With the TC44PRO M3, ddHifi presents a portable DAC based on two CS43198 DAC chips from Cirrus Logic with a sleek design and a 3.5mm and 4.4mm jack output. This small portable DAC is capable of handling a signal up to PCM 32bit 384kHz and DSD256, and is designed to accompany you wherever you go and adapt to any situation.
The BC44NET cable from ddHiFi is fitted with gold-plated 4.4mm jack connectors on both ends to provide foolproof protection against corrosion and oxidation. At 15cm long, it's ideal for short interconnects, such as connecting a DAP.
With the EM-01, Eversolo presents an omnidirectional electret microphone specially developed to work with Eversolo streamers for acoustic calibration of the listening environment. However, the very good performance of this microphone also makes it an excellent tool in a much wider range of situations, from studio recording to broadcasting.
The Audio-Technica ATH-S300BT headphones, big brother of the ATH-S220BT, are closed, dynamic wireless headphones whose main strength lies in their 90-hour battery life, without sacrificing the quality of the sound they deliver. In fact, a Ø40mm transducer delivers clear, immersive sound for a qualitative listening experience, whether musical or...
The Audio-Technica ATH-AD500X are dynamic open-air headphones featuring no less than Ø53mm drivers for clear, immersive sound reproduction. These headphones offer powerful midrange and low-frequency reproduction thanks to CCAW coils developed by Audio-Technica.
The Wondom JAB3+ is an amplifier module capable of delivering 1x100W of power, supporting Bluetooth 5.0 (aptX HD) and incorporating an ADAU1701 DSP for an all-in-one audio solution. Thanks to this DSP, JAB3+ can be programmed with SigmaStudio and controlled via an intuitive graphical interface (requires the use of a Wondom ICP5 module, not supplied).
The DAX88 lets you connect up to eight control keyboards per device. With the DAX88HUB, you can connect all your keyboards to the DAX88 with a single Ethernet connection.
With the DKT4X25AB, Wondom offers a DIY kit to assemble a 4x25W Class AB amplifier module yourself. Designed with a TDA7569BLV chip, this kit offers an output of 25W per channel at 4Ω and has been designed for use as a car radio amplifier. Equipped with a robust heatsink, the DKT4X25AB benefits from an optimal cooling design for increased durability...
This protective leather case has been specially designed to provide effective protection for the Shanling UP6 DAC, while allowing convenient access to all the device's controls.
Viablue SC-6 AIR jumpers provide an optmale connection between the terminals of your bi-wirable speakers. Designed with AIR technology, these jumpers guarantee interference- and loss-free signal transmission, providing natural, dynamic sound reproduction.
The Kiwi Ears Allegro Mini portable DAC / headphone amplifier is a small device that can support high-resolution streams up to PCM 32bit 384kHz and DSD128, and is capable of delivering up to 30mW under 32Ω. This means you can enjoy high-resolution files and drive a wide range of headphones and earphones available on the market.
With the Audiophonics Pulsar DIN 5-pin cable, we offer you a carefully designed cable, using top-quality components and assembled by hand in our workshops in France.
The Fosi Audio K7 is a compact, high-performance DAC/headphone amplifier featuring an original design and high-quality components. It features an XMOS XU208 USB interface, an AKM AK4493SEQ DAC chip for its digital-to-analog conversion stage, and a balanced amplifier circuit with two TPA6120 chips and OPA1612 OPAs. The Fosi Audio K7 is therefore capable of...
Danville Signal's dspNexus is a state-of-the-art digital audio processor (DSP), designed to serve as a versatile control center in modern audio systems. It incorporates advanced features to optimize sound quality and audio source management. Thanks to its advanced DSP technologies and high-precision data converters, the dspNexus offers outstanding sound...
Kiwi Ears KE4 are hybrid in-ear monitors combining two dynamic drivers and two Balanced Armature drivers, designed to deliver natural, precise and immersive sound reproduction.
Tanchjim Zero Ultima in-ear monitors offer exceptional performance at an affordable price. Each earphone features a DMT 4 Ultra dynamic driver with titanium-plated composite cone and PU suspension, plus a dual acoustic chamber. This combination delivers precise, transparent sound.
Jantzen Audio resistors in the Superes series offer the highest quality at an affordable price. They offer excellent temperature tolerance and shock resistance. These resistors have long been used by high-end audio manufacturers and DIY enthusiasts alike.
