ASCILAB F6B Bookshelf Speakers Black (Pair)
The AsciLab F6B are passive bookshelf speakers offering precise, powerful sound reproduction in a compact format. These 2-way speakers feature a 1“ aluminum dome tweeter with custom waveguide and phase tapping, combined with a 6” woofer with fiber cone, all housed in an enclosure with passive radiator.
By buying this product you get 89 loyalty points
Reference : 20831
899,00 €tax incl.
749,17 € tax excl.
Shipping date: 02-04-2026.
AsciLab F6BBookshelf Speakers 125W 4 Ohm 84dB Black (Pair)
Photo of Ascilab F6B
The AsciLab F6B are passive bookshelf speakers offering precise, powerful sound reproduction in a compact format. These 2-way speakers feature a 1“ aluminum dome tweeter with custom waveguide and phase tapping, combined with a 6” woofer with fiber cone, all housed in an enclosure with passive radiator. The optimized depth of the AsciLab F6B makes them easy to integrate on a shelf or desk, while enhancing their sensitivity. In addition, the 5x8” passive radiator provides a considerable boost at low frequencies. Their design allows for lower crossover points and reduced distortion, for an extremely clear sound. The F6B feature a 1kHz crossover and support up to 125W of amplification.
For other colors, please contact us via our contact form. The classic white model is available here.
F6B models
AsciLab F6B: Optimized tweeters for controlled sound dispersion
AsciLab F6B tweeters feature a waveguide and internal phase plug designed to precisely manage sound dispersion. These elements avoid phase interference, reduce internal resonance and improve off-axis dispersion. The advantages of this type of configuration translate into a more linear frequency response, reduced distortion and better spatialization of sound, offering a more coherent soundstage.
Zoom in on the F6B tweeter
Zoom in on the F6B woofer
AsciLab F6B: Powerful 6” woofer for optimum spatial coverage
Despite their compact size, the 6” woofers in the AsciLab F6B loudspeakers are capable of providing powerful, well-defined bass in spaces of up to 25m². High-performance and dynamic, these woofers also come with an aesthetically pleasing protective cover, combining performance and design.
AsciLab F6B: A 5x8” passive radiator
AsciLab F6B speakers feature a passive radiator at the rear. This limits unwanted resonance while optimizing low-frequency reproduction. This solution also helps reduce distortion at high volumes, unlike a bass-reflex port, which can generate turbulence. AsciLab has also chosen to integrate a passive radiator in order to maintain a relatively compact speaker design.
F6B passive radiator
AsciLab F6B test by Audio Science Science Review
"Just like the F6Bs, the immediate impression was warm and ultra clean detail. Here, the F6B went lower, producing a full range response.  I felt no need to change anything with EQ. The level of refinement oozes from every aspect of the F6B from external design to objective measurements.
When you include the price in the equation, I am at a loss to recommend alternatives to the F6B. It is that good!"
ASR logo
Product typePassive speakers
Design2 way
Tweeter1” aluminum dome tweeter
Woofer6” fiber woofer with reinforced plastic chassis
EnclosureWith passive radiator
FinishMatte
Crossover frequency1kHz
Sensitivity84dB @ 2.83V / 1M
SPL Max. (Full-bandwidth)97dB SPL
SPL Max. (>100Hz)102dB SPL
Frequency response-3dB @ 56Hz / -6dB @ 46Hz
ImpedanceNominal 4 ohm (min 140Hz / 3.5 ohm)
Recommanded amplification50W - 125W
Screw terminal connectionsBanana 4mm
Bare wires
Spades
Dimensions40 x 20.3 x 26.5cm
Weight7.5kg/speakers
Package1x Pair of AsciLab F6B speakers
2x Woofer grille
Impedance (Ω)4
Efficiency / Sensitivity (dB)84.0
Lowest frequency (Hz)N/A
Highest frequency (Hz)N/A
Power (W)125.0
Number of ways2
Number of loudspeakers3
Speaker typePassive
Speaker form factorBookshelf speaker
Absolutely amazing
This review has been posted for ASCILAB F6B Bookshelf Speakers 125W 4 Ohm 84dB Black (Pair)
The AsciLab F6B are passive bookshelf speakers offering precise, powerful sound reproduction in a compact format. These 2-way speakers feature a...
