis Ravie de l'ajout de cet Hecate dans mon système :-)
Encore un superbe produit proposé par Audiophonics.
Hocine H.
XANGSANE XS-006R Splitter Aluminum 1x14mm to 2x7mm Black This black aluminum splitter has one 14mm diameter input and two 7mm diameter outputs. It will allow you to design perfectly finished cables, with an efficient guiding and holding.
Très bonne qualité
Super qualité pour ce splitter qui est solide et bien maintenu. Ideal pour terminer un câble HP. Attention, les flèches indiquent le sens de filage des conducteurs, donc pour le même câble prenez 2x7mm vers 14mm et 14mm vers 2x7mm. Vous verrez d'un simple coup d'oeil quel côté connecter à la source. Enfin, pour ceux qui pensent que le sens de filage des conducteurs a une importance. Musicalement.
Selman K.
IAN CANADA I2S to PCM Conversion Board V2.0 This I2S to PCM conversion module from Ian Canada has been developed to improve the sound performance of audio systems using a MULTIBIT digital to analog conversion chip.
be careful!
There wasn't any power cable in my set,but photo shows the power cable?
Also be careful about TP1 AND TP9 through holes,because silk white writing indicates dc and gnd are wrong! It is almost like a trap! Small mistake but audiophonics should write a note under this product about it!
Maybe he should add uf.l connectors into this set..
For me,uf.l pads should be on front side of the pcb(hear me Ian :)
Connectors are well aligned,I liked the pcb quality,I didn't test yet,but I powered the board without any problem.
Thanks!
Hocine H.
Condensateur utilisé avec un bypass de 0.01 uf pour refaire un filtre passif (Medium/Grave) qui donne entière satisfaction. Je l'ai utilisé en combo avec un Jantzen Superior z-cap qui se marie très bien pour la dynamique qu'apporte l'evo oil Mundorf. En plus il est peu encombrant. C'est du solide. Audiophonics, vous vous êtes trompés sur les dimensions de ce produit.
Grégory L.
Bien mais fragile
Attention à ne pas chauffer trop longtemps si vous devez souder des fils sur les bornes de cet interrupteur.
Préférez les cosses si vous le pouvez.
A voir...
Après avoir essayé le wiim mini, qui n' était pas stable dans son software, j' ai voulu essayer la "perle" des streamer avec ce wiim pro +.
L' application, la stabilité, la connectivité sont top et fiable pour le coup.
Cependant, je l' utilise avec un dac externe eversolo z6.
Le son est brouillon, dans le bas. Obligé de passer par l' equalize en mode réduction de basse. Quel dommage !!!
J' ai de meilleur résultat en bluetooth avec mon dac.
Encore victime du matraquage marketing.
Je vais le garder quand même et essayer de compenser (grrr..)
Peter V.
Furutech
I'm a fan of Furutech Headphone Cables!
Precise execution and a broad stage
The plugs are the right size
Excellent.
Câble testé et redécouvert recemment, d'où mon commentaire sur celui-ci. Je l'ai écouté comparativement a son cousin Nes 5005 et au Magellan Spk 240 entre autres de prix similaire a savoir 4 euros le mètre. Le matériel utilisé était la partie préampli d'un Cyrus 3 vers un bloc quad 405 sur des Apertura nova. Écoute faite d'abord en mono via le boîtier commutateur dynavox pour une comparaison a/b instantanée, puis validée en stéréo de façon alternée. J'ai trouvé ce câble excellent pour le prix. Belle qualité de timbres alliant richesse et définition. Il surclasse ses compagnons en terme d'espace et d'aération, proposant une image exceptionnelle large et spacieuse, ça fuse de toutes parts sans aucune crispation sur le cd de Léon Parker Belief. Le Spk 240 est aussi vraiment très bon avec peut être un côté un peu plus rond, et plus précis, mais c'est plus feutré, il y a moins d'espace autour des instruments. En ce qui concerne le Nes 5005 il ne se fait pas remarquer côté timbres c'est plutôt neutre. Par contre en stereo l'image se focalise un peu plus comme si l'on était plus proche des instruments. Pour ma part j'apprécie moins mais il faut relativiser cela reste une excellente référence pour le prix.
