By buying this product you get 449 loyalty points
Media Center DAC SABRE ES9038PRO 32bit 768kHz DSD512 MQA Bluetooth WiFi DLNA AirPlay Black
Rose's RS150 is a high-performance network player and media center, offering a wide range of multimedia services as well as exceptional sound quality and support for ultra high-resolution video.
The digital/analogue conversion stage incorporates the excellent SABRE ES9038PRO DAC chip. This supports high resolution files up to 32bit 768kHz PCM and up to DSD 512 (Native). In addition, taking advantage of the proprietary Velvet Sound technology, this chip provides excellent measurements with a low noise level, for an exceptionally rich and dense sound reproduction.
The entire unit has been calibrated and adjusted by experienced acoustic engineers for perfect reproduction across the entire audio spectrum, from deep, intense lows to elegant highs.
The linear power supply stage of the Rose RS150 benefits from an intelligent design to significantly reduce electrical noise in order to provide the various circuits with a clean electrical signal for distortion-free sound reproduction.
The RS150 also features a high-precision femtosecond clock, drastically limiting distortion while providing a wide and accurate sound image.
All the components of the RS150 are concealed under a magnificent high-purity solid aluminium chassis, which promotes efficient heat dissipation. The number of parts in this chassis is also considerably limited in order to limit the impact of vibrations that could alter sound reproduction.
Rose's Media Center supports Master Quality Authenticated (MQA) technology through an integrated decoder. This award-winning British technology delivers the sound of the original master recording. The file is authenticated by the record company, artist or rights holders. In addition, this type of file is light enough to be streamed.
The RS150 also allows you to enjoy Ultra HD 4K video, stored locally or via the Rose Tube application, thanks to its HDMI output. Ideal for a Home Theater system!
The front of the device features a beautiful, large 14.9" IPS touch screen for intuitive navigation through the RS150's ergonomic interface.
The Rose RS150 can therefore be controlled not only via its touch screen, but also with the dedicated Rose Connect application, available free of charge on Android and iOS devices. This allows you to play your music and videos locally or from a network location.
The device can also be controlled using the supplied Bluetooth remote control, which is particularly convenient for operating the device directly from the sofa.
The RS150 features the Rose OS operating system, enabling an innovative music experience. It allows you to stream and play your music in ultra high quality, enjoy support for 4K videos, a commercial-free YouTube application, as well as many radio stations, manage CD playback and burning (via an external drive) and much more!
The RS150 allows you to stream your audio or video files very simply. The device supports AirPlay and DLNA protocols and allows you to connect smartphones, tablets and computers via WiFi, Ethernet or Bluetooth.
In addition, its rear panel offers a particularly complete panel of connectors, which will meet the vast majority of needs for integration into all audio / video systems.
Designed to hold sufficient storage for your HiFi audio files, the RS150 is compatible with SSDs up to 4TB, external HDDs up to 10TB or Micro SD cards up to 400GB. It also allows the connection with a NAS.
| Specifications | |
| Product type | Media Center |
| Audio inputs | 1x Coaxial SPDIF 1x Optical Toslink 1x AES/EBU 1x USB-B 2.0 1x HDMI ARC 1x Line stereo RCA input |
| Audio outputs | 1x Pre-Out Single-ended stereo RCA 1x Pre-Out Balanced XLR 1x Coaxial SPDIF 1x Optical Toslink 1x AES/EBU 1x I2S via DVI 1x I2S via RJ45 |
| Video output | 1x HDMI 2.0 (up to 3840 x 2160px / 60Hz) |
| Network connectivity | Ethernet RJ45 10/100/1000 BASE-T WiFi via USB dongle (sold separately) |
| Bluetooth connectivity | Bluetooth via USB dongle (A2DP Sink, AVRCP v1.3) (sold separately) |
| Media connection | File system: SMBv1, SMBv2 / FTP / WebDav / NTFS / eXfat / FAT32 Connectors : 2x USB-A 3.0, 1x Micro SD, 1x SSD |
| Supported streaming protocols | AirPlay DLNA Roon Ready MQA Full Decoder |
| Supported streaming services | TIDAL Radio internet Podcast |
| Supported audio codecs | WAV, FLAC, AIFF, WMA, MP3, OGG, APE, DFF, DSF, AAC, CDA, AMR, APE, EC3, E-EC3, MID, MPL, MP2, MPC, MPGA, M4A PCM up to 32bit 384kHz Native DSD up to DSD512 |
| Supported video codecs | ASF, AVI, MKV, MP4, WMV, MPEG-1, MPEG-2, MPEG-4 H.263, H.264, H.265, VC-1, VP9, VP8, MVC H.264/AVC, Base/Main/High/High10 profile @ level 5.1 up to 4Kx2K @ 30fps H.265/HEVC, Main/Main10 profile @ level 5.1 High-tier up to 4Kx2K @ 60fps |
| OS | Rose OS V1.22.4 (base on a custom version of Android 7.1) |
| CPU | Hexa Core CPU Dual Core Cortex-A72 up to 1.8GHz Quad-Core Cortex-A53 up to 1.4GHz |
| GPU | Mali-T864 OpenGL ES 1.1/2.0/3.0/3.1 OpenVG1.1 OpenCL DX11 |
| RAM | LPDDR3 4GByte |
| DAC chip | SABRE ES9038PRO |
| Supported sampling rates | PCM up to 32bit 768kHz Native DSD up to DSD512 |
| DAC Technology | Velvet Sound |
| THD+N DAC | -124dB |
| Dynamic range DAC | 134dB |
| SNR DAC | 134dB |
| Output level | Single-ended : 4.5Vrms Balanced : 9Vrms (no load) |
| SNR | Single-ended : 117dB @1kHz Balanced : 120dB @ 1kHz |
| THD+N | Single-ended : 0.0005% @ 1kHz Balanced : 0.0003% @ 1kHz |
| THD | Single-ended : 0.0003% @ 1kHz Balanced : 0.0002% @ 1kHz |
| Software update | Via internet Via USB OTA Via Rose Store |
| Remote control | Bluetooth remote control Rose Connect app (Android, iOS) |
| General | |
| Supply voltage | AC 100-230V 50/60Hz |
| Input power | 55W |
| Fuse | T3.0AL/250V |
| Dimensions | 430 x 316 x 123mm |
| Weight | 13kg |
| Case material | Designed in a solid block of high purity aluminium, minimizing vibrations. |
| Color | Black |
| Package | 1x Rose RS150 1x Power cable 1x Bluetooth remote control 4x SSD Screws |
| Input | Bluetooth |
| Input | HDMI |
| Input | AES/EBU |
| Input | RCA |
| Input | Optical |
| Input | RJ45 |
| Input | WiFi |
| Input | SPDIF |
| Output | XLR |
| Output | HDMI |
| Output | Bluetooth |
| Output | AES/EBU |
| Output | RCA |
| Output | I2S via DVI |
| Output | Coaxial SPDIF |
| Output | RJ45 |
| Output | WiFi |
| Output | Optical Toslink |
| Output | I2S via RJ45 |
| DAC / ADC Chip | AK4499 |
| Color | Black |
| Remote Control | Yes |
| Streaming services & Network protocols | DLNA |
| Streaming services & Network protocols | Roon / Roon Bridge / Roon Ready |
| Streaming services & Network protocols | Web radios |
| Streaming services & Network protocols | AirPlay |
| Streaming services & Network protocols | Tidal |
