VIBRAPOD ISOLATORS MODEL1 Insulator / Absorber Vibration (Set x4)
VIBRAPOD ISOLATORS MODEL1 Isolateur/Absorbeur Vibrations (Set x4)
Reference : 2651
29,00 €tax incl.
24,17 € tax excl.
Available
Shipping date: 23-04-2018.
Orders placed before 1pm (GMT+1) will be shipped the same day (working day).
Accessories
Absorbers Vibrapod x4
Vibrapod isolators (or absorbers) are designed to absorb vibrations that could be transmitted to your Hifi and video or other devices.
They protect the devices from vibrations that degrade the sound or video quality.
Because an absorber suitable for a 5kg CD player will not work for a 40kg amplifier, Vibrapod has designed 5 models to achieve optimum performance regardless of the weight of the device.
It is surely the absorbers which present the best efficiency / price ratio.
Your ears will certainly thank you ...
There are 5 models of Vibrapods depending on the weight of your components:
Model of VibrapodRecommended weight
(kg per Vibrapod)
Weight
(kg per Vibrapod)
Minimum weight of the device
for 4x Vibrapods
Model # 11.10.90 - 1.363.6 - 5.4
Model # 22.71.81 - 3.627.2 - 14.4
Model # 34.53.62 - 5.4414.4 - 21.7
Model # 47.26.35 - 8.1625.4 - 32.6
Model # 511.39.9 - 12.739.8 - 50.8
Dimensions:1.5cm high x 6.2cm in diameter.
For appliances with feet larger than 4.2cm, they can be placed directly on the dome of the Vibrapod
For appliances with feet with a diameter between 1.9 and 4cm, place them on the central island, Vibrapod upside down (photo2)
For appliances on points, add a tailstock with a minimum diameter of 1.9cm.
componentand feet
In some cases, when the bottom of the appliance is irregular,e the original feet are too small or the appliance is heated, it is advisable to use a "sandwich" mounting
You should then place your device on a shelf, which itself will rest on Vibrapod.
Remember to include the weight of the shelf when choosing the Vibrapods model.
Because of their vinyl design, it is possible that the Vibrapods leave some traces on the smooth surfaces.
Diameter62mm
MaterialCaoutchouc
ColorNoir
Colissimo - TNT - SoColissimo
Très bien
Attention toutefois.
Dans mon cas ils étaient sous un dac et reposaient sur mon preampli.
J'ai senti quelques duretés parties aussitôt le déménagement du dac effectué
This review has been posted for VIBRAPOD ISOLATORS MODEL1 Insulator / Absorber Vibration (Set x4)
