AIRTRY DLNA UPNP Airplay Wireless WiFi Receiver
3.0 / 5
Reference : 8779
49,90 €tax incl.
41,58 € tax excl.
This small audio receiver will allow you to listen to your music in your living room on your Hi-Fi amplifier or in your vehicle from your Smartphone, tablet or any source compatible DLNA / Airplay / UPNP etc ...
Unlike most receivers it is not the Bluetooth technology that is used here but the Wifi allowing a signal transmission without any compression or loss as well as a much greater range.
Each device is renamed in its interface to allow you to send your music in the area of ​​your choice (Lounge, Bedroom, Kitchen etc).
Capable of being used in direct connection with a smartphone (without being connected to an existing Wifi network) it can also be connected to your existing residential network.
Connected in Wi-Fi it allows to always have an auxiliary input in 3.5mm jack format to connect another source.
Features:/ Strong>
  • Auxiliary input (3.5 mm stereo jack) Jack / jack cable supplied
  • Auxiliary Output (3.5 mm stereo jack) Jack to RCA cable for simplified connection to a conventional amplifier
  • Micro-USB: Charge (transformer delivered)
  • Wi-Fi 802.11 g / n
  • Wi-Fi / Wi-Fi client access point
  • Ability to add multiple devices (renamed in their interface to be easily identified) without limit
  • Audio Bypass Function
  • Firmware update
  • Airtry Receiver Operating Instructions in English (PDF)
Features for sharing audio content on DLNA-enabled devices:
https://www.audiophonics.fr/images2/8779/8779_airtry_music_receiver_3.jpg
Comparative table between Wi-Fi and bluetooth:
WIFI connectionBluetooth
Network coverage All theresidential areaLimited to 1 piece
Hearing quality Without lossLoss in encoding - decoding
User Experience ConvenientEasy
Limitation of compatibility Anylimited
https://www.audiophonics.fr/images2/5807/micougnou.jpg
Test of the Airtry by Micougnou
https://www.audiophonics.fr/images2/8779/8779_airtry_music_receiver_1.jpg
https://www.audiophonics.fr/images2/8779/8779_airtry_music_receiver_2.jpg
https://www.audiophonics.fr/images2/8779/control_center.jpg
Possible Usage Scenarios:
https://www.audiophonics.fr/images2/8779/manual01.jpg
Smartphone / Receiver Direct Link:
https://www.audiophonics.fr/images2/8779/manual02.jpg
Networking on your residential home network:
https://www.audiophonics.fr/images2/8779/manual03.jpg
Auxiliary input:
https://www.audiophonics.fr/images2/8779/manual04.jpg
Connection delivered with the product:
https://www.audiophonics.fr/images2/8779/8779_airtry_music_receiver_5.jpg
Airtry DIY version also available:
https://www.audiophonics.fr/images2/8885/8885_airtry_dlna_diy_wifi_1.jpg
2 reviews
Pas très fiable
Le système se déconnecte très souvent du wifi. Lors d'une écoute il lui arrive souvent de produire des petits craquements entre 2 morceaux. Je l'utilise principalement avec Spotify. Sur le papier c'est un très bon produit mais finalement c'est assez décevant... A éviter
This review has been posted for AIRTRY DLNA UPNP Airplay Wireless WiFi Receiver
pas mal
Possesseur d'un systéme airplay, je souhaitai intégrer un vieux systéme ampli analogique afin de disposer d'un systéme multiroom plus étendu. Ce petit appareil rempli pleinement sa fonction, et de façon plus économique qu'une borne airport express.
le réseau wifi est pleinement detecté, seul bémol, il n'aime pas trop les réseaux masqué ( c'est une faiblesse également répandu sur les dongles miracast, ezcast, et "bidules" en cast). Obligation de rendre visible le réseau wifi pour que cela fonctionne.
 (3)
