Filters
Categories level 1
Brand
In stock
Emmanuel p.
worth it
cher, mais nécessaire pour adapter un double XLR 3 pôles vezrs un XLR 4 pôles d'un Topping A90
Emmanuel p.
ça vaut l'upgrade
de D90 à A90, et en utilisant l'équalization autoeq.app plus des sorties symmétriques, on a un superbe résultat
Alexander G.
All around great little box
This is a versatile and neat little box. Compact chassis, integrated power supply, nice display, easy menu navigation, good...
New products
  • Ref : 21075
    In Stock
    The Moondrop Pill are OWS (Open Wearable Stereo) clip-on earbuds with a futuristic design and a transparent capsule-shaped charging case. The clip-on design is ideal for comfortable wear and a secure fit, perfect for listening on the go or during a workout.
    44,90 € 37,42 €Ex.
    In Stock
  • Ref : 21076
    In Stock
    44,90 € 37,42 €Ex.
    In Stock
  • Ref : 21133
    This Mundorf VL300 coil is build from massive copper wires specially developed to help improve the audio quality when it comes to speaker filtering. This format belongs to Mundorf 's family of high-fidelity components the series of which is made for professional studio use.
    49,90 € 41,58 €Ex.
    In Stock
  • Ref : 21134
    64,90 € 54,08 €Ex.
    In Stock
  • Ref : 21135
    59,90 € 49,92 €Ex.
    In Stock
  • Ref : 21136
    69,90 € 58,25 €Ex.
    In Stock
  • Ref : 21137
    79,90 € 66,58 €Ex.
    In Stock
  • Ref : 21138
    89,90 € 74,92 €Ex.
    In Stock
  • Ref : 21139
    99,90 € 83,25 €Ex.
    In Stock
  • Ref : 21069
    In Stock
    44,90 € 37,42 €Ex.
    In Stock
  • Ref : 21052
    In Stock
    The UcPure Mini Solo from Ian Canada is a high-voltage power supply with supercapacitors specially designed for sensitive analogue audio applications. Operating in purely passive mode, it contains no active components or negative feedback, ensuring that the output is completely isolated from the input. With its low 1/f noise, minimal ESR and compatibility...
    229,00 € 190,83 €Ex.
    In Stock
  • Ref : 21068
    In Stock
    The UcPure Mini Dual from Ian Canada is a high-voltage power supply with supercapacitors specially designed for sensitive analogue audio applications. Operating in purely passive mode, it contains no active components or negative feedback, ensuring that the output is completely isolated from the input. With its low 1/f noise, minimal ESR and compatibility...
    389,00 € 324,17 €Ex.
    In Stock
  • Ref : 21047
    In Stock
    The Gustard R30 is a DAC, streamer and preamplifier based on an R2R ladder resistor network to offer high-precision digital-to-analogue conversion, supporting PCM up to 32-bit 1536kHz and DSD up to DSD1024 for faithful and detailed reproduction. Its extensive connectivity allows it to be integrated into a wide range of audio setups. Based on CelWare 3.x...
    3 590,00 € 2 991,67 €Ex.
    In Stock
  • Ref : 21050
    In Stock
    In Stock
  • Ref : 21018
    The USB DD HIFI TC19CC is a USB cable with a high-end audiophile design. It features DATA conductors made of 4N monocrystalline pure silver and load conductors made of silver-plated OFC 5N copper, all implemented in a parallel structure with 4 flat conductors.
    59,00 € 49,17 €Ex.
    In Stock
  • Ref : 21020
    In Stock
    64,90 € 54,08 €Ex.
    In Stock
  • Ref : 21021
    In Stock
    74,90 € 62,42 €Ex.
    In Stock
  • Ref : 21022
    In Stock
    The USB DD HIFI TC19BC is a USB cable with a high-end audiophile design. It features DATA conductors made of 4N monocrystalline pure silver and load conductors made of silver-plated OFC 5N copper, all implemented in a parallel structure with 4 flat conductors.
    119,00 € 99,17 €Ex.
