This straight 3.5mm TRRS male jack connector features 24k gold-plated contacts as well as a carbon fiber body. This allows it to resist oxidation and corrosion while also protecting against interference.
This straight 3.5mm TRS male jack connector features 24k gold-plated contacts as well as a carbon fiber body. This allows it to resist oxidation and corrosion while also protecting against interference.
The Dayton Audio CF120-4 low-midwoofer is the perfect combination of aesthetics and performance thanks to its high-tech carbon composite cone. The CF120-4 covers a wide frequency response ranging from 50Hz to 15kHz and is ideal for 2-way satellite systems as well as MTM designs or high-end car audio applications.
The Furutech e-TP609 NCF-N1 is a power distributor designed to provide a dedicated power supply point within a demanding Hi-Fi or home cinema system. It features six individually wired mains sockets from a central IEC input, based on an internal architecture that prioritises continuity of conduction in order to distribute power evenly between the various...
The iFi Audio NEO iDSD 3 is a DAC and headphone amplifier based on Burr-Brown conversion architecture, enabling it to simultaneously perform digital-to-analogue conversion of PCM streams up to 32-bit/ 768 kHz and DSD512, combined with an amplifier stage capable of delivering up to 2532 mW under 64 Ω.
The Fosi Audio S3 is an extremely complete device combining the functions of streamer, DAC and balanced preamplifier. Indeed, it relies on high-end components as well as a comprehensive chipset including a Burr-Brown PCM1894 ADC chip, an Amlogic A113X processor, an AK4493SEQ DAC chip and two OPA1612 operational amplifiers for signal preamplification.
The Go Link 2 from iFi Audio is a portable DAC adapter that is ideal for connecting headphones or earphones to a device that does not have a 3.5mm headphone jack, such as a recent smartphone. It also allows devices with a headphone jack to enjoy better sound thanks to the built-in high-quality DAC and headphone amplifier.
The USB iPurifier Pro from iFi Audio is a noise filter for USB ports. The successor to the iGalvanic 3.0, it also includes the feature of the iSilencer and iDefender for a unique and ever more powerful product aimed at audiophiles. Compact yet comprehensive, the iPurifier Pro protects the signal from USB interference to ensure high-quality transmission.
The LHY-Audio linear power supply is a low-noise power supply based on the use of a high quality custom toroidal transformer, high-performance LT3086 regulators, high-current, low-resistance Schottky rectifiers, and Vishay BC electrolytic capacitors, all mounted on a four-layer PCB with gold-plated copper circuits.
This power supply adapter allows you to power devices requiring 36V 6A DC (up to 216W) from a 100-240V AC mains source. It features a 5.5mm/2.5mm DC jack connector on the output, and a Type C / IEC C7 power cable is included.
