IAN CANADA UCCONDITIONER PRO 2025 Conditioner Board 3.3V 400F
The Ian Canada UcConditioner Pro 2025 3.3V is a supercapacitor signal conditioning module operating with a 3.3V power supply. It will significantly improve the quality of your power supply by reducing both internal ESR and noise levels, while optimising stability and maximum current delivery.
Reference : 21037
155,00 €tax incl.
129,17 € tax excl.
Shipping date: 17-11-2026.
Ian Canada UcConditioner Pro 2025 3.3V 400F 400F Ultra Capacitor Conditioner Board 3.3V
Ian Canada UcConditioner Pro 2025 : Front view
For audiophiles, upgrading their power supply with the UcConditioner Pro 2025 may prove to be one of the best solutions for achieving significantly better sound quality.
Ian Canada UcConditioner Pro 2025 3.3V: Key point
The UcConditioner Pro 2025 is based on a low-resistance MOSFET architecture, with automatic charge management, active supercapacitor balancing and LED status indicators. It uses a PCB designed for high current and very low ESR, and operates at 3.3V in plug & play mode with output instantly following input.
Ian Canada UcConditioner Pro 2025 3.3V: New features in version 2025
This version incorporates pre-assembled 400F low ESR supercapacitors, a 4-layer PCB with thickened copper, high-efficiency power management that reduces charging time and EMI noise, as well as enlarged connectors and vertical mounting brackets for easy integration.
Ian Canada UcConditioner Pro 2025 : Dimensions and Spacing holes
Product typeSignal conditionner
Input voltage3.3V
Output voltage3.3V
Capacity of supercapacitors400F
Dimensions85 x 55.5mm
Mounting holes spacing81.5 x 49mm
Package1x Ian Canada UcConditioner Pro 2025 3.3V
InputScrew terminals
OutputScrew terminals
Output voltage (V)3.3
Output current (A)NC
Input voltage (V)3.3
Power SupplyPower conditioner
Quadrature du cercle ?
J'ai commencé l'aventure Ian Canada, il y a un mois.
- Raspberry Pi 3B +
- Volumio
- Ian Canada Purepi II
- Ian Canada TransportPi Digi II
Puis 15 jours plus tard
- Ian Canada SC-Pure Horloges 45.1584MHz et 49.1520MHz
- Ian Canada UcConditioner Pro 2025 3.3V.
Cela sonne exactement comme j'avais envie que cela sonne.
C'est fabuleux !
This review has been posted for IAN CANADA UCCONDITIONER PRO 2025 400F Ultra Capacitor Conditioner Board 3.3V
The Ian Canada UcConditioner Pro 2025 3.3V is a supercapacitor signal conditioning module operating with a 3.3V power supply. It will significantly...
