The Swans M10 is a 3-way 2.1 kit amplified for multimedia gamer use or the high fidelity sound of a room.
With a high-quality assembly quality in its black version, here is a well-built 2.1 High fidelity kit.
The 2-way satellites are closed and composed of a 8cm midrange speaker and a textile dome tweeter.
The case uses a 13cm long excursion loudspeaker, as well as 2 Bass-Reflex vents. P>
This European version features a sound signature adapted to the Western market. This kit 2.1 is shielded, so as not to interact with a CRT screen.
Subwoofer: | ||
System: Td> | 1-way vented box active system Driver Configuration | |
Woofer: | 5 " | |
Frequency range: Td> | 42-5kHz | |
Power rating: Td> | 10-40W | |
Integrated Amplifier: | ||
Frequency range: | 100Hz-20kHz | |
Nominal power : | 2 x 8W RMS | |
Noise signal ratio: | > 88dB | |
Distortion: | THD <0.01% (8Ω @ 1KHz @ 1W) | |
Input sensitivity: | 600mV | |
Input impedance: | 22KΩ | |
Crosstalk: | > 60dB | Other: |
Finish: | PVC matt black, with HP white | |
Dimensions: | 245 x 258 x 172mm | |
Net peas: | 4.2 kg | |
Td> | ||
satellites | ||
System: | 2-way 1st sealed box system | |
Woofer: | Td> | 3 " |
Tweeter : | 20mm | |
Plage of frequency: Td> | 140Hz - 20kHz | |
Distortion: | 280Hz - 20kHz = 1% (2.83 V / 1m) | |
Sensitivity: Td> | 87dB 2.83V / 1m | |
Nominal impedance: Td> | 4Ω Td> | |
Power rating: | 1-20W | |
Other: | ||
Dimensions: | 110 x 100 x 172mm | |
Net weight : | 0.84 kg |
[Img-18810-left-thickbox_default] P>
[Img-18813-left-thickbox_default]