Amaury C.
Révélateur de talents !
Je viens d’un câble Supra 2.5, équivalent du Jantzen vendu par Audiophonics. Que dire de cet Elecaudio HP-25OCC ? En résumé il laisse passer le signal avec le moins d’altération possible (transparence). Et c’est ce que l’on demande avant tout à un maillon intermédiaire dans un système audio.
Côté mise en œuvre, j’ai utilisé des fiches bananes QED qu’il me restait en stock (j’ai été pro dans un lointain passé). Celles qui se sertissent sur le câble avec une pince spéciale afin d’obtenir une « soudure à froid ». Comme les manchons de ces fiches QED ne passaient pas sur la gaine du câble Elecaudio (très grosse), alors je les ai remplacées par des gaines thermo rétractables blanches et rouges (esthétiquement ça réagit très bien sur la gaine noire du câble).
En amont le système est composé d’un Oppo 105D que je n’utilise plus que pour lire CD et SACD, couplé à un DAC Gustard X16. Ils sont liés en I2S via HDMI (grâce à l’adaptateur acheté aussi chez Audiophonics). En préampli un Marantz AV7706 et en amplification : Audiophonics MPA-S250NC XLR. Les câbles modulation (RCA et XLR) sont des Neotech NEI 3004. Les enceintes sont des Focal Aria 936.
Je confirme qu’il faut une période de rodage d’une bonne dizaine d’heures (voire un peu plus).
Résultat du changement des câbles HP ? On y gagne partout : respect des timbres, ouverture et profondeur de la scène sonore, ambiances de salles, micro informations beaucoup plus audibles. Ça respire ! Et en corollaire, on gagne aussi sur l’intelligibilité de la restitution. Tout s’entend mieux, tout se comprend mieux. La géométrie de la scène sonore est respectée. Je veux parler du placement des instrumentistes et des voix, mais aussi de leur volume propre. Alors évidemment, si l’ingénieur du son à voulu mettre en avant la voix au détriment de l’accompagnement instrumental, ça ne va rien y changer, mais s’il s’agit d’une prise de son stéréo d’un ensemble, alors oui, clairement, tout est bien à sa place et dans le volume propre à chaque voix/instrument. Très franchement, ce câble est un révélateur de talents. Alors, si vous souhaitez profiter à plein de votre système, faites l’essai pour vous faire votre propre opinion. Mais a priori vous ne devriez pas le regretter.
Thierry T.
Amélioration notable
Dans l’optique d’améliorer le système phono depuis la platine, la tête de lecture jusqu’aux enceintes, j’ai acheté ce câble en remplacement du câble d’origine sur une platine phono Transrotor, Et
Je dois dire qu’une fois encore dès la première écoute j’ai été étonné, il me semble avoir gagné nettement dans les aigus essentiellement. Étant donné le prix de ce câble, c’est un élément essentiel pour améliorer toute la chaîne d’écoute.
Thierry
Gregory G.
Rapport musicalité/prix excellent
Je l'ai acheté pour équiper un ancien dac sans entrée USB. J'ai été tout de suite surpris par les résultats. La musique est très dynamique, la réponse en fréquence étendue et la résolution est excellente.
Les résultats ont été tellement bon que j'ai voulu l'essayer sur mon dac Audio-GD NOS. Et là les résultats ont été au-dessus de mes espérances. On retrouve les mêmes résultats que sur mon ancien dac mais tout en mieux. L'écoute est très nettement supérieure à l'entrée usb Amanero de l'Audio-gd. Au point que maintenant le Silkline est branché en permanence dessus. Vraisemblablement, le FGPA permet d'atteindre un niveau d'écoute excellent pour un prix raisonnable.
