LHY AUDIO AS8 Pro Network Switch Silver
LHY Audio offers us their AS8 Pro network switch. The switch includes 6 RJ45 Ethernet ports, 2 SFP fibre optic ports and an input and output connected to the 10mHz OCXO clock. Everything is housed in an elegant anodised aluminium case machined from a single piece of material to limit resonance, and designed to separate data processing, audio signal processing, the internal clock and the power supply stage.
By buying this product you get 175 loyalty points
Reference : 20756
1 759,00 €tax incl.
1 465,83 € tax excl.
Shipping date: 01-12-2026.
LHY AUDIO AS8 Pro Network Switch 6x RJ45 2x Optical Fiber Silver
LHY AUDIO AS8 Pro : Front view
LHY Audio
offers us their AS8 Pro network switch. The switch includes 6 RJ45 Ethernet ports, 2 SFP fibre optic ports and an input and output connected to the 10MHz OCXO clock. Everything is housed in an elegant anodised aluminium case machined from a single piece of material to limit resonance, and designed to separate data processing, audio signal processing, the internal clock and the power supply stage.
LHY Audio AS8 Pro: A noise-free, stable power supply
The AS8 Pro deploys two 50VA transformers for a regulated linear power supply coupled with an RFI suppression filter. Once transformed, the current passes through a low-drop multi-stage voltage regulator and voltage rectifier to ensure the cleanest possible power supply.
LHY Audio AS8 Pro: An OCXO master clock at the heart of everything
In terms of signal processing, the LHY Audio AS8 Pro offers 6 RJ45 ports, two of which are digitally isolated, and two optical SFP ports, one of which is also digitally isolated. But that's not all: the AS8 Pro has a 10MHz OCXO clock at its heart, itself connected to a BNC input and output. You can use this network switch as a master clock to synchronise other external sources or simply resynchronise the input signal. Finally, the OCXO clock is coupled to a PLL phase-locked loop.
AS8 Pro overview
LHY AUDIO AS8 Pro : rear panel diagram
1Power switch
2Fuse
3AC power input
4Ground switch
5Ground terminal
650Ω BNC input and output
7SFP+ indicator light
8SFP+ 10Gb/s port
9RJ45 2.5Gb/s ports
10Isolated RJ45 1Gb/s ports
11Isolated SFP 1Gb/s port
12SFP+ indicator light
Product typeOptical Fiber Ethernet Network Switch
Interface4x RJ45 ethernet port
2x Isolated RJ45 ethernet port
1x SFP+ optical fibre connector
1x Isolated SFP optical fibre connector
1x BNC input for 10MHz clock (input impedance 50Ω)
1x BNC output for 10MHz clock (50Ω output impedance)
Clock phase noise-110dBc @1Hz
Clock frequency stability< ±5ppb
Clock frequency accuracy< ±0.5ppm
Power supply220V - 240V AC
ConsumptionStandby : 18W
in use : 28W
Dimensions400 x 260 x 55mm
Weight5.5kg
ColorSilver
Package1x LHY Audio AS8 Pro
1x Power supply cable
LHY AUDIO AS8 PRO Network Switch 6x RJ45 2x Optical Fiber Silver
LHY Audio offers us their AS8 Pro network switch. The switch includes 6 RJ45 Ethernet ports, 2 SFP fibre optic ports and an input and output...
