DD TC35I 2021 DAC Adapter Male Lightning to Female Jack 3.5mm 32bit 384kHz
This TC35I 2021 adapter consists of a female 3.5mm jack connector and a Lightning male connector. It will allow you to connect a 3.5mm Jack to an Apple device with only a Lightning connector, as it is the case on the latest iPhone. The components are integrated in a compact and robust 316 stainless steel case.
Reference : 15418
39,90 €tax incl.
33,25 € tax excl.
TC35I 2021
TC35I 2021 Adaptateur DAC Lightning vers Jack 3.5mm Femelle CTIA 32bit 384kHz
This TC35I 2021 adapter consists of a female 3.5mm jack connector and a Lightning male connector. It will allow you to connect a 3.5mm Jack to an Apple device with only a Lightning connector, as it is the case on the latest iPhone. The components are integrated in a compact and robust 316 stainless steel case. The TC35I automatically detects and activates when a headset is connected to it. The adapter can also be used with headphones/headsets with built-in controls and microphones.
In this 2021 version, the TC35I becomes lighter and benefits from a better finish, thanks to the use of a new Aluminium alloy.
Product typeJack 3.5mm / Lightning adapter
ConnectorsJack 3.5mm femelle
Lightning
THD+N< -92dB
DNR> 110dB
SNR> 120dB
Output power30mW @ 32Ω
Recommended headphone impedance16-200Ω
Case materialAluminum alloy
ColorBlue
InputLightning
OutputJack 3.5mm
DAC / ADC ChipNC
Max sampling rate384kHz
ColorSilver
This TC35I 2021 adapter consists of a female 3.5mm jack connector and a Lightning male connector. It will allow you to connect a 3.5mm Jack to an...
