By buying this product you get 31 loyalty points
The Audiophonics team is proud to present its new version of RaspTouch, the RaspTouch LTE. Based on a Raspberry Pi 3and oneDAC I-Sabre ES9023, it offers an out-of-pair compatibility with many platforms, allowing you to enjoy your entire library. Its new, redesigned design offers a space-saving and flexible solution with a back cover for a professional finish.
This version also includes a power management for PI3 with a Power ON / OFF button. It becomes a truly stand-alone solution with a piCorePlayer distribution.
Comes basic with piCorePlayer installed, this operating system allows you to enjoy just the whole of your audio library. So, whether your music is physically stored on a hard drive connected to your Raspberry Pi or on a server, you can access it without any limitation while enjoying your I-Sabre ES9023 DAC. </ P>
More than that, it works with the coupleSqueezeliteandLogitech Media Serverto transform your RaspTouch LTE into true network drive , allowing you to remotely control your system. Even better, you can download and use applications like iPengorSqueezerin order to control your player with your smartphone, directly from your sofa.
Finally, to ensure more compatibility, your device is compatible UPnP,DLNAandAirplay, allowing you to simply stream your content to your turntable.
Want to enjoy your music throughout your home? The RaspTouch LTE takes care of this by offering an efficient multiroom system, allowing you to stream your files on any deck connected to your network and to control them.br>
Based on a DAC I-Sabre ES9023capable of converting sampling rates up to 24bit / 192kHz and equipped with Ultra-low noise regulators and Low ESR filter capacitors, the RaspTouch LTE is definitely a high-end audio / video deck.
Raspberry Pi 3, DAC I-Sabre ESS 9023 and 7 "Raspberry official touch screen allows you to tilt or fix your deck as you wish, in order to adapt to your use and your environment This version BS V2 features a rear protection for an impeccable finish.
| Connections: Inputs | |
| USB-A | 4x |
| Ethernet RJ45 | 1x |
| Micro USB-B (Power supply) | 1x |
| Slot Micro SD | 1x |
| Connection: Output | |
| RCA Stereo | 1x |
| I-Sabre ES9023 | |
| Sampling | 24bits 192kHz |
| <controllers/ Td> | Ultra Low Noise |
| Filter Capacitors | Low ESR |
| Raspberry Pi 3 | |
| chipset | ARM Cortex A53 64bit 4 cores |
| Wireless LAN | 802.11 b / g / n |
| Bluetooth | 4.1 |
| Multimedia coprocessor IV Videocore dual core | |
| Memory | LPDDR2 1 GB |
| Screen & Support | |
| Screen | 7 '' capacitive touch 10 fingers |
| Resolution | 800 x 400px |
| Support | Reclining SmartiPi |
| Power On / Off Button | |
| Various | |
| Weight | 548G |
| Dimensions | 22 x 9.7 x 13.8 |
| Food | Micro USB 5V 3A |
