OPA
Pavel V.
Good and tight plugs
Good and tight plugs, but despite my impression from the pictures, there is actually no grooving to put on a coloured rubber...
Pavel V.
Excellent amplifier with a power-on issue
Excellent amplifier. The only serious issue: it can frequently trip sensitive circuit breakers on start-up. The NC252MP...
Pavel V.
Excellent amplifier
- the power supply produces a very slight high-piched noise (~4kHz)...
OPA
  • Ref : 12695
    In Stock
    The OPA MUSES8820 has been developed by the specialist manufacturer NJR. It is an operational amplifier optimized for high fidelity and professional uses, thus offering very good audio performance.
    9,90 € 8,25 €Ex.
    In Stock
  • 12,90 € 10,75 €Ex.
    In Stock
  • Ref : 12490
    This OPA mounted on a DIP8 bracket uses a hybrid structure. Indeed, this one is composed of a Texas Instruments OPA1611 OPA chip followed by a Class A amplifier stage allowing it to provide a higher output current of 200mA and a lower impedance, giving it a greater versatility.
    6,90 € 5,75 €Ex.
    In Stock
  • Ref : 12489
    This OPA1622 is ideal for the replacement of any OP NE5532, OPA2134 DIP8 compatible amplifier, An excellent stereo AOP, dynamic, straight, affordable, which will find its place notably in the output of DAC and headphone amplifier.Strengths:High rejection rate JRC/NE 5532 compatible DIP 8 support and derivatives Total harmonic distortion: -119dB
    10,90 € 9,08 €Ex.
    In Stock
  • Ref : 18336
    In Stock
    This OPA210 is a single AOP mounted on DIP8. It is built on Texas Instrument's Super Beta precision complementary bipolar semiconductor process. This OPA is recommended for high-speed, high-precision applications.
    7,90 € 6,58 €Ex.
    In Stock
  • Ref : 18337
    In Stock
    This OPA2210 is a dual OPA mounted on DIP8. It is built on Texas Instrument's Super Beta precision complementary bipolar semiconductor process. This OPA is recommended for high-speed, high-precision applications.
    7,90 € 6,58 €Ex.
    In Stock
  • Ref : 17534
    In Stock
    The Oracle II 01 single OPA represents a new generation of hybrid discrete operational amplifier, specifically designed for audio applications and offering excellent performance for incredible sound quality.
    6,90 € 5,75 €Ex.
    In Stock
  • Ref : 17535
    In Stock
    The Oracle II 02 dual OPA represents a new generation of hybrid discrete operational amplifier, specifically designed for audio applications and offering excellent performance for incredible sound quality.
    6,90 € 5,75 €Ex.
    In Stock
  • Ref : 19345
    In Stock
    Sonic Imagery Labs' model 252AP is a high-performance, discrete operational amplifier (OPA) designed for professional audio applications and areas where ultra-low noise and low distortion are required. The 252AP is particularly well suited to circuits with medium to high source impedance, and to microphone input transformers with high transformation...
    95,00 € 79,17 €Ex.
    In Stock
  • Ref : 9356
    In Stock
    The Sonic Imagery Labs 990ENH-TICHA model is a high-performance, discrete operational amplifier (OPA) designed for professional audio applications and areas where ultra-low noise, low distortion and highly linear, uncolored operation are required. This model has been designed to replace Jensen JE990, Automated Processes Inc API-2520, John Hardy Co...
    95,00 € 79,17 €Ex.
    In Stock
  • Ref : 9357
    In Stock
    Sonic Imagery Labs' model 992ENH-TICHA is a high-performance, single discrete operational amplifier (OPA) designed for professional audio applications and areas where ultra-low noise, low distortion and highly linear, uncolored operation are required. The 992ENH-TICHA discrete OPA achieves a new standard of noise excellence with a measurement at...
    55,90 € 46,58 €Ex.
    In Stock
  • Ref : 9354
    In Stock
    Sonic Imagery Labs' model 994ENH-TICHA is a high-performance dual discrete operational amplifier (OPA) designed for professional audio applications and areas where ultra-low noise, low distortion and highly linear, uncolored operation are required. The 994ENH-TICHA discrete OPA achieves a new standard of noise excellence with a measurement at 0.89nV/Rt.Hz...
    109,00 € 90,83 €Ex.
