ARMATURE ELECTRA 8 V2 Power Distributor 8 Sockets Aluminium Black
The Electra 8 V2 Armature is a high quality mains distributor incorporating 8 sockets with Gold-plated contacts, all integrated in an elegant Black Aluminum case.
KEY POINTS :
  • Copper OCC
  • 2500W 10A
  • Gold plated contacts
  • 8 direct sockets without filtering
3.9 / 5
Reference : 12357
169,00 €tax incl.
140,83 € tax excl.
The ELECTRA F8 distributor is available at this address: ARMATURE ELECTRA F8 V2 Filtered Power Distributor 8 Sockets.
8 Sockets Power Distributor
Distributeur secteur Armature Electra 8
An essential hifi element
The mains power is the first link in your Hifi system. It is therefore essential to offer your stereo system a clean and stable voltage. It is in this spirit that Armature has developed its Electra range, composed of high-performance sector distributors, integrating high-quality components, like an OCC Copper.
High quality design
The Electra 8 V2 model of Armature integrates 8 mains plugs to be able to connect a complete system. All contacts are gold-plated to ensure excellent signal conductivity and thus enhance the sound reproduction of your system. All this is integrated into a casing at once sober is elegant. Designed in black aluminum it proves to be very resistant. The internal wire is exclusively in OCC copper 2.5mm²
Armature Electra 8
TypePower distributor with OCC 2.5mm² internal copper cable.
Number of outlets8
Maximum power2500W 10A
ContactsGold plated
Case materialAluminium + 4 non-slip rubber feet
Dimensions33.5 x 15.5 x 6.8cm
Weight1.8kg
Accessories1x IEC cable 1.5m
Number of sockets8
FilteringNo
9 reviews
Articolo di scarsa qualità
Dopo 4 anni di utilizzo le prese si distaccano dall' interno,così è successo a me e ad altri amici, prodotto veramente di scarsa qualità
This review has been posted for ARMATURE ELECTRA 8 V2 Power Distributor 8 Sockets Aluminium Black
Etonnante version MK2 sans les prises branlantes!!
Mon instal ayant pris de l'ampleur, streamer, DAC etc... j'ai racheté une barette identique à la première. La première il y a deux ans amenait une évidente transparence (à priori cable interne de course??) mais avait des prises un peu branlantes. Bon une fois la prise fixée, personne va aller la secouer, mais c'était une petite contrariété. Oh surprise Audophonics a du rectifier le tir car non seulement ce ne sont pas les même prises (plus cossus) mais enclenchement super ferme dans la prise. Le top. Là sans les prises bralantes, je suis bluffé car y'a plus aucun reproche possible et toujours ce petit plus en transparence. Chapeau bas et bravo d'avoir rectifié une (probable) erreur de jeunesse. Surtout gardez les même prise. C'est pas du furutech mais beau placage or et très proche de furutech niveau qualitif (vu chez ami audiophile et toujours du mal à comprendre de tels prix) et pour 8 prises le "coût à la prise" est juste "wow" !!
bonne prise..si vous avez de la chance..
au debut rien a redire pour le prix.. heureusement un pote ma promi a la fin de l ete;-) de monter se joli monde en etoile.. quelques prise ont du etre revisée.. mais j ai de la chance cette fois..sa fonctionne.. pour une marque francaise j aurais esperé une meilleurs finition.. par la suite je monterais des prise furuteck.. le bémol sais sois des contact en bronze phosphoré ou cuivre pur avec rhodium.. je n aime pas le rhodium,.sa semble plus définis.. mais sais sans joie.. pour mes goûts.. alors si vous proposiez une furuteck cuivre pur plaquer or..la sa serrais génial ..pour bc de monde.. si non rapport qulite prix..au minimum..
sockets can break
the whole concept, design, finish and shape are nice, and there seems to be no substitute for this distributor. but i experienced one socket to break internally - its plastic parts actually crumbled beyond repair. it is a weakness of the sockets, so i am afraid of further sockets breaking over time. mine right now is an 'ELECTRA 7'...
Excellent
Ma barette précédente , une Jentech DB06-EU , ne comportait que 6 prises , ce qui commençait à faire juste .
De plus , après avoir investi dans de l'analogique de qualité ( Platine Clearaudio et un petit pré-ampli à lampes) , je constatais des ronronnements et autres bruits parasites captés par la cellule de la platine. J'ai mis une alimentation indépendante, ( une batterie autonome) pour le pré-ampli, j'ai doublé la masse du pré-amp vers le secteur ... Rien n'y faisait . Toujours ces bruits parasites , un peu altérés mais bien présents .
Depuis une semaine, j'ai installé l'ARAMTURE Electra 8 .
Plus rien !!! , plus un ronronnement, plus de sifflement parasite , le simple souffle classique d'un pré-ampli phono quand il est à fort niveau..
Sur le numérique, que ce soit sur le cd ou le streaming ( qobuz) , plus d'aération , de transparence.
Chapeau , à ce prix , super produit .
Juste un petit bémol ( mais qui ne décote pas la note, puisqu'il n'est pas captif) , le cable d'alimentation de base mérite d'être remplacé dans la foulée , il bride le résultat de cette belle réalisation .
Pour ma part , en attendant de recevoir un kit de cable commandé chez audiophonics ( sur conseil de David Aubert , merci!) et qui me coutera moins de 50 € , j'ai placé l' ancien cable de base de lecteur cd , et c'est déja bien meilleur .
Peut-être que celui fourni était défectueux , ça arrive...
Je recommande donc chaudement cette barrette simple et efficace, qui a libérée mon système de toutes les "saloperies" circulantes et encore aéré le message .
A bientôt sur votre site .
The Electra 8 V2 Armature is a high quality mains distributor incorporating 8 sockets with Gold-plated contacts, all integrated in an elegant Black...