Autre chose, ce n'est pas parce que l'appareil n'est pas cher, qu'il ne faut pas soigné l'installation. Il est très sensible au câble usb. Donc ne pas hésiter à en mettre un bon. Pour ma part j'ai obtenu un très bon résultat avec le Neotech cuivre-argent. J'ai aussi mis une alimentation externe. L'apport est moins sensible que pour le câble mais il y a encore un mieux.
Autre chose. J'ai dû renvoyer le premier appareil qui a lâché au bout d'une semaine. Par contre je n'ai pas eu de problème avec le second. La prise USB semble toutefois bien fragile. Il faut bien qu'il y ait un défaut vu le prix raisonnable.
jf a.
TOPPING L50 Balanced Headphone Amplifier NFCA Black The Topping L50 is a desktop headphone amplifier with an architecture optimized for incredible sound performance. It features a new generation NFCA circuit, based on the one...
rapport qualité prix imbatable
Topping fait très fort comme d'habitude... Il y a plus cher mais c'est moins bien !!!
Un seul mini regret: le "pass-through" ne fonctionne que lorsque l'ampli est éteint.
Eric A.
Juste la musique, un point c'est tout...
Tout a déjà été dit sur ce magnifique appareil.
J'écoute toute sorte de musiques, beaucoup de classique, d'indi, de jazz, de rock...Ce R26 ne vous décevra jamais.
Avec lui c'est juste l'essence de la musique, c'est analytique, mais pas trop, c'est dynamique, ça monte haut, respect des timbres, ça descend bas, aucune agressivité, l'image stéréo est immense en largeur et profondeur...que dire, on a juste la musique en face de soi...
J'avais lu sur les réseaux quelques problèmes avec le streamer, mais non, tout fonctionne parfaitement chez moi, Tidal connect, Bubbleupnp, LMS.
Encore au dessus d'un SMSL Su-9 qui est pourtant un DAC remarquable. Bien mis en oeuvre on a la une base de choix pour bâtir un système de haute qualité..
Pas donné bien sur, mais rapport qualité prix incroyable, et service Audiophonics impeccable.
Hocine H.
MUNDORF MRESIST CLASSIC Resistor 10W 2.2 Ohm Mundorf MResist Classic resistors offer very good performance. They are similar but slightly simpler in construction than the MResist Supreme resistors. The MResist Classic...
Top mais fragile
Utilisée pour remplacer des resistances sables sur un filtre passif, cette resistance ouvre le son, comme si on enlevait un couvercle. Attention elles sont fragiles. Je conseille vivement.
Peter V.
5 Stars
I'm a big fan of Furutech Headphone cables!
IFI AUDIO IPURIFIER 2 SPDIF EMI Filter Galvanic Isolator Reclocker The iFi Audio iPurifier 2 SPDIF is a small interface that functions as an EMI/RFI filter, galvanic isolation and reclocker. It provides you with a clean audio signal for...
Installé entre mon lecteur réseau (sans DAC) et un DAC Topping D70, l'écoute est transfigurée. Belle aération, élargissement de la scène sonore et surtout fluidité musicale, le stress dans les aigus ayant disparu. Ayant déjà expérimenté le IFI audio NANO GALVANIC qui m'a apporté la même impression sur une autre configuration (en USB), je ne peut que recommander cet accessoire indispensable à une écoute HIFI.
Patrick H.
Prise MIDI / MIDI socket
Si vous vous demandez.... oui c'est une prise midi. If you're wondering.... yes it's a midi socket.
Patrick R.
LUDIC ASGARD Power Distributor 6 Schuko Sockets Black The Ludic Asgard power distributor is a high-end model with 6 Schuko plugs and a total shielding. It will provide your audio devices with a clean and stable electrical signal,...
Extra
Barette secteur au rapport qualité prix imbattable. La construction juste parfaite.
Ce n'est pas une barette filtrée donc pas de risque de tassement de la dynamique.