    In Stock
  • Ref : 9355
    In Stock
    Sonic Imagery Labs' Model 995FET-TICHA is a high-performance, discrete operational amplifier (OPA) designed for professional audio applications and areas where ultra-low noise, low distortion and highly linear, uncolored operation are required. A matched-pair FET input stage is integrated to provide superior sound quality and speed for outstanding audio...
    99,00 € 82,50 €Ex.
    In Stock
  • Ref : 13906
    In Stock
    Some discrete OPA use a different pinout from the DIP8 standard, such as the SS2590 from Sparkos Labs. This API to DIP8 adapter will therefore allow you to use such a OPA on DIP8 support. Mounting is simple since it is enough to place your OPA on the adapter and make a few solderings and then cut the legs that protrude under the PCB.
    13,90 € 11,58 €Ex.
    In Stock
  • Ref : 15071
    In Stock
    This adapter allows you to simultaneously install two Sparkos discrete AOPs (tyoe SS2590) on a stereo connector on DIP8. It thus allows a pair of sparkos discrete mono AOPs to be used on a stereo AOP slot.
    14,90 € 12,42 €Ex.
    In Stock
  • Ref : 18979
    In Stock
    After the undeniable success of the SS3601 and SS3602 discrete OPA, SparkoS Labs focused on discrete OPA that can be found in studio equipment or recording devices, such as the API2520 operational amplifier or the Jensen 990. After numerous tests and measurements, SparkoS Labs decided to offer a much more efficient OPA. Here, two SS2590 AOPs have...
    149,00 € 124,17 €Ex.
    In Stock
  • Ref : 13897
    In Stock
    59,90 € 49,92 €Ex.
    In Stock
  • Ref : 13168
    In Stock
    SparkoS Labs has created a range of discrete DIP8-mounted PDOs optimized to deliver excellent audio performance. They will allow you to replace less powerful AOP or quite simply to obtain a different sound.
    39,90 € 33,25 €Ex.
    In Stock
  • Ref : 13169
    In Stock
    85,00 € 70,83 €Ex.
    In Stock
  • Ref : 18949
    In Stock
    Staccato's open-loop OSH-DHA OPA is there to magnify the sound of high-end DACs and preamplifiers. The use of J-FET, in both input and output stage, in combination with high bias current, had result in low open loop distortion with dominating of 2nd harmonic.
    99,00 € 82,50 €Ex.
    In Stock
  • Ref : 18951
    In Stock
    Staccato's open-loop OSH-DHB AOP is there to magnify the sound of high-end DACs and preamplifiers. The use of J-FET, in both input and output stage, in combination with high bias current, had result in low Open loop distortion with dominating of 2. harmonic. The source follower at the output using an active current source which allow higher output current...
    99,00 € 82,50 €Ex.
    In Stock
  • Ref : 18963
    In Stock
    Staccato's open-loop OSH-DV OPA is there to magnify the sound of high-end DACs and preamplifiers. The use of J-FET, in both input and output stage, in combination with high bias current, had result in low Open loop distortion with dominating of 2. harmonic. The source follower at the output using an active current source which allow higher output current...
    99,00 € 82,50 €Ex.
    In Stock
  • Ref : 18964
    In Stock
    Staccato's open-loop OSH-S OPA is there to magnify the sound of high-end DACs and preamplifiers. The use of J-FET, in both input and output stage, in combination with high bias current, had result in low Open loop distortion with dominating of 2. harmonic. The source follower at the output using an active current source which allow higher output current...
    49,90 € 41,58 €Ex.
    In Stock
  • Ref : 14420
    In Stock
    The Texas Instruments LM4562NA/NOPB is a high-performance 2-channel operational amplifier (OPA) integrated in a PDIP8 enclosure. This ultra low distortion, low noise and high speed AOP is optimized for high fidelity audio applications.
    3,60 € 3,00 €Ex.
    In Stock
  • Ref : 14413
    The Texas Instruments LME49720NA/NOPB is a high performance 2-channel Class AB, high performance operational amplifier (OPA) integrated in a DIP8 package. This ultra low distortion, low noise and high speed AOP is optimized for high fidelity audio applications.
    5,50 € 4,58 €Ex.
    In Stock
  • 1,90 € 1,58 €Ex.
    In Stock
