IFI AUDIO NEO IDSD 3 Headphone Amplifier DAC
The iFi Audio NEO iDSD 3 is a DAC and headphone amplifier based on Burr-Brown conversion architecture, enabling it to simultaneously perform digital-to-analogue conversion of PCM streams up to 32-bit/ 768 kHz and DSD512, combined with an amplifier stage capable of delivering up to 2532 mW under 64 Ω.
By buying this product you get 89 loyalty points
Reference : 21589
899,00 €tax incl.
749,17 € tax excl.
iFi Audio NEO iDSD 3 Headphone Amplifier DAC Burr-Brown Bluetooth 5.4 32bit 768kHz DSD512
iFi Audio NEO iDSD 3 : Front view
The iFi Audio NEO iDSD 3 is a DAC and headphone amplifier based on Burr-Brown conversion architecture, enabling it to simultaneously perform digital-to-analogue conversion of PCM streams up to 32bit 762kHz and DSD512, combined with an amplifier stage capable of delivering up to 2532mW under 64Ω.
Beyond this hardware foundation, the device adopts a separate processing architecture for PCM and DSD streams, ensuring bit-perfect handling tailored to each format, while proprietary processing technologies enhance frequency response and perceived spatialisation. This approach is extended by the integration of Bluetooth 5.4 connectivity compatible with high-definition codecs such as aptX Lossless, aptX Adaptive, LDAC and LHDC, thus preserving excellent resolution even in a wireless transmission context.
iFi Audio NEO iDSD 3 : An amplifier for all headphones
In addition to generous amplification of 2532mW at 64Ω, the Neo IDSD 3 has been designed to drive even the most power-hungry headphones. It features three gain modes to suit all situations. First is Normal mode at +0dB, which is mainly useful for earphones, as they are generally equipped with low-power speakers. Next is Turbo mode at +6dB, designed for headphones with medium sensitivity. Finally, there is Nitro mode at +12dB, for the most demanding headphones.
In addition, you can activate the brand's proprietary feature, iEMatch. This allows your high-sensitivity headphones and earphones to benefit from reduced background noise and an increased usable volume range.
iFi Audio NEO iDSD 3 : In use
iFi Audio NEO iDSD 3 : Burr-Brown DAC
The NEO iDSD 3 bases its digital-to-analogue conversion on a Burr-Brown DAC chip and is capable of handling signals up to 32bit 768kHz PCM and DSD512, allowing you to enjoy the highest resolution content. Furthermore, to ensure bit-perfect support for each technology, the device employs a dual-circuit architecture, with each circuit specialising in PCM and DSD processing.
Beyond its ability to handle high-resolution files, the NEO iDSD 3 incorporates K2 and K2HD technologies, which improve the harmonic coherence and microdynamics of PCM streams, enhancing the perceived continuity of recordings from digital masters.
iFi Audio NEO iDSD 3 : XSpace and XBass technology
The NEO iDSD 3 also incorporates many of the brand's proprietary technologies, such as XSpace and Xbass. Once activated, the former widens the soundstage, which is very useful in closed-back headphones to avoid a feeling of enclosedness.
XBass technology, meanwhile, comes in several variations. The basic XBass setting enhances the lower end of the audio spectrum and is particularly suitable for use with open-back headphones to compensate for the lack of bass inherent in their design. XBass Presence mode, on the other hand, enhances the mid-range for more pronounced vocals. Finally, the last mode combines the basic XBass mode and Presence mode if you want to enjoy both settings at the same time.
iFi Audio NEO iDSD 3 : XBass and XSpace logo
iFi Audio NEO iDSD 3 : Bluetooth 5.4
Designed with practicality in mind, the NEO iDSD 3 also features Bluetooth 5.4 connectivity supporting high-definition codecs aptX Lossless, aptX Adaptive, aptX, LDAC, LHDC/HWA and AAC.
Product typeDAC
Headphone amplifier
Inputs1x Stereo RCA
1x USB-B 3.0
1x Coaxial
1x Optical
BNC (Clock)
Bluetooth 5.4
Outputs1x 4.4mm balanced headphone jack output
1x 6.35mm single-ended headphone jack output
1x Single-ended stereo RCA line output
1x Balanced stereo XLR line output
Supported sampling ratesPCM up to 32bit 768kHz
DSD up to DSD512
Signal-to-noise ratio (SNR)≥ 120dB(A) @ -60dBFS
Dynamic range≥ 120dB(A) @ -60dBFS
Total harmonic distortion more noise (THD+N)≤ 0.0015% @ 0dBFS
RMS output powerSingle-ended: 2532mW @ 64Ω
Balanced: 2244mW @ 32
Max output powerSingle-ended: 184mW @ 600Ω / 2832m @ 32Ω
Balanced: 650mW @ 600Ω / 5551m @ 32Ω
Headphone output impedance≤ 1Ω
iEMatch: 7Ω
Line output impedanceXLR: ≤ 102Ω
RCA: ≤ 51Ω
Line output levelXLR: : ≤19.5V (variable); 4.4V (fixed)
RCA: ≤10.V (variable); 2.2V (fixed)
Supported Bluetooth codecsaptX Lossless, aptX Adaptive, aptX, LDAC, LHDC/HWA, AAC, SBC
Power supply voltage9V DC / 1.5A
15V DC / 0.9A
Weight916g
Dimensions214 x 158 x 41mm
Package1x iFi Audio NEO iDSD 3
1x iFi Audio iPower 2
1x Remote control
1x Stand for vertical placement
1x RCA cable
1x USB-A to USB-B cable
1x 3.5mm to 6.35mm jack adapter
InputClock (BNC)
OutputJack 4.4mm
OutputJack 6.35mm
DAC / ADC ChipBurr Brown
Max sampling rate768kHz
Max sampling rateDSD512
Remote ControlYes
IFI AUDIO NEO IDSD 3 Headphone Amplifier DAC Burr-Brown Bluetooth 5.4 32bit 768kHz DSD512
The iFi Audio NEO iDSD 3 is a DAC and headphone amplifier based on Burr-Brown conversion architecture, enabling it to simultaneously perform...
