Filters
Categories level 1
Brand
In stock
Laurent B.
Bonne upgrade
Hans B.
Patrice L.
Un produit bien conçu.
New products
  • Ref : 20885
    In Stock
    These nickel-plated steel screws in M2.5x12mm format have a countersunk hexagon socket head. Their resistance rating of 10.9 guarantees excellent durability.
    0,80 € 0,67 €Ex.
    In Stock
  • Ref : 20753
    With the AS6, LHY Audio offers us a network switch, an evolution of the SW6-SFP model, comprising 5 RJ45 ports, one of which benefits from digital isolation, a fibre optic SFP port and a BNC input connected to the integrated 10mHz OCXO clock. All of this is housed in an elegant anodised aluminium enclosure machined from solid material and designed to...
    749,00 € 624,17 €Ex.
    In Stock
  • Ref : 20754
    In Stock
    LHY Audio offers us their AS8 Pro network switch. The switch includes 6 RJ45 Ethernet ports, 2 SFP fibre optic ports and an input and output connected to the 10mHz OCXO clock. Everything is housed in an elegant anodised aluminium case machined from a single piece of material to limit resonance, and designed to separate data processing, audio signal...
    1 759,00 € 1 465,83 €Ex.
    In Stock
  • Ref : 20809
    With the HS300, ddHiFi offers an anodised aluminium tray designed to provide excellent heat dissipation as well as offering an aesthetic that is both sober and elegant. This tray is part of a set of components that allow you to create your own modular HiFi stand to suit your needs perfectly. In the same range, you'll find a set of aluminium feet in...
    59,90 € 49,92 €Ex.
    In Stock
  • Ref : 20813
    With the SR70, ddHiFi offers a set of 4 aluminum feets that can be nested together. These are designed to be fitted onto the trays in the same range to create a modular piece of HiFi furniture to suit your needs perfectly. All screws and bolts are supplied.
    29,90 € 24,92 €Ex.
    In Stock
  • Ref : 20815
    With the HS300 + BASE, ddHiFi offers an anodised aluminium tray designed to provide excellent heat dissipation, coupled with vibration-absorbing feet. This tray acts as a stable, vibration-free base for your HiFi equipment. This base is part of a set of elements that can be used to create a modular piece of HiFi furniture to suit your needs perfectly. In...
    85,00 € 70,83 €Ex.
    In Stock
  • Ref : 20764
    The SMSL DS20 is a portable DAC and headphone amplifier distinguished by its cutting-edge audiophile performance and singular aesthetics. It is based on an advanced architecture incorporating four CS43131 DAC chips and an XMOS XU316 USB interface. This combination enables it to handle high-resolution audio streams up to PCM 32bit 768kHz, DSD256, and MQAx8...
    199,00 € 165,83 €Ex.
    In Stock
  • Ref : 20707
    The Dunu V53 is a balanced desktop headphone amplifier combining refined design and exceptional audio performance. The result of a collaboration between Dunu and NiuNiu Audio, this amplifier is designed to deliver an immersive and faithful listening experience, meeting the expectations of the most demanding audiophiles. The V53 boasts first-rate technical...
    1 699,00 € 1 415,83 €Ex.
    In Stock
  • Ref : 20766
    Pre-order - Availability date to come
    The DUNU Concept R is a portable CD player that combines retro-futuristic design with state-of-the-art audiophile performance. Featuring a fully discrete R-2R DAC architecture and amplification selectable in Class A or AB modes, it offers an authentic analog listening experience, whether on the move or at home.
    809,00 € 674,17 €Ex.
  • Ref : 20756
    In Stock
  • Ref : 20759
    This Tonewinner pack includes the AT-300 audio/video processor and home theater preamplifier, plus two AD-5100PA+ power amplifiers. The result is an extremely powerful, high-performance home theater system. What's more, these devices feature a unique design for aesthetic integration into your audio system. The package is completed by the Tonewinner ETM-2...
    2 199,00 € 1 832,50 €Ex.
    In Stock
