EVERSOLO T8 Streamer Digital Transport
The Eversolo T8 network transport allows you to connect your HiFi system to a network so you can enjoy high-resolution digital sources. Specially designed to deliver a digital stream to an external DAC or integrated amplifier, it supports numerous network protocols. This gives you easy access to various streaming platforms such as Qobuz, Tidal, Amazon Music, and Spotify. It supports high-resolution streams up to PCM 32-bit 768kHz and DSD512.
By buying this product you get 139 loyalty points
Reference : 21117
1 390,00 €tax incl.
1 158,33 € tax excl.
Shipping date: 15-04-2026.
Eversolo T8 Streamer Digital Transport WiFi 6 DLNA UPnP Roon Ready Bluetooth 32bit 768kHz DSD512
Eversolo T8 picture
The Eversolo T8 network transport allows you to connect your HiFi system to a network so you can enjoy high-resolution digital sources. Specially designed to deliver a digital stream to an external DAC or integrated amplifier, it supports numerous network protocols. This gives you easy access to various streaming platforms such as Qobuz, Tidal, Amazon Music, and Spotify. It supports high-resolution streams up to PCM 32-bit 768kHz and DSD512. With no DAC or preamplification, it focuses purely on signal transmission for flawless performance. In addition, the sound can be adjusted via DSP, equalizer, or acoustic calibration for near-perfect sound reproduction. Added to this is a beautiful 6" color LCD touchscreen with a brand new, fluid, and intuitive interface for total control of the T8. In terms of connectivity, it features a full range of digital outputs for nearly universal compatibility.
Eversolo T8: An audiophile design
The Eversolo T8 benefits from high-quality components and a clean architecture. Starting with its linear power supply, which incorporates a shielded and insulated 4N OFC copper toroidal transformer to prevent any perceptible noise. In addition, the clock is accompanied by a femtosecond oscillator with a precision that greatly reduces jitter for clear and dynamic sound reproduction. It should also be noted that each digital output benefits from galvanic isolation and an independent decoupling circuit. Eversolo has done everything possible to ensure optimal signal transmission.
The structure of the Eversolo T8
Eversolo T8: A state-of-the-art device
WiFi 6
WiFi 6
With its high bandwidth, low latency, and excellent interference immunity, WiFi 6 ensures stable and efficient wireless audio transmission for a smooth playback experience.
Quad-Core ARM Processor
Offers powerful multitasking capabilities, combined with high-speed, high-capacity memory for fast caching and processing of large data sets.
Increased RAM and storage
A large amount of RAM (4GB DDR) ensures stable multitasking, while 64GB of built-in storage allows you to store high-quality audio files and system resources.
Eversolo T8: For a connected HiFi system
Thanks to its EOS operating system, the T8 gives you access to numerous streaming apps including Tidal, Qobuz, HighRes Audio, Amazon Music, Spotify, Deezer, Napster, and many more. To top it off, the T8 is compatible with DLNA and UPnP network protocols and is Roon Ready certified for access to your local network music library. Capable of supporting up to PCM 32-bit 768kHz and DSD512, this device is sure to delight enthusiasts of high-resolution files.
Access streaming platforms with the Eversolo T8
Eversolo T8: Bluetooth
In addition to its network connectivity, the T8 has a Bluetooth receiver offering reliable and stable reception via a source such as your phone, tablet, or computer.
Bluetooth functionality of the Eversolo T8
Eversolo T8: DSP, equalization, and acoustic calibration
The T8 features a powerful 10-band equalizer supported by its internal DSP engine, allowing for precise adjustment of the sound output according to the listener's preferences or the characteristics of their HiFi system. A handy feature allows users to create and save various curve profiles for easy retrieval. In addition, the Evotune automatic calibration system is integrated into the T8. Using microphones and an algorithm, it analyzes the acoustics of the room and applies a correction to optimize the curve for balanced sound. Calibration can be performed using the brand's EM-01 microphone or a smartphone via the Eversolo Control app.
DSP, equalization, and acoustic calibration of the Eversolo T8
16TB expansion of the Eversolo T8
Eversolo T8: 16TB expansion
The two SSD slots support up to two 8TB external SSDs, providing a possible total of 16TB of storage—enough space to store tens of thousands of lossless, master-quality audio files.
Please note that SSDs are not included with the T8.
Eversolo Control Application
Eversolo T8: Eversolo Control app
The Eversolo app has been redesigned for an even more intuitive and seamless experience. It is supported by iOS, Android, and macOS, allowing you to control the T8 in all circumstances.
Eversolo T8: Sophisticated ergonomics and design
The T8 features a sturdy metal chassis and a reinforced 6" (15 cm) LCD touchscreen. It has a new, smooth and attractive interface that allows you to easily access the device settings and your music. Several display styles are available for complete customization of the T8. As an added bonus, numerous VU meters are available for display.
The aesthetics of the Eversolo T8
Eversolo T8 overview
Overview of the Eversolo T8
1Mains power supply
2SPF fiber input
3Gigabit LAN input
4USB-A 3.0 / USB-A 3.0 OTG input
5Isolated USB-A 3.0 output
6AES/EBU output
7Toslink optical output
8Coaxial output
9I2S output via HDMI
10Trigger IN/OUT (12V)
Eversolo T8: 8 I2S output modes
The I2S output via HDMI has 8 different output modes to ensure compatibility with most DACs on the market.