Elle fait très bien le boulot et l'affichage est bien un pkus très appréciable.
Christophe F.
excellent ampli
Disposant d’un DAC SMSL SU8 avec sorties symétriques, j’avais envie d’avoir un ampli avec entrées XLR, d’autant que je suis très sensible à la qualité des silences dans une installation hifi. Jusqu’alors satisfait de mon ampli BC ACOUSTIQUE 222.3, j’ai tout de même décidé de passer à cette classe D économe en énergie et donc écolo, compacte, au design sympa mais en ayant des doutes quant à sa musicalité (appelons ainsi la capacité d’un appareil à restituer la musique le plus naturellement possible ou du moins dans des conditions qui font que l’écoute se fait oublier). Je me doutais que la restitution serait dynamique car même nos petits autoradios ou nos télés (la plupart amplifiées avec des modules classe D basiques) ont de la pêche et que les basses seraient toniques. Simple confirmation de ce côté, mais quid du reste ? Eh bien, c’est avant tout plein de détails. Là, entre mon ancien ampli et le nouveau, il n’y a pas photo. Côté bruit de fond, c’est très bon, les pianissimi et nuances fines ressortent bien. Les timbres, eux, sont bons sans être exceptionnels, ça s’entend sur des violons par exemple, il reste une petite touche pas nécessairement électronique mais pas totalement naturelle, c’est très léger et parfois on se demande très sérieusement si ce n’est pas plutôt la prise de son qui est en question. L’autre très léger regret, c’est parfois une impression de manque de corps mais là encore, c’est subtil et difficile à décrire, il est très possible que ce soit simplement la différence entre une restitution « à l’ancienne » (j’ai biberonné aux vieux amplis analogiques) et une restitution plus objective, plus droite, plus fouillée. Côté image, je ne m’avance pas car mon installation dans une salle à manger avec la table devant les enceintes n’est vraiment pas idéale !
Au final, très satisfait de mon achat même si côté équipement ma migration a nécessité que j'achète un ampli casque dédié à brancher sur la sortie asymétrique de mon DAC : la restitution est dynamique, bourrée de détails et vivante. Sur de la musique actuelle, ça le fait totalement. Sur de la musique classique, ses nombreuses qualités suffisent à emporter l’adhésion mais il reste une petite matité dans les timbres à peaufiner. Reste à voir comment se comportera l’appareil sur la durée (mais mon dac de la même marque, datant de quelques années, est toujours aussi vaillant...)
Rumen S.
Steel Housing Black Cover for Toroidal Transformer 110x100x115mm This sturdy 110 x 100 x 115mm cover for toroidal transformer is made of Aluminum. Its panels are 1mm thick. The assembly is done using its four M4 threads.
Very useful cover
A transformer cover with an excellent aesthetic appearance.
However the material is not aluminum, but a stamped steel.
Rumen S.
XANGSANE XS-6002AU Banana plugs Gold-plated Ø7.5mm (Set x4) These Xangsane XS-6002AU banana plugs feature copper alloy contacts with gold plating for enhanced conductivity and resistance to corrosion and oxidation. Their...
What a pleasant surprise!
The plugs came packed in a luxury metal box. They have a very well crafted heavy brass body. The gilding looks smooth and thick. The overall appearance is like an expensive product. A real bargain!
Rumen S.
Excellent craftsmanship
High quality terminals, mounted on a thick and heavy aluminium panel. An affordable price for the set.
jean paul g.
transfo pour ampli tubes
commande facile avec le logiciel intégré à la commande , prix et délai correct transfo très bien réalisé .
Enrico Z.
DAYTON AUDIO ND65-8 Speaker Driver Full Range Aluminium 15W 8 Ohm 81dB 80Hz - 20kHz Ø6.3cm With its low distortion motor mounted on a Neodymium magnet, its high excursion design and its lightweight, solid aluminum diaphragm construction, the ND65-8 wideband speaker...
