MYTEK BROOKLYN BRIDGE Streamer DAC MM/MC Phono Preamplifier ES9028Pro 32bit 384kHz DSD256 MQA
The Mytek Brooklyn Bridge is a resolutely audiophile network player with numerous features and compatible with a multitude of high-resolution audio formats. It supports PCM streams up to 32bit 384kHz, DSD up to DSD512 but also MQA. Particularly versatile, the Brooklyn Bridge also supports DAC, phono preamplifier and headphone amplifier functions.
By buying this product you get 279 loyalty points
Reference : 14848
2 790,00 €tax incl.
2 325,00 € tax excl.
Streamer DAC MM/MC Phono Preamplifier 32bit 384kHz DSD256 MQA
Mytek Brooklyn Bridge Lecteur Réseau DAC Préamplificateur Phono MM/MC 32bit 384kHz DSD256 MQA
The Mytek Brooklyn Bridge is a resolutely audiophile network player with numerous features and compatible with a multitude of high-resolution audio formats. It supports PCM streams up to 32bit 384kHz, DSD up to DSD256 but also MQA. Particularly versatile, the Brooklyn Bridge also supports DAC, phono preamplifier and headphone amplifier functions.
Its numerous inputs allow the connection of the vast majority of HiFi devices. We find USB-B, Coaxial SPDIF, Toslink Optical, USB-A and RJ45 Ethernet. These inputs are complemented by a powerful WiFi connectivity allowing you to stream your music in high quality. Outputs include unbalanced RCA, balanced XLR and two 6.35mm headphone outputs, capable of delivering a substantial 6W of power.
The Brooklyn Bridge is an ideal choice for integration into a high-end audio system, providing incredibly accurate, rich, and dynamic sound reproduction, thanks to its well-designed circuitry.
A high-performance conversion stage
The Brooklyn Bridge's conversion stage is based on an ESS Sabre 9028Pro chip, known and recognized by audiophiles for its audio performance. It provides full support for the vast majority of high-resolution file formats such as DSD, DXD, MQA and PCM up to 32bit 384kHz. Renowned for its precision, low noise and high dynamic range, this DAC will help you get the most out of your music. It is here associated with an extremely precise clock generator to obtain a very low jitter of 0.82ps. When the Brooklyn Bridge is used in USB with a computer, its DAC is coupled to an NXP controller, ensuring an incredibly accurate digital to analog conversion.
Integrated phono preamplifier
In addition to its DAC function, the Mytek Brooklyn Bridge also includes a phono preamplification stage. This uses a specifically selected transformer associated with a relay to select the input level. The device is therefore compatible with boards having a MM (Moving Magnet) or MC (Moving Coil) cell.
This phono preamplifier can also be turned off, in order to use a preamplified vinyl turntable or any other HiFi device, such as a CD player.
Optimal Connectivity
Equipped with a dual Ethernet and WiFi network controller, the Brooklyn Bridge makes it easy to stream music stored on the network from a computer, smartphone or tablet. Many streaming services are also compatible, such as Qobuz or Tidal. A USB-A port allows it to connect a storage device, such as a hard drive or USB key. Playback control is then performed intuitively from a device with the Roon application.
Powerful headphone amplifier
Also benefiting from two headphone outputs in Jack 6.35mm format, the Brooklyn Bridge will also allow you to enjoy a very high quality headphone listening. Its impedance of 0Ω and its important power of 6W allows it to efficiently accompany the great majority of headphones and earphones, including the most demanding models. This dual headphone output can also be switched to a balanced output.
Product typeStreamer
DAC
Preamplifier / Phono preamplifier
Headphone amplifier
DAC ChipES9028Pro
Inputs1x USB-B : PCM up to 384kHz, DSD up to DSD128 / DoP
2x SPDIF Coaxial : PCM up to 24bit 384kHz, DSD up to DSD128 / DoP
1x Optical Toslink : PCM up to 24bit 176kHz, DSD up to DSD64 / DoP
1x RJ45
1x USB-A Host
1x Stereo RCA
Phono GND terminal
1x Trigger Jack 3.5mm
1x Balanced stereo XLR
2x Jack 6.35mm headphone output
ConnectivityEthernet Cat 5 : PCM up to 24bit 192kHz, DSD up to DSD64
WiFi : PCM up to 24bit 192kHz, DSD up to DSD64
DSD up to DSD256
DXD
MQA Support
Dynamic range130dB
ClockMytek Femtoclock Generator™
0.82ps
Headphone amplifier power6W
Analog attenuator1dB step
Independent main and headphone output volume
Digital attenuator32bit
1dB step
Relay bypass
Analog preamplifierLine level
Phono MM / MC
Relay control
Audio interface functionAll digital inputs can be routed to a computer via USB
Dimensions216 x 44 x 216mm
Weight2kg
Package1x Mytek Brooklyn Bridge
1x Remote control
1x USB Cable
InputRJ45
InputWiFi
OutputJack 6.35mm
ClassN/A
Remote ControlYes
The Mytek Brooklyn Bridge is a resolutely audiophile network player with numerous features and compatible with a multitude of high-resolution audio...