Les modes de sortie HDMI I2S du Eversolo T8
Product typeNetwork transport
InputsWiFi
1x RJ45 Ethernet port
1x SFP Ethernet port
1x USB-A 3.0 OTG input
1x USB-A 3.0 input
Outputs1x Isolated USB-A output
1x HDMI I2S output
1x Toslink optical output
1x Coaxial output
1x AES/EBU output
Other connectorsTrigger in
Trigger out
Supported sample ratesUSB and HDMI I2S outputs: PCM up to 32bit 768kHz, DSD up to DSD512
Coaxial, optical and AES/EBU outputs: PCM up to 24bit 192kHz, DSD DoP64
Supported audio formatsDSD (DSF, DFF, SACD ISO Supports DST up to DSD512)
MP3,APE,WAV,FLAC,AIF,AIFF,AAC,NRG,CUE
WiFiWi-Fi 6 (2.4G+5G dual band)
SFP fiber optic networkSFP modules are not included. Supports single-fiber single-mode, dual-fiber single-mode optical modules, and SFP network communication modules.
Streaming servicesTIDAL, Qobuz, HIGHRESAUDIO, Amazon Music, Roon Ready, TIDAL Connect,Qobuz connect, DLNA, NAA HQ Player, etc.
Supported network protocolsUPnP, NAS, SMB
Screen6" color LCD touchscreen
Internal memory4G DDR4 +64G eMMC
Memory expansionDual rack for SSDs up to 16 TB (2 x 8 TB)
Power supplyAC 110–240V, 50/60Hz
Energy consumption20W
Dimensions315 x 230 x 88mm (LWH)
Package1x Eversolo T8 Network Streamer
1x Remote control
1x AC power cable
InputWiFi
OutputI2S LVDS via HDMI
OutputAES/EBU
OutputOptical Toslink
OutputCoaxial SPDIF
OutputUSB
DAC / ADC ChipNC
Max sampling rate768kHz
Max sampling rateDSD512
Remote ControlYes
Streaming services & Network protocolsTidal Connect
Streaming services & Network protocolsDeezer
Streaming services & Network protocolsSMB
Streaming services & Network protocolsUpnP
Streaming services & Network protocolsWeb radios
Streaming services & Network protocolsQobuz Connect
Streaming services & Network protocolsSpotify Connect
Streaming services & Network protocolsRoon / Roon Bridge / Roon Ready
Streaming services & Network protocolsHQPlayer NAA
Streaming services & Network protocolsAmazon Music
Streaming services & Network protocolsBubble UpnP
Streaming services & Network protocolsDLNA
3 reviews
great streamer for its price
I'm not going to surprise anyone by saying that the environment and functionalities of this streamer are great, but what really caught my attention was what I didn't expect, which is encountering superb sound quality. It is true that I have it connected to the internet via fibre optic and that I use a reference USB cable, which is how it works best with my Gustard X26 iii DAC, and the sound has made a very significant quality leap, especially in phase accuracy, which makes the sound much more three-dimensional and spatial, separating each instrument in a large stage. Great streamer at a fantastic price.
This review has been posted for EVERSOLO T8 Streamer Digital Transport WiFi 6 DLNA UPnP Roon Ready Bluetooth 32bit 768kHz DSD512
Eversolo T8
En remplacement d'un streamer Dac intégré préampli Gold note j'ai commandé l'Eversolo T8 désirant séparé la partie streamer de la partie DAC pour améliorer les performances de mon système.
Je possède un dac intégré dans mon ampli préampli intégré et je voulais dans un premier temps pouvoir l'exploiter et évoluer si nécessaire vers un Dac indépendant.
L'Eversolo possède une interface très intuitive et facile à mettre en oeuvre. Cela m'a pris 10 mn pour le mettre en service.
Je l'ai connecté en RJ45 puis en wifi cette dernière liaison me permet d'isoler le streamer électriquement de la box.
J'ai testé la liaison coaxiale et USB pour l'instant je n'ai pas encore pu déterminer laquelle était la meilleure.
L'Eversolo T8 permet d'entendre toutes les micro-informations présentent sur l'enregistrement. Cela est dû déjà à un silence de fonctionnement total. La dynamique permet de vivre l'enregistrement. L'étalement des plans sonores en largeur et en profondeur est parfait.
Pour l'instant j'ai utilisé le streamer seulement en streaming sur Qobuz. La lecture est parfaite sans aléa de lecture.
Je ne regrette aucunement mon achat Je peux qualifier ce streamer de très haut gamme. La technologie embarquée est de premier ordre avec une isolation de toute les interfaces qu'on ne retrouve que très peu sur d'autres appareils à ma connaissance.
Le RQP est excellent. Il n'y a pas de concurrence à ce prix.
Prochaine étape essayer le Dac Z10 pour savoir si il surpasse mon Dac intégré.
J'en profite pour remercier David Aubert qui répond toujours rapidement et sincèrement à mes questions
Dominique
 (3)
Stunning music streamer
Pros:
Excellent audio signal output (especially I2S).
Easy configuration (in 10 minutes unit is ready for use).
List of supported music streaming services, apps and connectivity.
Silent unit (zero noise, black background).
Fast and stable mobile app.
Software updates.
Cons:
Upsampling feature (preferable in DSD) in future software releases.
 (5)
The Eversolo T8 network transport allows you to connect your HiFi system to a network so you can enjoy high-resolution digital sources. Specially...
