AUNE N5 EVO Streamer
The Aune Evo N5 is a network player based on an architecture that favors signal processing using audiophile components. It features an ES9039Q2M DAC chip, an NXP Cortex-M7 processor, an Intel FPGA and a Qualcomm QCC5125 Bluetooth chip, as well as FIFO technology and a dual PLL internal clock for optimized jitter management.
By buying this product you get 42 loyalty points
Reference : 21013
429,00 €tax incl.
357,50 € tax excl.
Aune N5 EVO Streamer ESS9039Q2M WiFi Bluetooth aptX HD LDAC 32bit 768kHz DSD5122
Aune N5 EVO picture
The Aune Evo N5 is a network player based on an architecture that favors signal processing using audiophile components. It features an ES9039Q2M DAC chip, an NXP Cortex-M7 processor, an Intel FPGA and a Qualcomm QCC5125 Bluetooth chip, as well as FIFO technology and a dual PLL internal clock for optimized jitter management. It supports sampling rates up to PCM 32bit 768kHz and DSD512, as well as advanced Bluetooth codecs such as aptX-HD and LDAC, enabling you to enjoy the best audio files available via streaming or your local library. The N5 is compatible with numerous network protocols and streaming platforms: Airplay 2, Spotify, Tidal, Deezer, Qobuz, Amazon Music and more. Its extensive connectivity also makes it an excellent device for transforming your Hi-Fi system into a connected Hi-Fi system.
Aune N5 EVO highlights
Aune N5 EVO: An architecture focused on signal processing precision
The architecture of the Aune N5 EVO offers jitter-free decoding thanks to femtosecond-precision signal processing from 44.1kHz to DSD512. The overall architecture, similar to that of a CD player, focuses solely on signal processing for the cleanest possible rendering. The combination of the Intel FPGA and the ESS9039Q2M DAC chip delivers lossless quality to the N5 EVO's outputs.
Aune N5 EVO architecture
Aune N5 EVO: A gateway to streaming and wireless
The N5 EVO supports numerous streaming protocols, so you can enjoy streaming platforms such as Spotify, Tidal, Deezer and Qobuz, for example. Added to this is AirPlay 2 functionality and a Qualcomm QCC5125 Bluetooth receiver chip supporting the high-definition codecs aptX HD and LDAC for the most reliable and stable wireless playback that also preserves signal quality.
Aune N5 EVO connectivity
Aune N5 EVO: External clock support
A connector on the rear panel of the N5 EVO lets you connect an external clock, further enhancing the device's signal processing performance.
Zoom in on the BNC clock connector on the Aune N5 EVO
Aune N5 EVO overview
1Source selector
2Display
3Multifunction button
4Balanced XLR analog output
5Single-ended RCA analog output
6I2S output via HDMI
7Coaxial output
8Toslink optical output
9Connector for external clock
102x USB DISK input
11Bluetooth antenna
12WiFi antenna
139VDC power supply
14Power switch
Product ypeStreamer
DAC chipES9039Q2M
Bluetooth chipQCC5125
InputsWiFi
Bluetooth
2x USB Disk
Outputs1x Balanced XLR output
1x Single-ended RCA output
1x I2S output via HDMI
1x Coaxial output
1x Toslink optical output
Other connectorBNC connector for external 10MHz clock
Supported sample ratesToslink optical and coaxial: PCM up to 24bit 192kHz, DSD DoP64
I2S via HDMI: PCM up to 32bit 384kHz, DSD up to DSD256
Analog outputs: PCM up to 32bit 768kHz, DSD up to DSD512
Supported bluetooth codecsaptx-HD, LDAC
ConnectivityBluetooth 5.1
WiFi 2.4G
Compatible audio formatsDSD, APE, FLAC, WAV, MP3/WMA/AAC, ALAC/AIFF/CUE
Digital outputs characteristics
THD+N-141.6dB (24bit 44.1kHz)
Jitter171.5ps(24bit 44.1kHz)
Analog outputs characteristics
Frequency response+/- 0.5dB (20Hz-20kHz)
SNR109dB
THD+N @ 1kHz-109dB (24bit 44.1kHz)
Power supply9V DC via jack DC
Dimensions160 x 208 x 63mm
Gross weight1.8kg
Package1x Aune N5 EVO network player
2x Antenna
1x Remote control
1x Mains adapter
InputWiFi
OutputOptical Toslink
OutputI2S LVDS via HDMI
OutputCoaxial SPDIF
DAC / ADC ChipES9039Q2M
Max sampling rateDSD512
Max sampling rate768kHz
Remote ControlYes
Streaming services & Network protocolsSpotify
Streaming services & Network protocolsTidal Connect
Streaming services & Network protocolsQobuz
Streaming services & Network protocolsAmazon Music
Streaming services & Network protocolsDLNA
Streaming services & Network protocolsSpotify Connect
Streaming services & Network protocolsDeezer
Streaming services & Network protocolsUpnP
Streaming services & Network protocolsWeb radios
AUNE N5 EVO Streamer ESS9039Q2M WiFi Bluetooth aptX HD LDAC 32bit 768kHz DSD512
The Aune Evo N5 is a network player based on an architecture that favors signal processing using audiophile components. It features an ES9039Q2M...
