By buying this product you get 38 loyalty points
Bookshelf Speaker 2 Way 88dB 46Hz - 30kHz Graphite Gray (Pair)
The Q Acoustics 3030i loudspeakers incorporate a large woofer/midrange driver inspired by the 3050i floorstanding speaker and a 25mm decoupled tweeter. This combination provides a beautiful bass presence, balanced and expressive midrange and precise and detailed high frequencies. This design will allow you to enjoy your music to the fullest and capture all its richness.
The all-new woofer/midrange uses a high quality, impregnated, coated paper cone combined with an optimised motor. As this speaker is capable of a prodigious low frequency presence, the 22mm tweeter above it is decoupled and is therefore isolated from the vibration of the w/midrange driver, for a clearer and purer sound.
Like the entire 3000i range, the 3030i uses the unique reinforcement technique developed by Q Acoustics. This computer-assisted precision process results in an extremely rigid speaker cabinet that eliminates unwanted vibrations.
The Q Acoustics 3030i, in addition to its sturdy structure, has a beautiful contemporary look with its Graphite Grey colour for the most beautiful effect. As with the other models in the 3000i range, the protective grilles are magnetic and each speaker is surrounded by a chrome ring.
Product type | Bookshelf speaker |
Number of ways | 2 |
Bass Reflex | |
Woofer diameter | Ø165mm (6.5") |
Tweeter diameter | Ø22mm (0.9") |
Frequency response (±3dB, -6dB) | 46Hz - 30kHz |
Average impedance | 6Ω |
Minimum impedance | 4Ω |
Sensitivity (2.83V@1m) | 88dB |
Stereo amplifier power | 25 - 75W |
Crossover frequency | 2.4kHz |
Effective volume | 12.5L |
Dimensions (L x P x H) | 200 x 329 x 325mm |
Weight | 6.4kg |
Color | Graphite Gray |
Color | Gray |
Impedance (Ω) | 4 |
Impedance (Ω) | 6 |
Efficiency / Sensitivity (dB) | 88.0 |
Lowest frequency (Hz) | 46 |
Highest frequency (Hz) | 30000 |
Power (W) | 75.0 |
Number of loudspeakers | 2 |
Speaker type | Passive |
Speaker form factor | Bookshelf speaker |
