DAYTON AUDIO CF120-4 Speaker Driver Midwoofer
The Dayton Audio CF120-4 low-midwoofer is the perfect combination of aesthetics and performance thanks to its high-tech carbon composite cone. The CF120-4 covers a wide frequency response ranging from 50Hz to 15kHz and is ideal for 2-way satellite systems as well as MTM designs or high-end car audio applications.
Reference : 21590
59,57 €tax incl.
49,64 € tax excl.
DAYTON AUDIO CF120-4 Low-Midwoofer 30W 4Ω 89dB 50Hz-15kHz Ø114.3mm
Summary of the main advantages of the Dayton Audio CF120-4:
  • Pincushion cast aluminum frame.
  • Its ultra-lightweight and robust woven carbon fibre cone.
  • A copper cap and a large magnet for a low-distortion motor structure.
  • Its 2.54 cm (1") voice coil is both durable and powerful, resistant to high temperatures thanks to its double layer.
  • The black anodised aluminium vented former, allowing for better heat dissipation and power management.
  • A frequency response up to 15kHz.
Dayton Audio CF120-4: Curves and dimensions
Product typeSpeaker
Speaker typeMidwoofer
Nominal DiameterØ114.3mm (4-1/2")
Power Handling (RMS)30W
Power Handling (MAX)60W
Impedance4Ω
Frequency Response50Hz-15kHz
Sensitivity89,1dB 2,83V/1m
Voice Coil Diameter2.54cm (1")
Thiele-Small Parameters
Resonant Frequency (FS)53.2Hz
DC Resistance (Re)3,4Ω
Voice coil inductance (Le)0,45mH
Mechanical Q (Qms)1,89
Electromagnetic Q (Qes)0,32
Total Q (Qts)0,28
Compliance equivalent volume (Vas)0,17pi³
Mechanical compliance of Suspension (Cms)1.306mm/N
BL product (BL)4.94T·m
Diaphragm mass inc. airload (Mms)6.86g
Maximum linear excursion3.5mm
Surface area of cone (Sd)51.25cm²
Materials
Cone materialCarbon fiber composite
Surround materialRubber
Voice coil wire materialCopper
Voice coil formerAluminium
Basket / frame materialCast Aluminum
Magnet materialFerrite
Mounting Information
Overall outside diameter127mm (5")
Baffle cutout diameter95.25m (3.75")
Depth57.15mm (2.25")
Mounting holes4
Recommended Enclosure Volume
Sealed volume0.07pi³
Sealed F3180Hz
Vented volume0,2pi³
Vented F360Hz
Package1x Dayton Audio CF120-4
Weight2.2kg
Speaker Power (W RMS)30
Speaker TypeMidbass
Impedance (Ω)4
Loudspeaker diameter (mm)114.0
Diaphragm typeCarbon fiber
Efficiency / Sensitivity (dB)89.0
Max Linear Excursion (Xmax) (mm)3.5
Lowest frequency (Hz)50
Highest frequency (Hz)15000
DAYTON AUDIO CF120-4 Speaker Driver Midwoofer Carbon Fiber 30W 4 Ohm 89dB 50Hz-15kHz Ø11.4cm
The Dayton Audio CF120-4 low-midwoofer is the perfect combination of aesthetics and performance thanks to its high-tech carbon composite cone. The...