    In Stock
  • Ref : 21023
    In Stock
    The USB DD HIFI TC19BA is a USB cable with a high-end audiophile design. It features DATA conductors made of 4N monocrystalline pure silver and load conductors made of silver-plated OFC 5N copper, all implemented in a parallel structure with 4 flat conductors.
    119,00 € 99,17 €Ex.
    In Stock
  • Ref : 21027
    In Stock
    The UcPure Pro from Ian Canada is part of the third generation of supercapacitor power supplies designed by the brand. It makes use of the huge 3000F or higher capacitance ultracapacitor pack to achieve an ultimate power supply performance. Because it is a pure passive power supply, there will be neither feedback nor active components involved when...
    499,00 € 415,83 €Ex.
    In Stock
  • Ref : 21040
    In Stock
    The SMSL AS400 is an extremely versatile integrated amplifier. It offers numerous advantages, such as a phono input, an HDMI ARC input, a preamplified output for active subwoofers, and two headphone outputs. It also features an audiophile chipset allowing it to support sampling rates up to PCM 32-bit 768kHz and DSD256 while delivering up to 2x 165W of...
    279,00 € 232,50 €Ex.
    In Stock
  • Ref : 21043
    The SA6 MK2 are in-ear earphones featuring a total of six balanced armature drivers combined with a crossover system that combines physical and electronic solutions for a sound that is both smooth and detailed. Their aesthetics, a combination of wood, gold particles and resin, give each piece a unique design for a look that is both understated and...
    579,00 € 482,50 €Ex.
    In Stock
  • Ref : 21044
    In Stock
    In Stock
  • Ref : 21032
    In Stock
    449,00 € 374,17 €Ex.
    In Stock
  • Ref : 21039
    In Stock
    The UcPure Pro from IAN Canada is part of the third generation of supercapacitor power supplies designed by the brand. It makes use of the huge 3000F or higher capacitance ultracapacitor pack to achieve an ultimate power supply performance. Because it is a pure passive power supply, there will be neither feedback nor active components involved when...
    459,00 € 382,50 €Ex.
    In Stock
  • Ref : 21048
    In Stock
    The Syitren R400 is a small battery-powered CD player that combines retro design with modern features. It is equipped with an M93BG6 playback head and an SC6137D decoding chip. In terms of functions, the R400 offers a choice of playback modes: loop, single loop, or random. In addition, in terms of connectivity, it features a classic 3.5mm jack output for...
    89,00 € 74,17 €Ex.
    In Stock
  • Ref : 21049
    In Stock
    The Syitren N100 is a compact wireless speaker with a minimalist retro design. It is equipped with two small speakers and is capable of delivering 2x5W of power. Its top panel features an ON/OFF button, a play/pause button, and a volume button. Audio input is via the N100's 3.5mm jack connector or the built-in Bluetooth 5.0 receiver, allowing you to...
    34,90 € 29,08 €Ex.
    In Stock
  • Ref : 21029
    PSVANE's EL34-Z power tube offers a soft, warm sound, full and natural, with good balance and no background noise. PSVANE offers us a tube with a more pronounced analog texture than conventional tubes, with voices more prominent than usual and an overall sound evocative of vinyl.
    179,00 € 149,17 €Ex.
    In Stock
  • Ref : 21034
    In Stock
    The Ian Canada UcConditioner Pro 2025 3.3V is a supercapacitor signal conditioning module operating with a 3.3V power supply. It will significantly improve the quality of your power supply by reducing both internal ESR and noise levels, while optimising stability and maximum current delivery.
    249,00 € 207,50 €Ex.
    In Stock
  • Ref : 21036
    159,00 € 132,50 €Ex.
    In Stock
  • Ref : 21037
    In Stock
    155,00 € 129,17 €Ex.
    In Stock
  • Ref : 21038
    In Stock
    The Ian Canada UcConditioner Pro 2025 5V is a supercapacitor signal conditioning module operating with a 5V power supply. It will significantly improve the quality of your power supply by reducing both internal ESR and noise levels, while optimising stability and maximum current delivery.
    In Stock
  • Ref : 21041
    In Stock
    In Stock
  • Ref : 21042
    In Stock
    In Stock