With the DKT2X20D, Wondom offers a DIY kit to assemble a 2x20W Class D amplifier module yourself. Designed with two MP7720 AMP integrated circuits, this kit offers an output of 20W per channel at 4Ω, guaranteeing high-fidelity sound with low noise and high efficiency.
With the DKT2X20AB, Wondom offers a DIY kit to assemble a 2x20W Class AB amplifier module yourself. Designed with a TDA7576B chip, this kit offers 20W output per channel at 4Ω, guaranteeing high-fidelity sound with low noise. Equipped with a robust heatsink, the DKT2X20AB benefits from an optimal cooling design for increased durability and longevity.
With the Shanling ONIX Zenith XST20, Shanling has unveiled a new top-of-the-range CD transport with a luxurious design and high-performance components. In addition to a striking aluminium chassis, it is equipped with Sanyo DH870 laser optics and is capable of reading CD, SACD and MQA CDs. Finally, for the best possible experience, the ONIX Zenith...
The SMSL C200 Pro is a versatile, high-performance DAC / headphone amplifier based on market-renowned audiophile components. It incorporates an ES9039Q2M DAC chip, an XMOS XU316 USB interface and no fewer than four OPA1612A OPAs. This enables it to support high-definition sampling rates up to PCM 32bit 768kHz and DSD512, while delivering headphone output...
This eARC HDMI switch/splitter offers extensive connectivity and exceptional flexibility to suit all multimedia configurations. It supports a wide range of HDMI sources, such as game consoles, computers, TVs and projectors.
The Moondrop Echo-A is a compact, high-performance USB-C to 3.5mm jack adapter designed to deliver a high-resolution audio experience with ease. It incorporates a DAC/headphone amplifier chip capable of supporting sampling rates up to PCM 32bit 384kHz.
The Moondrop Echo-B is a compact, high-performance USB-C to 4.4mm balanced jack adapter, designed to deliver a high-resolution audio experience with ease. It incorporates a DAC/headphone amplifier chip capable of supporting sampling rates up to PCM 32bit 384kHz.
The 6SN7GTB Tung-Sol tube is a double triode tube that benefits from a beautiful design thanks to quality materials. This model has identical characteristics to the 6SN7GTA series tubes, and features 8 pins.
This compact digital interface converts a SPDIF coaxial signal to Toslink optical and vice versa. What's more, it integrates an RCA output and a 3.5mm headphone output, capable of driving headphones with impedances from 16 to 300Ω.
The Kiwi Ears Orchestra Lite in-ear monitors have been designed on the same basis as the original Orchestra, but have been redesigned for greater performance and value. Orchestra Lite IEMs also feature eight Balanced Armature drivers and excellent tonal balance.
The MINIDSP Pocket ADC is an analog-to-digital converter featuring a stereo RCA analog input and two digital outputs, a Toslink optical output and a coaxial SPDIF output. Thanks to a DIP switch on one of the front panels, it can convert at several sampling rates up to PCM 24bit 192kHz.
The Tanchjim Stargate 2 is a portable DAC and headphone amplifier with USB-C male and Jack 3.5mm female connectors. It's ideal for enjoying high-quality listening on a smartphone without a 3.5mm headphone output.
This 13cm-long USB-C male to USB-C male flat cable lets you easily connect your phone to a portable battery or DAC, while minimising the space taken up by the cable. The cable is USB 4 standard, offering transfer speeds of up to 40Gbps, support for 8K 60Hz video streaming and the ability to support up to 240W of power.
The O-Noorus D4 is a powerful integrated amplifier, based on high-quality components. It incorporates an ES9023P DAC chip, a TPA3255 amplifier chip and DIP8-mounted OPA1642 OPAs. As a result, the D4 supports PCM up to 24bit 192kHz via its various digital inputs, and delivers up to 2x260W into 4 ohms, enabling it to soundtrack a sizeable space.
We offer you a WiiM x Audiophonics product pack comprising the Wiim Ultra audio streamer, an AP300-S500NC amplifier, a pair of RCA modulation cables and a trigger cable. This pack will give you a connected system with plenty of power reserve and excellent sound quality.
The Texas Instrument LM4562 OPA is designed for high-fidelity use, and its low distortion of 0.00003% coupled with a noise level of just 0.34μV makes it the perfect candidate for your DIY HiFi projects.
