MUNDORF ACW220P-BK/BU ANGELIQUE Wiring Cable
The MUNDORF ACW220P-BK/BU ANGELIQUE is a SolidCore audio wiring cable made of Angelique® copper, offered as a twisted pair of 2mm diameter conductors, with a cross-section of 2x 3.1416mm².
Reference : 22537
44,90 €tax incl.
37,42 € tax excl.
Cable sold by the meter
Mundorf ACW220P-BK/BU ANGELIQUE Single-Strand Copper Wiring Cable 2x3.1416mm² Black/Blue
The Mundorf ACW220P-BK/BU Angelique is a SolidCore audio wiring cable made of Angelique® copper, offered as a twisted pair of 2mm diameter conductors, with a cross-section of 2x 3.1416mm². Featuring YI8 PVC insulation and black / blue identification, it is intended in particular for the internal wiring of loudspeakers and electronic equipment, as well as for various audio cable constructions. Its DC resistance of 2x 6 mΩ/m and its outer diameter of 2x 3mm make it a suitable solution for applications requiring a SolidCore conductor with a large cross-section. The cable is rated for a nominal voltage of 300V DC and an operating temperature range between -20°C and +90°C.
Technical Specifications
Product TypeWiring cable
Conductor MaterialCopper
Conductor Diameter2x 2mm
Cross-Section2x 3.1416mm²
DC Resistance2x 6 mOhm/m
Outer Diameter2x 3mm
Nominal Voltage300V DC
Operating Temperature-20°C / +90°C
ColorBlack / Blue
PackagingSold by the meter
Diameter (mm)2.0
Number of conductors2
Insulation materialPVC
ShieldingNo
Section (mm²)3.1
Ground / ShieldingNo
MUNDORF ACW220P-BK/BU ANGELIQUE Single Strand Copper Wiring Cable 2x3.1416mm² Black / Blue
The MUNDORF ACW220P-BK/BU ANGELIQUE is a SolidCore audio wiring cable made of Angelique® copper, offered as a twisted pair of 2mm...
