AUNE NC1 EVO OCXO Clock / Linear Power Supply
The Aune Audio NC1 EVO is a high-end audiophile solution combining an ultra-stable 10MHz master clock and a silent linear power supply, designed to optimize the performance of DACs, digital transports, and streamers.
By buying this product you get 42 loyalty points
Reference : 21539
429,00 €tax incl.
357,50 € tax excl.
Aune NC1 EVO 10MHz OCXO Clock Sinusoidal Signal / DC 9V-12V Power Supply
Photo of the Aune NC1 EVO
The Aune Audio NC1 EVO is a high-end audiophile solution combining an ultra-stable 10MHz master clock and a silent linear power supply, designed to optimize the performance of DACs, digital transports, and streamers. Its OCXO oscillator delivers a sinusoidal 10MHz signal (2 outputs) with a level greater than 7dBm into 50Ω, ensuring precise synchronization and effective jitter reduction. In addition, it features two clean and stable DC power outputs (9V 2.5A and 12V 2A) to power sensitive audio equipment. Compatible with numerous devices and sharing the same form factor as the Aune N5 EVO, it integrates perfectly into a high-fidelity audio system. Its robust chassis, low-noise linear power supply, and professional BNC connectivity make it an ideal tool for improving timing accuracy, sonic stability, and overall coherence in demanding digital audio systems.
Aune NC1 EVO: High-precision 10 MHz master clock & exceptional thermal stability
The Aune NC1 EVO integrates a 10MHz reference clock delivered via two high-purity sinusoidal BNC outputs, allowing compatible audio devices to synchronize with remarkable precision (< ±0.02ppm) and an output level exceeding 7dBm into 50Ω. This external timing reference improves digital signal coherence by effectively reducing jitter, contributing to a more stable and realistic soundstage.
Its architecture relies on an OCXO oscillator with extremely high thermal stability, reaching optimal accuracy after a short warm-up period of approximately 5 minutes. This increased stability enhances micro-dynamics, refines spatial precision, and reveals more detail in recordings, resulting in a more natural and immersive sound reproduction.
Aune NC1 EVO: high-precision 10 MHz master clock & exceptional thermal stability
Aune NC1 EVO: Integrated audiophile linear power supply
The NC1 EVO incorporates a low-noise linear power supply capable of powering external equipment with two 9V 2.5A or 12V 2A DC outputs. This clean and stable power delivery reduces electrical interference that could degrade audio performance.
Aune NC1 EVO: integrated audiophile linear power supply
Aune NC1 EVO: Robust audiophile design
The solid metal chassis ensures excellent mechanical and electrical isolation, while the internal construction optimizes the stability of sensitive circuits.
  • Robust shielded enclosure
  • Circuits optimized for minimal noise
  • Construction designed for demanding audiophile environments
Its form factor also allows perfect pairing with the Aune N5 network player.
Aune NC1 EVO: robust audiophile design
Overview of the Aune NC1 clock
1Display On/Off button
2Screen-off LED indicator
3Display
4Multifunction touch button
52x 10MHz sine wave clock outputs
62x Linear DC power outputs 9V/12V
7AC power input
Technical specifications
Product typeClock
Linear power supply
Outputs2× Clock outputs on BNC connectors
2× Power outputs on DC jack
Clock output frequency10MHz
Clock output level10MHz >7dBm (50 ohm)
Clock accuracy< ±0.02ppm
Clock warm-up time5min
Power output current9V 2.5A or 12V 2A DC
Operating impedance0-50 ohm
Recommended operating impedance15-35 ohm
Power supplyAC mains
Dimensions208 x 160 x 63mm
Weight3.5kg
Package contents1x Aune NC1 Evo
1x BNC cable
2x DC power cables
1x AC power cable
InputNC
OutputBNC
OutputJack DC 5.5/2.1mm
Output voltage (V)9.0
Output voltage (V)12.0
Output current (A)2.0
Output current (A)2.5
Input voltage (V)230.0
Power SupplyRegulated Linear Power Supply
AUNE NC1 EVO OCXO 10MHz Clock Sinusoidal Signal / DC 9V-12V Power Supply
The Aune Audio NC1 EVO is a high-end audiophile solution combining an ultra-stable 10MHz master clock and a silent linear power supply, designed to...
