ALLO USBRIDGE SIGNATURE PLAYER Streamer USB Interface Ultra Low Noise + Case DietPi
The Allo USBridge Signature Player is based on a Raspberry Pi Compute Module 3+ SBC (Single Board Computer), offering this system great versatility. The DietPi operating system is pre-installed and the streamer is delivered mounted in a custom-designed aluminum housing.
Reference : 14145
299,00 €tax incl.
249,17 € tax excl.
This version based on the DietPi operating system requires computer knowledge.
Allo USBridge Signature Player Lecteur Réseau Interface USB Ultra Faible Bruit + Boîtier
USBridge Signature
The Allo USBridge Signature Player is based on a Raspberry Pi Compute Module 3+ SBC (Single Board Computer), offering this system great versatility. The DietPi operating system is pre-installed, and will allow you to easily access your entire audio library on a network or locally (USB storage).
The purpose of this module is to reduce noise on the USB bus as much as possible in order to provide the purest, most accurate and richest sound reproduction possible. For this purpose, the USBridge Signature includes an excellent USB control chip from TI and the Ethernet circuit is completely separate from the USB circuit, thus limiting interference. In addition, noise has been reduced on each power rail through the use of more than 30 LDO controllers. Even the power rail of the Micro SD port has its own LDO. Thus, the module does not include any switching elements that can generate noise.
As the USBridge Signature is based on a Pi Compute, Allo has chosen to integrate all the available connectivity on a standard Raspberry Pi, namely a GPIO port, USB-A, HDMI and a Micro SD slot. Therefore, anything that works with a Raspberry Pi will work with the USBridge Signature.
Review and presentation by The Hans Beekhuyzen Channel
Aluminium Case
This Aluminium case has been specially designed by Allo to cover the USBridge Signature, protecting it from dust and shocks. Tightly stretched, the housing allows access to all the USBridge Signature connectors.
The USBridge Allo is delivered mounted in the housing.
Product typeStreamer
SBCRaspberry Pi Compute Module 3+
OSDietPi
Inputs3x USB-A 2.0 Host
1x Gigabit Ethernet RJ45
1x Micro SD slot
Outputs1x USB-A (delivers up to 900mA)
1x HDMI
Supported sampling ratesPCM up to 768kHz
DSD up to DSD512 (DSD1024 theoretically possible)
Ethernet chipsetAX88179
Ethernet bandwidth330Mbs
USB protectionAll USB Host ports include built-in overload protection
Alimentation5V 3A via USB-C (sold separately)
Certification USBridge SignatureFCC, CE
Case materialAluminium
Dimensions125x154x55mm
Weight net600g
InputRJ45
InputMicro SD
OutputHDMI
DAC / ADC ChipNC
Max sampling rateDSD1024
Max sampling rateDSD512
Max sampling rate768kHz
Streaming services & Network protocolsDLNA
Streaming services & Network protocolsSpotify Connect
Streaming services & Network protocolsWeb radios
Streaming services & Network protocolsRoon / Roon Bridge / Roon Ready
12 reviews
Durée de vie 4 ans !
Dommage que ce très bon produit ne tienne pas plus longtemps, car moins de 4 ans, c'est court. Audiophonics confirme que les diodes donnent un message come quoi le lecteur réseau est HS...
This review has been posted for ALLO USBRIDGE SIGNATURE PLAYER Streamer USB Interface Ultra Low Noise + Case DietPi
Très satisfait !
Je souhaitais améliorer l'utilisation de ma bibliothèque et j'ai découvert qu'à priori je pouvais aussi en améliorer le rendu sonore avec l'USBRIDGE pour un investissement relativement restreint. Je possède un Marrantz SR7012 qui me sert aussi pour la HIFI. Et bien oui ! Le avant / après (avec alimentation de base pour le moment) est bluffant. Meilleure présence des voix, plus grande spatialisation, meilleur contrôle des basses. Livraison rapide, conseil du service technique ! Merci Audiophonics.
Excellent !
Très bon streamer. De la matière, du détail et une très belle scène sonore. Le mien tourne sous Picoreplayer, qui permet pas mal de paramétrage et se commande très bien avec l’application iPeng. Connecté à un DAC Smsl SU9, miam ! Alimentation Shanti bien sûr mais le résultat est aussi très bon nourri par une bonne power tank (attention avec courant mini de 2 à 3A).
Aucun regret !
Bravissimo Allo USBridge Signature !
Ce petit streamer est un vrai bijou, il excelle vraiment en tout ! Je peux le comparer à un SOTM, un Innuos, un Bluesound, un Marantz, une Squeezebox, et même un Antipodes et un Linn, il les distance tous, et de loin:
- rapport qualité/prix imbattable (même s'il faut lui rajouter une alim et des câbles de terre qui rallongent l'addition à 500 € tout compris)
- ergonomie et intégration: contrairement à beaucoup de streamers qui mettent de 30 à 60 secondes à s'initialiser, celui-ci met moins de 6 secondes, il tourne en RAM et ne réclame donc pas de bouton ON/OFF, on peut l'éteindre directement depuis la multiprise de sa chaîne Hifi,
- souplesse d'installation: applis au choix, avec interfaces graphiques (y compris ALLO), réglages nombreux pour les amateurs de DIY....
- et surtout: qualité de restitution audio impeccable, tout y est, mais surtout, la "musicalité" est au rendez-vous, j'hésite à le dire, mais trop souvent ces streamers sont "fatigants" (surtout avec les formats "lossy" MP3, AAC de Spotify et des webradios), les aigus sont aigres, il y a une certaine "maigreur" du son qui manque de "corps", même si la résolution et l'écoute analytique sont très bonnes. A contrario, la carte ALLO Usbridge Sig a un rendu quasi "analogique" qui n'est pas au détriment de la précision des attaques et des transitoires, quand à la scène sonore, elle est superbe (surtout si l'alimentation est top)........ bref, une excellente surprise, qui met à bas les discours marketing des marques très HDG et des marchands de soupe Hifi....
Un bémol: les tutos d'installation d'Audiophonics sont plutôt incomplets, le matériel est livré sans notice, il vaut mieux parler anglais et savoir naviguer dans les forums, où l'on trouve tout ce qu'il faut.
Pas facile de trouver mieux.
Tout d'abord, ce fut une découverte du monde Linux. Avec le tuto du blog et un coup de main de l'équipe Audiophonics tout c'est bien passé.
Au départ, je voulais mettre à niveau ma chaine "vintage" pour la lecture de fichiers Flac sur un NAS et l'écoute de Quobuz.
Maintenant le principal : l'écoute. Relié en USB à un DAC Topping D70 puis un ampli NAD C320BEE avec enceintes JM Lab Chorus 725 avec cable Elecaudio HP 250 CC (conseillé par Audiophonics) C'est que du bonheur et ça me plait. Pas de fatigue à l'écoute et une palette de fréquences que je n'avais pas l'habitude d'entendre.
Quoiqu'il en soit, je vous conseille de demander l'avis à Audiophonics avant d'acheter, ils sont de très bons conseils et ne force pas sur le matériel couteux.
Je ne regrette pas l'expérience, comparé à des installations d'un prix beaucoup plus élevé.
Bravo à toute l'équipe.
The Allo USBridge Signature Player is based on a Raspberry Pi Compute Module 3+ SBC (Single Board Computer), offering this system great...
