RaspTouch LTE I-Sabre V2 Back side - Streamer touch Raspberry Pi & DAC ES90023
By buying this product you get 31 loyalty points
Reference : 12252
319,00 €tax incl.
265,83 € tax excl.
Rasptouch LTE
AUDIOPHONICS RASPTOUCH LTE ES9023, UN MUST HAVE
The Audiophonics team is proud to present its new version of RaspTouch, the RaspTouch LTE. Based on a Raspberry Pi 3and oneDAC I-Sabre ES9023, it offers an out-of-pair compatibility with many platforms, allowing you to enjoy your entire library. Its new, redesigned design offers a space-saving and flexible solution with a back cover for a professional finish.
This version also includes a power management for PI3 with a Power ON / OFF button. It becomes a truly stand-alone solution with a piCorePlayer distribution.
rasptouch LTE
COMPLETE COMPATIBILITY
Logitech Media Server
iPeng Squeezer DLNAAirplay
Comes basic with piCorePlayer installed, this operating system allows you to enjoy just the whole of your audio library. So, whether your music is physically stored on a hard drive connected to your Raspberry Pi or on a server, you can access it without any limitation while enjoying your I-Sabre ES9023 DAC. </ P>
More than that, it works with the coupleSqueezeliteandLogitech Media Serverto transform your RaspTouch LTE into true network drive , allowing you to remotely control your system. Even better, you can download and use applications like iPengorSqueezerin order to control your player with your smartphone, directly from your sofa.
Finally, to ensure more compatibility, your device is compatible UPnP,DLNAandAirplay, allowing you to simply stream your content to your turntable.
THE MULTIROOM WITHOUT ANY LIMIT
Want to enjoy your music throughout your home? The RaspTouch LTE takes care of this by offering an efficient multiroom system, allowing you to stream your files on any deck connected to your network and to control them.br>
ACCESSIBLE HIGH FIDELITY
Based on a DAC I-Sabre ES9023capable of converting sampling rates up to 24bit / 192kHz and equipped with Ultra-low noise regulators and Low ESR filter capacitors, the RaspTouch LTE is definitely a high-end audio / video deck.
ERGONOMY BEFORE ANYTHING
Raspberry Pi 3, DAC I-Sabre ESS 9023 and 7 "Raspberry official touch screen allows you to tilt or fix your deck as you wish, in order to adapt to your use and your environment This version BS V2 features a rear protection for an impeccable finish.
pivotable support SmartiPi
Connections: Inputs
USB-A4x
Ethernet RJ451x
Micro USB-B (Power supply)1x
Slot Micro SD1x
Connection: Output
RCA Stereo1x
I-Sabre ES9023
Sampling24bits 192kHz
<controllers/ Td>Ultra Low Noise
Filter CapacitorsLow ESR
Raspberry Pi 3
chipsetARM Cortex A53 64bit 4 cores
Wireless LAN802.11 b / g / n
Bluetooth4.1
Multimedia coprocessor IV Videocore dual core
MemoryLPDDR2 1 GB
Screen & Support
Screen7 '' capacitive touch 10 fingers
Resolution800 x 400px
SupportReclining SmartiPi
Power On / Off Button
Various
Weight548G
Dimensions22 x 9.7 x 13.8
FoodMicro USB 5V 3A
