RaspTouch LVDS - Streamer I2S HDMI Audio-GD Compatible IIS
AUDIOPHONICS RaspTouch Network Player I2S LVDS HDMI Audio-GD Compatible Black
By buying this product you get 36 loyalty points
12030
369,00 €tax incl.
307,50 € tax excl.
Available
Shipping date: 23-01-2018.
Orders placed before 1pm (GMT+1) will be shipped the same day (working day).
Accessories
If you have any doubts about the compatibility and/or functioning of this product, please do not hesitate to contact us.
RASPTOUCH I2S LVDS HDMI
Open Source Raspberry 3 Player - I2S LVDS HDMI
Rasptouch I2S LVDS HDMI
Audiophonics is back with a brand new version of its RaspTouch, designed for experienced audiophiles. It includes a Raspberry Pi 3, an Allo Kali reclocker and an I2S output module for HDMI Audio-GD. So you can enjoy a true HiFi I2S signal and the resulting sound quality.
piCorePlayer
max2play
OSMC
Complete compatibility
Supplied with a Micro SD card for the OS installation, there are many operating system options to choose from, depending on your preferences and needs.
Ready to use electronically, many software solutions exist to meet all your expectations: piCorePlayer, Max2Play, OpenElec...
Multiroom without limits
Do you want to enjoy your music throughout your home? The Rasptouch offers you an efficient multiroom system, allowing you to stream your files on any turntable connected to your network and control them.
I2S LVDS: The ultimate in audio quality
Instead of using the usual signals, this RaspTouch lets you enjoy a clean I2S signal. For example, an I2S FIFO 44 / 48MHz Allo Kali reclocker allows the Raspberry Pi's I2S signal to be processed thanks to an Ultra Low Jitter clock fed by LDO and an ultra-quiet power supply, providing high precision. Your system's performance is fast: your music "opens", your sound scene expands, and you can now see sounds that were previously unheard.
This signal is then routed to an Audio-GD I2S module to HDMI, symmetricating the signal. Just plug in your DAC and enjoy.
Many compatible DACs
To take advantage of your RaspTouch player, simply choose your HDMI DAC, such as Audio-GD DAC-19 or Audio-GD NOS-19. Of course many other models exist. Here is the list of brands by proposing (not exhaustive) :
  • Astin Trew
  • Audio Byte
  • Rockna
  • Javs
  • K&K Audio
  • Love Harmony
  • PS Audio
  • Sonore
  • Stahl Tec Optus DAC
  • Wired 4 Sound
Ergonomic and Design
Featuring a 7"touch screen, it allows you to easily and intuitively control your audio library via a graphical interface..
Mounted in a 100% CNC-machined aluminium housing in France, its black colour and matt appearance give it a modern and contemporary design. A device that will fit perfectly into your high-end audio system.
Connectors
Inputs4x USB-A
1x Ethernet RJ45
1x Micro SD
Outputs1x HDMI I2S LVDS
1x HDMI Vidéo
Raspberry Pi 3
SoCBroadcom BCM2837
CPUARM Cortex-A53 1.2GHz Quadcore
Wifi802.11n
Bluetooth4.1
GPUMultimédia IV Videocore Coprocessor Dual Core
RAMLPDDR2 1Go
Allo Kali
FIFO CircuitWith FPGA
FIFO MemorySRAM 4MB
ClockMulti-frequency clock with automatic comutation and high performances
Voltage regulatorUltra low noise regulator
ScreenCapacitive tactil 7"
Screen resolution800 x 400px
Case colorNoir
Case materialAluminium
Dimensions200 x 95 x 230mm
Weight1440g
MaterialAluminium
ColorNoir
StructureAluminium
Colissimo - TNT - SoColissimo
