IAN CANADA UCCONDITIONER PRO 2025 Conditioner Board 5V 400F
The Ian Canada UcConditioner Pro 2025 5V is a supercapacitor signal conditioning module operating with a 5V power supply. It will significantly improve the quality of your power supply by reducing both internal ESR and noise levels, while optimising stability and maximum current delivery.
Reference : 21038
155,00 €tax incl.
129,17 € tax excl.
Shipping date: 17-11-2026.
Ian Canada UcConditioner Pro 2025 5V 400F 400F Ultra Capacitor Conditioner Board 5V
Ian Canada UcConditioner Pro 2025 : Front view
For audiophiles, upgrading their power supply with the UcConditioner Pro 2025 may prove to be one of the best solutions for achieving significantly better sound quality.
Ian Canada UcConditioner Pro 2025 5V: Key points
The UcConditioner Pro 2025 is based on a low-resistance MOSFET architecture, with automatic charge management, active supercapacitor balancing and LED status indicators. It uses a PCB designed for high current and very low ESR, and operates at 5V in plug & play mode with output instantly following input.
Ian Canada UcConditioner Pro 2025 5V : Nouveautés de la version 2025
This version incorporates pre-assembled 400F low ESR supercapacitors, a 4-layer PCB with thickened copper, high-efficiency power management that reduces charging time and EMI noise, as well as enlarged connectors and vertical mounting brackets for easy integration.
Ian Canada UcConditioner Pro 2025 : Dimensions and Spacing holes
Product typeSignal conditionner
Input voltage5V
Output voltage5V
Capacity of supercapacitors400F
Dimensions85 x 55.5mm
Mounting holes spacing81.5 x 49mm
Package1x Ian Canada UcConditioner Pro 2025 5V
InputScrew terminals
OutputScrew terminals
Output voltage (V)5.0
Output current (A)NC
Input voltage (V)5.0
Power SupplyPower conditioner
IAN CANADA UCCONDITIONER PRO 2025 400F Ultra Capacitor Conditioner Board 5V
The Ian Canada UcConditioner Pro 2025 5V is a supercapacitor signal conditioning module operating with a 5V power supply. It will significantly...