Positive experience with small speakers
The sales service was excellent, the product arrived quickly, intact and well packaged. As for the speakers... I have yet to test them thoroughly but they seem to work very well.
Jan H.
Nice connectors, but the pins of these Viborg xlr connectors have no numbers. So that makes it a little difficult.
Denis D.
Câble correct mais pas Hi-Fi
Câble bouché que j'avais acheté en 2019 à mes début.
Dès les premières écoutes, le son est lassant, monotone, bouché.
A voir s'il a besoin de burn-in. Mais on part tellement de loin que cela ne donne pas envie de continuer et d'espérer une amélioration.
Autrement le son passe pour d'autres applications. Un peu le cas de tous les produits de cette marque...
Câble correct mais pas adapté à la Hi-Fi!
Hocine H.
XANGSANE SP-8515 Speaker Cable Silver-Plated OFC Copper 2x1.5mm² This Xangsane SP-8515 is a speaker cable whose conductors are both made of 7 strands of silver-plated OFC copper for enhanced conductivity. The...
Top produit
Utilisé pour recâbler l'intérieur d'enceintes bibiotheques, ce câble est une merveille, tant dans la fabrication que son utilisation, meilleur rendu sonore dans le haut du spectre. Cette marque est incroyable pour ce prix.
Hocine H.
Très bon produit, efficace pour decaper, etamer, désouder.
Vraiment top ces fiches !
Destinées à un câble Mogami 3103, sans soudure, ces fiches sont d'une très grande qualité.
Je les préfère aux Viborg VB 401 qui offrent moins de contact dans les borniers d'un amplificateur.
Ces fiches ont une prise banane intérieure pleine qui renforce le cylindre quand on l'introduit dans le bornier.
Après l'avoir enfoncé jusqu'au 3/4, j'ai poussé fortement et une résistance se fait sentir jusqu'au fond, tout au fond du bornier.
On est sûr que le contact est maximal et ça ne bouge vraiment plus, le bornier est totalement rempli.
La qualité des vis est excellente, on peut bien serrer avec une clé 6 pans de 2mm (non fournie).
Le matériau est génial, aucune détérioration du signal contrairement à des bananes basiques.
Pour la finition j'ai mis une gaine thermo-rétractable.
La fiche accepte bien un câble jusqu'à 5mm2.
4 fiches livrées en vrac dans un sachet plastique, pour un cadeau prévoir une jolie boite.
Livraison éclair en 2 jours chrono, bravo à Audiophonics.
Super !
Grâce aux avis précédents, aucune difficulté pour enfiler ces splitters sur un câble Mogami 3103.
Très peu de vaseline sur chaque câble rouge et noir et ça rentre tout seul sans forcer.
Belle finition pour ce câble ensuite.
Livraison éclair en 2 jours, bravo Audiophonics.
Gerard T.
NEOTECH NEDI-4001 XLR AES/EBU 110 Ohm Cable Silver Plated OFC Copper Ø7mm The Neotech NEDI-4001 is a balanced cable for AES/EBU cable design. It provides excellent transmission quality thanks to its silver-plated OFC copper conductors (SP-OFC) and...
Bien mais..
J ai voulu comparer un NEDI 4001 110 ohm en AES au
NEVD-2001 75ohm.
Musicalement rien à voir le NEVD-2001est largement au dessus.
est-ce du à l argent ? aux divers blindages ?
Marc S.
Bon rapport qualité prix mais...
transformateur de prix correct, cependant il présente des vibrations importantes et audibles, du coup en audio pas top
Hocine H.
Super fiches, contact total sur toute la tête et très bien maintenue dans le bornier, en plus les gaines thermos sont avec, à ce prix c'est à peine le prix des gaines thermos.
Eric K.
ampli casque symétrique
très bon ampli symétrique (surtout).Je l'utilise sur un dac smsl : nickel ! Son précis et ample sur audio technica ATH MSR7b.Merci pour les renseignements sur service technique (David Aubert).
